| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#41 |
What is the best configuration for the SimpleSe with EL34 for the B+ and the cathode resistors ?
#42 |
I'm a big fan of the Hammond 374BX, though it is more expensive than some of the other options. It'll give you a B+ of about 450 volts. You could also use the less expensive Hammond 274BX or the downright frugal Allied 6K7VG. They should result in similar B+ voltages.
With 560 ohm cathode bias resistors, you'll probably end up just a bit over 60 mA idle current per tube. Overall dissipation would be somewhere over 20 watts, but under 24. If your tubes will handle that without overheating the plates, then go for it. The big Electroharmonix 6CA7EH are perfectly happy running here. I've also tried some Reflektor 6p3s-e and some Shuguang 6L6GC and the wattage is just a bit too much for them. They'd probably be happier with a 620 or 680 ohm cathode resistor instead. |
#43 |
I have already built a SimpleSe with KT88.
I use for power transformer the Hammond 374BX For OPT's the Tango U-808 output tube KTt88-98 Shuguang driver tube 12AT7 Siemens rectifier tube 5AR4 Telefunken My B+ 450 volts With 560 ohm cathode bias resistors. In this condition I think the setting is perfect but the B+ a bit high for the EL34. I would like to use it with a conservative setting. I have in stock for the OPT James 6123HS and for the power transformer the James JS9611. |
#44 |
Well.
I started turning my top plate into swiss cheese tonight to rotate my PT...as I did discover that I had a hum issue. I rotated the PT and the hum is still there. I left the PT sort of loose and was able to move it around 1-2 inches and the hum did not fade in or out, it is just there... If I plug in or unplug the RCA's it makes no difference. Another question. I bought a capacitor off ebay a while back when I was still at the beginning of my learing curve (believe me I am not much farther up the curve yet, but I'm getting there). It is a 90uF 375VAC as labeled. The DC voltage I read where it would be installed is about 500VDC. I think I can safely assume I should NOT use this cap. Not sure what, if any, the rating difference between DC and AC may be. |
#45 |
A film or oil cap rated for a particular volts AC is suitable for use at much higher DC voltages. I can't recall the exact conversion factor, but I think it's somewhere between 1.4x and 1.6x. In other words, your 375VAC cap ought to be safe to use at 500 volts DC.
My Simple SE had a noticeable 60 Hz hum when I first assembled it. It seemed to be a ground loop passing through the chassis ground and over the RCA jack grounds. When I built it, I failed to use isolated RCA input jacks. Lifting the chassis ground eliminated the hum. I think the permanent fix is to use plastic washers to lift the RCA inputs off the chassis plate. I also notice you have no power supply choke on the top deck. Is there one under the chassis? From the simulations, it seems even a small choke (1.5H, like a Dynaco C354) should cut the residual 120 Hz hum on the B+ supply by a factor of four. A decent sized choke, say 5~10 H ought to reduce it by a factor of ten. |
#46 | |
I have seen published multiplication factors as high as 2X. The normal application for these caps is to shift the phase in a motor winding which is an inductor. This means that the voltage seen by the capacitor may be higher than 1.414 times the RMS value. I wouldn't go that far since one of these things could be ugly if it ever blew up. I have applied about 600 volts to my cap for short periods of time during some experiments. The hum in your amp could be 120 Hz from the power supply. This usually sounds more like a buzz than a hum. It could also be a 60 Hz hum from a grounding issue. It is not always easy to chase this down. Try this test. Remove the 12AT7. Turn the amp on and see if the hum is still there. If it is, it is not coming from the input wiring. Do you have a choke in your power supply? If not, it might be a good idea. The motor run cap will help too. If the hum goes away it was likely due to the grounding associated with the input wiring.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#47 | |
I will try out the cap. I will play around with the RCA's. I will try the 12AT7 test and let you know... Thanks! Carl |
#48 |
You have room under the chassis, so use the ugly but effective Triad C-14X. It is about $15 from Allied Electronics. I use it in my amps. I have noticed a low hum without it. My low hum could be louder with better speakers. Make sure you remove R1 when you add the choke. (www.alliedelec.com)
#49 | |
For what it's worth, I placed my bet on the choke. I sometimes wonder if I'm missing out because I didn't add the motor run cap. |
#50 |
OK,
I isolated the RCA inputs and made no difference. I pulled the 12at7 and the hum actually got worse...and with that it sounded more like a buzz than a hum... |
| (YATSE) Yet Another Tubelab SE (sorry...long) | rknize | Tubelab | 12 | 23rd June 2009 06:39 AM |
| Nubie first build Tubelab simple SE | Mungo Park | Tubelab | 65 | 27th May 2009 05:41 PM |
| Long time lurker - Intro! | hack247.co.uk | Introductions | 1 | 29th May 2006 08:54 PM |
| First time caller, long time listener... | smallangryboy | Introductions | 15 | 19th March 2005 08:10 PM |
| Forgot to do this long long time ago | chris ma | Introductions | 2 | 30th October 2003 10:53 PM |
