Tubelab SE diode substitute - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 22nd April 2008, 03:29 AM   #1
sbelyo is offline sbelyo  United States
Default Tubelab SE diode substitute
D2, D3
Manufacturer IXYS
Manufacturer Part Number DSEI12-12A
Description DIODE FRED 1200V 11A TO-220AC
Digikey and mouser are out of them until mid June...
Is there a substitute from mouser or allied that is just as good?
Old 22nd April 2008, 11:21 PM   #2
I don't see anything on mouser
Old 23rd April 2008, 02:14 AM   #3
Tubelab_com's Avatar
Any FRED diode that is rated for 1200 volts or more will work. Other TO220 packaged diodes with a "fast recovery" or "soft recovery" characteristic will also work.
I have used the IXYS DSEI 20-12A and the IR HFA06TB120PBF (now made by Vishay) before.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 23rd April 2008, 03:52 AM   #4
Thanks George...
Is there any problem with using this resistor for R7 from mouser instead of the panasonic one from digikey.
https://www.mouser.com/Search/Produc...-MO2LT631R104J
It's bigger, but it looks like the lead spacing will just fit. I just don't want to use a part that will degrade the sound.
Old 23rd April 2008, 04:30 AM   #5
It's same value and same type (metal oxide). I don't see why it wouldn't do the job just as well.
Old 23rd April 2008, 08:05 PM   #6
I was in the same situation over the weekend, and I decided to order p/n 747-DSEI12-10A. This has nearly the same specs as the 747-DSEI12-12A, the only differences being:
10A 12A
Vfwd 2.1V 2.2V
Pdsp 75W 78W
Vrev 1000V 1200V
Are these specs not acceptable? I noticed that Mr. Tubelab mentioned a reverse voltage of 1200V...
Should I order the DSEI20-12A instead?
Thanks,
Eddie
tubelab se DimZ Tubelab 58 20th January 2009 12:47 PM
tubelab PP? weinstro Tubelab 9 25th March 2008 03:07 AM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
tubelab ethermion Tubelab 24 20th July 2006 03:13 PM
Copyright 1999-2017 diyAudio
