| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I would like to built another SimpleSE.
I have in stock a power transformer the James JS-9611. Can I use it with the SimpleSE ? For the 6.3V, I dont have only 2 wires like Hammond. How should I connect the james to the board ? |
#2 |
You could parallel Secondary 3, 4 and 5 together and connect them to the Simple SE board. That would get you nine amps of 6.3 volts. That might even be too much capacity - you might find the heater voltage tends to run high. If so, just use two of the 6.3 volt secondaries.
Keep the 2.5 volt taps on sec 4 and sec 5 away from anything. Wire nut and / or tape them back safely out of the way. Be sure to observe the proper phasing of the windings - if you parallel them out of phase, you'll get zero volts instead of 6.3. |
| WTB: James 9611 or 9612 | pabbi1 | Swap Meet | 2 | 31st May 2009 01:16 AM |
| FS: James JS-9611 Power Xfmr | t3447ml | Swap Meet | 1 | 30th May 2009 10:10 PM |
| James Transformers JS-6113HS vsEdcorCXSE25-8-5K for SimpleSE | Mungo Park | Tubelab | 9 | 24th April 2009 02:55 AM |
| SimpleSE and me | allyourzigg | Tubes / Valves | 8 | 1st August 2007 02:44 AM |
| Fun with James | Nixie | The Lounge | 2 | 1st March 2007 06:13 PM |
