Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 15th October 2008, 12:46 PM   #11
cjkpkg is offline cjkpkg  United States
Looks like I may need to beef up R17 and R27 to a higher resistance to maybe the 700-800 range.
Old 15th October 2008, 12:52 PM   #12
Ty_Bower's Avatar
I just tacked an extra 250 ohms in series with the existing 560 ohm resistor. Send me an email, and I'll mail you a pair.
Here's a photo of mine:
http://www.diyaudio.com/forums/showt...95#post1624995
Old 15th October 2008, 01:01 PM   #13
tubelab.com's Avatar
I plugged in the choke
If you are using a choke you should not be using R1, remove it. They are wired in parallel so you can use one or the other.
If R1 was glowing, and is now dead, there is a short somewhere. It may be intermittent, and may return to bother you again later. Please check over the wiring for anything that could be touching. If the board is mounted over a metal chassis make sure that the long pins from the electrolytic caps and tube sockets can not touch anything. If you have not mounted your transformers to a chassis yet, measure the case of each one to make sure that one of them is not hot with voltage. This is rare but it can be deadly.
As I stated in the manual every piece of metal in the amp must be grounded through the third pin on the power cord. This is usually automatic when everything is mounted to a metal chassis which is connected to the ground pin. You should have a fuse in the primary circuit. A cheap 2 amp fuse from Radio Shack will save the power transformer.
When I first started building these amps I was getting about 460 volts of B+ with SS rectification and 430 with a 5AR4. It seems that Hammond may be saving copper by leaving off some primary turns. My old 6K7VG makes 380 volts in my Simple SE with a 121 volt line, now we are getting 397 volts. I think that rasing the cathode resistors to 620 or 680 ohms with 6L6GC's is not a bad idea.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 15th October 2008, 01:27 PM   #14
Thanks George...R1 has been removed and I have implemented the fuse. I will definitely be triple checking all ground continuity as I complete the assembly on the new chassis.
My thought is that R1 blew along with the FREDs and the 5AR4 when the hot from the old PT shorted on the bell housing.
I plan to run tube rectification eventually so that may kick down the voltage just enough.
Thanks George and Ty for all your help.
Carl
Putting the Science Back into Loudspeakers graaf Multi-Way 65 2nd August 2008 12:48 AM
Flashing Rectifier Tube- Bad Thing? Sherman Tubes / Valves 46 19th August 2005 12:00 AM
rectifier board not working after putting on bypass caps. demogorgon Chip Amps 19 8th December 2004 10:31 AM
Problem putting together my preamp (simple) - please help :) elizard Solid State 4 31st March 2003 08:35 PM
Page generated in 0.08695 seconds (78.30% PHP - 21.70% MySQL) with 10 queries
