| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#11 |
I had an 845 go gassy on me. I still haven't bothered fixing the amp since the results were so disturbing. The 'lytics in the amp are rated at 3.2kv, but I think the grid bias supply for the 845 amp lost some caps.
#12 |
George you make me smile.
Keep up the good work. |
#13 |
Alllriiiight! Glowing tubes without the need to put them in the microwave
Funny, a pair of crummy ones that did that to me were Sylvania too. But they were yellow print. |
#14 | |||||
The moral of this story is, If you see a white getter, don't put it in your amp!
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#15 |
The moral of the moral is
Be aware of (not so) lo priced bulk lots Rejected, but stored ones, are starting to appear on the market. Specially from WW2 era Yves. |
#16 | |
*gets BB gun *
#17 | |
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#18 | |
Gives new meaning to the term "shootout". Jeff |
#19 |
George, I always love reading about your adventures in tube testing. Bravo my friend.
When you got'em by the ball's their heart's and mind's will follow! |
#20 |
I set out to perform the autopsy, and found that the patient was still alive. I had yanked the power cord to the oscillator by mistake. The amp is still alive even with the exploded cap. There is this messy goo all over the PC board and all of the parts. I changed the cap, wiped up the goo put in some more of the Sylvanias and cranked it up again. OK it works, makes about 2.2 WPC and still sounds good, but this is BORING, and I got a box full of tubes to test.
What's next..... After thinking for a few milliseconds, it became perfectly obvious. I needed to answer the question. You know the question that I always ask. How much power can you get out of this thing. Well, even I know that exploring the upper limits will require gome glowing tubes, but I don't need any more exploding capacitors, and I need some more knobs to turn, so its time for fixed (adjustable) bias. No more resistors in the path to slow down the flow of POWER. Speaking of power, I am going to need some more. So I wired up the big Fluke. Now I can go to 550 volts and 300 mA. The tubes are not going to like this! I jumped the cathode resistor, and connected the bias terminals of the power supply up to the grid resistors. At first I was running both channels, but I only have one bias knob, so I pulled one tube and decided to wire the remaining tube in UL mode. I put in one of the better looking Sylvanias and cranked it, and cranked it and finally just turned the power supply all the way up. Thats right a 6V6 with 550 volts of B+, 535 volts across the tube. I decided to ignore the glow and set the bias for the best power and lowest distortion. Would you believe that a 6V6 can put out 10 watts at 3% distortion, 11.6 watts at 5% distortion, and 17.2 watts when driven to maximum power. The bias current was 100 mA. this means a static dissipation of 53 watts, minus the output power! Remember this is a 6V6 in SE! You must know what the tube looks like! As I said before, good Sylvanias are tough tubes.
| death of zen | janey | Pass Labs | 29 | 16th September 2009 08:59 PM |
| The death of Hi-Fi | SunRa | Everything Else | 9 | 16th October 2008 03:22 AM |
| Death Of Zen | DoomPixie | Solid State | 2 | 22nd August 2006 10:21 PM |
| Death Of zen On 15V supply? | DoomPixie | Solid State | 18 | 21st August 2006 09:47 PM |
| DEATH by UPS | exurbia | Planars & Exotics | 10 | 4th June 2006 11:29 AM |
| Page generated in 0.16197 seconds (100.00% PHP - 0% MySQL) with 10 queries |
