Tubelab PCBs for an 845 - a good idea? - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 1st October 2008, 03:56 AM   #1
otto88's Avatar
Default Tubelab PCBs for an 845 - a good idea?
Hi
Two questions, re volts and the circuit.
I was considering using tubelabs Tubelab SE http://tubelab.com/TubelabSE.htm for an 845.
The operating point isnt chosen yet, but likely will be around 1000 v.
When I mentioned this to a guy familiar with materials (and tubes) he said:
PCBs for an 845 - NOT a good idea
There's a VERY good reason for this, VOLTs.. lots of 'em (1 KV+) and they can jump/arc across tracks!
Fibreglass PCB substrate ain't a very insulative dielectric at HV, air is much better
A guy here will be using the Tubelab SE boards for a GM-70.
Are these boards safe in this respect for high volts?
Also, the Tubelab SE has been tried with dozens of tube, mostly 45's, 2A3's and 300B's.
How optimal would the circuit be for an 845 run into A2, with a driver of the PowerDrive, or maybe triode connected EL34, EL36 or 807?
Old 1st October 2008, 04:01 AM   #2
http://tubelab.com/845SE.htm
Old 1st October 2008, 06:33 AM   #3
otto88's Avatar
Ken,
That demonstrates that George has done it. I know hes a very experienced and innovative tube guy
But with up to 1200 volts, itd be good to know how a problem with arcing on a pcb is avoided.
I also believe him that the powerdrive and A2 improve the sound.
But before committing to a big project like an 845, itd be good to know *how the circuit which was developed as a generic circuit for other tubes, was optimised for the 845
Cheers
Old 1st October 2008, 06:53 AM   #4
billr is offline billr  New Zealand
Hi
the HT for the 845 is not on the PCB. It has 400v for the driver valves.
so it should be ok, as that is within normal parameters.
Hope that helps
Bill
Old 1st October 2008, 10:59 AM   #5
otto88's Avatar
Bill,
Thanks, that explains the volts question.
Hopefully George (who I emailed re this thread) will chime in on how the circuit was or can optimised for the 845.
Cheers
Old 1st October 2008, 01:56 PM   #6
nhuwar is offline nhuwar  United States
nhuwar's Avatar
You can still put 1.2 kv on a pcb as long as it's a glass epoxy pcb. If you have I'd say .125" gap between the + &- traces you shold be fine. Remember 30kv per centimeter in air is the instantaneous breakdown distance.
Look for a pcb made from g10 and you will never have a problem even up to 6 or 7 kv.
Nick
Old 1st October 2008, 03:10 PM   #7
Tubelab_com's Avatar
Also, the Tubelab SE has been tried with dozens of tube, mostly 45's, 2A3's and 300B's. ..... or maybe triode connected EL34, EL36 or 807?
The Tubelab SE board is a two stage amplifier PCB. It was optimized for use with 45's, 300B's and 2A3's (in that order). The board is designed for mounting a 4 pin socket that fits these DHT's directly on the PC board. I have used it with other tubes for testing purposes. Serious modification is needed to use a tube that does not have a 4 pin base in the Tubelab SE board.
The Tubelab SE isn't a generic board it was designed for use with the 3 tube types mentioned above. An 845 requires a bunch of grid drive (several hundred volts P-P). It is highly unlikely that a succesful 2 stage 845 amp could be built. What I did with my 845 amp was to use the Tubelab SE as the first two stages. In this case it functions pretty much as a normal Tubelab SE running 45 tubes. The quiescent plate voltage on the 45 is about 250 to 275 volts. I used a "PowerDrive" board to interface the Tubelab SE to the 845, creating a 3 stage amp. At least one builder has used a Tubelab SE to drive an 845 via an interstage transformer.
Some information on the PowerDrive circuit can be found here:
http://www.tubelab.com/powerdrive.htm
Are these boards safe in this respect for high volts? .....
