#11 |
just ordered the pcb parts (from george's list) from digikey ... except the sockets
cant wait ..... |
#12 |
Don't know if its any help to you but I was having trouble sourcing the 4 pin pcb mount sockets. I found that if you take the collar off a chassis mount tube socket the lugs fit right into the pcb holes. Not sure if this is common knowledge but it was a little epiphany for me.
#13 | |
#14 |
While I'm sure the 372JX is a very good power transformer, it is a 600VCT unit. You'll end up with a B+ somewhere around 350VDC. The 374BX is a 750VCT unit (more like 780VCT with no load on it) and will give you a B+ around 455VDC.
Either choice will make for a fine Simple SE power supply, but your choice may depend on what tubes you've selected for your outputs. If you intend to run 6V6, stay away from the 374BX. If you want to run KT88, I'd recommend the higher voltage to get the most out of your tubes. |
#15 |
yeap its the simple se, sorry for the mess
#16 | |
#17 | |
#18 |
For KT88 I'd suggest a 750VCT power transformer, such as the 374BX or Allied 6K7VG. I'm not sure the Allied would work for you - it needs 120 volt 60 Hz for the primary winding.
Make sure your power supply capacitors are rated for 500VDC. I'd probably avoid the solid state FRED rectifier diodes. The startup surge voltage is too high for my liking, and the output tubes get hit with a lot of B+ while the cathodes are still cold. Stick with a 5AR4 rectifier tube instead. 560 ohm cathode resistors work well for KT88 at this voltage. You could probably safely drive them harder with 510 ohm or 470 ohm cathode resistors too, although you're already pretty close to the rated current limit of the 374BX using the 560 ohm cathode resistors. |
#19 |
Those are the capacitors as in george's parts list :
digikey part number / P7442-ND / CAPACITOR 47UF 500V ELECT http://search.digikey.com/scripts/Dk...?name=P7442-ND P7451-ND / CAPACITOR 120UF 500V ELECT http://search.digikey.com/scripts/Dk...?name=P7451-ND |
#20 |
think thats a nice online store .....
http://www.tube-town.net/ttstore/pro...ond-374BX.html any experience anyone ?? |
| Thread Tools | Search this Thread |
| 46 and the Tubelab SE | w5jag | Tubes / Valves | 8 | 18th May 2009 08:52 PM |
| tubelab PP? | weinstro | Tubes / Valves | 9 | 25th March 2008 04:07 AM |
| Especially for Tubelab: 845 amp 2.0 | Giaime | Tubes / Valves | 24 | 30th July 2006 04:39 PM |
| tubelab | ethermion | Tubes / Valves | 24 | 20th July 2006 04:13 PM |
| Page generated in 0.10270 seconds (84.17% PHP - 15.83% MySQL) with 11 queries |
