Tubelab simple SE help needed...working but only on one channel - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 1st April 2008, 02:13 PM   #11
chrish is offline chrish  Australia
chrish's Avatar
Also see that you have four switches on the front. You have probably read the warnings, but don't wire up a standby switch. I have the same Hammond transformer as you (374BX?) and 193H choke with a oil motor run cap. I was using a JJ GZ34 and had flashover and ended up frying my solid state diodes. I just use valve rectification and no standby switch. No problems since.
Chris
Old 2nd April 2008, 06:32 PM   #12
waam68 is offline waam68  United Kingdom
Bit of a newsflash!
Amp fixed & now sounding sweet on both channels!
Big thanks to Chris (again) as I have a feeling the holes I'd cut for the input & speaker jacks were too small on my thick hammond steel chassis....poss caused some earth/shorting prob to chassis? Anyway I bored them out & measured pin voltages...found a duff one on an output valve so re did most joints....
Stage 2 will be wire up the mode switch & wire in the supp oil cap
although there is no hum at all (which is nice)
Things I've learnt on this first build are:
build it on a breadboard first (I will next time)
It takes longer than you think if you have no real knowledge but you will start to learn by doing (a little anyway)...don't give up!
I would recommend the Simple SE as a great first project (If I can build it in my guestbedroom..you probably can too), it sounds excellent & George goes the extra mile to help out.
Mike
Tubelab Simple P-P booangler Tubelab 669 23rd March 2016 04:37 AM
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 12:18 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 04:15 AM
Copyright 1999-2017 diyAudio