No they are not. The Tubelab SE was designed for peak plate voltages in the 500 volt range. In my 845 amp, no extreme voltages are connected to the Tubelab SE PC board. The HV is only connected to the primary of the OPT which is connected to the plate of the 845. The peak plate voltage on the 845 can go over 2000 volts. The power supply and the OPT wiring are exposed to high voltages and special construction practices and components are required for use at these voltage levels.
There's a VERY good reason for this, VOLTs.. lots of 'em (1 KV+) and they can jump/arc across tracks! .... But with up to 1200 volts, itd be good to know how a problem with arcing on a pcb is avoided.
I did use a PC board in my HV power supply which puts out 1100 volts. The board must be designed for operation at extreme voltages. This is extremely important in humid climates (like mine), since moisture, dust, and high voltages can lead to disaster. Accidental contact with the voltages in this supply could result in DEATH! This must be carefully considered during the design of any 845 amp. All of the possible failure modes must be planned for.
A properly implemented PowerDrive circuit can drive an 845 or an 833A well into A2 without distortion without consuming power (drawing current) from the driver tube. I chose the 45 tube for my driver because of its great linearity.
A well designed transformer coupled design could be used in moderate A2. The driver tube must be capable of supplying power gince the grid current comes from the driver tube.
I put the schematics for the PowerDrive and for my 845SE amp on my web site for EXPERIENCED builders to use as a point of reference for their amp designs. An 845 amp is not for inexperienced constructors. The parts are expensive since many of them must be rated for multi kilovolt operation (transformers, capacitors, and even the wire). The probability of failure is much higher than a simple amp due to the circuit complexity and the extreme voltages. The price of failure is much higher since it is possible to fry some expensive parts, or worse.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 2nd October 2008, 07:26 AM   #8
otto88's Avatar
George,
Based on your case study described at the PowerDrive cookbook page, I also intend to run into A2, primarily for the lower distortion. (Though Im also after 35-40 watts).
A friend whos more tube knowledgeable than me, who would be doing the more critical parts of the project, said re A2:
The main constraint on the driver is undistorted voltage output at 100's Vp-p and the ability to supply a few milliamps of current at the +ve peak without distorting. This may eliminate the 45
Im also attracted to using the 45 as driver (if not, possibly a triode strapped EL34, EL36 or 807 meaning not Tubelab SE boards).
With appropriate PowerDrive (rather than transformer coupled) have you found or do you see any 'limitations' using the 45 as the driver for the 845 into A2?
Old 2nd October 2008, 11:07 AM   #9
otto88's Avatar
I just re-read the article on the 845 SE amplifier itself, which I hadnt read for a while.
The best version of the amp uses mosfets both after *and before* the 45 driver stage.
So apparently that overcomes any limitations using the 45 as the driver for the 845 into A2?
Old 2nd October 2008, 01:09 PM   #10
The PowerDrive circuit seperates the voltage amplification and the current sourcing functions. The tube (45 in this case) provides the voltage gain. The CCS and the mosfet follower allows the tube to operate with a very high load impedance so it does not have to provide any drive current even in A2. The tube provides pure voltage amplification. The 45 is very well suited for this task.
The mosfet buffer sources all of the drive current for the output tube. I took the unmodified 845 am and wired it up to an 833A tube. The Power Drive circuit had no problems with grid current peaks of several hundred mA. Power output was in the 200 watt range.
http://www.tubelab.com/833SE.htm
Is this a good idea? Nolantor19 Multi-Way 3 12th August 2009 12:36 AM
Where is a good place to get PCBs manufactured? turbo_slug Parts 12 21st March 2007 04:59 PM
Seems a good Diy idea !! sivan_and Everything Else 1 12th November 2006 07:44 AM
is this a good idea??? dmh Solid State 16 24th February 2005 03:47 AM
Good high output class D design with available PCBs... wigginjs Class D 5 13th September 2004 11:02 PM
Copyright 1999-2017 diyAudio
