| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I'm researching options for the two coupling capacitors needed for the Simple SE board. This would be C11 and C21.
Certainly the Mallory caps as noted on the parts list are an economical option. I'm wondering if the Wima FKP box caps would fit on the board. The pin spacing appears to be about right. Mouser sells them (505-FKP1.22/630/5P3), but they're kinda pricey ($6.52 a piece). I've used Sprague orange drops (715/716) before with good success. I'd bet they would fit reasonably well. Finally, I've got a pair of the Russian K40Y-9 caps that I'd like to try. Unfortunately, the 1000V rated ones seem huge, and I'm not sure how to get them to fit on the Simple SE board. Any advice? |
#2 |
| no coupling caps | ray bronk | Tubes / Valves | 2 | 20th May 2008 07:10 AM |
| Pre-amp coupling caps | Bill Fitzpatrick | Parts | 15 | 4th March 2005 11:54 AM |
| coupling caps | el capitan83 | Tubes / Valves | 10 | 17th December 2004 04:25 PM |
| coupling caps??? | AudioGeek | Tubes / Valves | 14 | 16th September 2004 12:05 PM |
| What value for the coupling caps? | roibm | Parts | 12 | 23rd March 2004 05:58 PM |
