tubelab SE 300b power transformer - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 10th March 2008, 12:15 AM   #21
adwsail is offline adwsail  United States
Tubelab, been lovin the SE for a couple of years now, popped one of the 2SK2700. Any off the top recommendations for replacements given they aren't readily available any longer?
Old 10th March 2008, 01:16 AM   #22
Tubelab_com's Avatar
The 2SK2700 mosfet has gone extinct due to ROHS laws. Toshiba decided to discontinue the part rather than make an unleaded version. I have found two suitable substitutes, the Fairchild FQP1N50 and the Supertex DN2540N5. I have been using the Fairchild part in my amplifiers. The Supertex part is only rated for 400 volts. The mosfet gets the B+ voltage on one end and the grid bias voltage (negative 50 volts or so) so it may me marginal in some amplifiers. Several users report good results with it though.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 10th March 2008, 01:46 AM   #23
Outstanding. I really appreciate the help.
Old 13th March 2008, 12:33 AM   #24
Do the Mylar insulators come with the parts? If not, where can they be bought?
Old 13th March 2008, 01:01 AM   #25
The mylar insulator is not needed on the mosfet. This will cause a high voltage to appear on the heat sink, but that voltage is already on the heat sink of the CCS chip. Mylar insulators can be used on those parts if you want though.
The insulator is needed on the filament regulator chip though. The insulators do not typically come with the parts. I use BER114-ND from DigiKey.
Old 13th March 2008, 01:10 AM   #26
Boris_The_Blade's Avatar
I use kapton (polyimide) insulators and shoulder washers from digikey with great success. They don't use messy silicone paste which is really nice.
Old 14th March 2008, 03:54 PM   #27
Default What about the fuse?
Will the power fuse be dependent on PT? And what value should one use for Tubelab SE?
Old 14th March 2008, 04:56 PM   #28
I have been using 2 amp fuses in 120 volt powered amps and 1 amp fuses for 240 volts.
Tubelab SE - alternate power transformer Evenharmonics Tubelab 22 14th June 2010 12:17 AM
Edcor Universal Power Transformer for Tubelab SE rknize Tubelab 43 19th June 2009 09:11 PM
tubelab SimpleSe power transformer connection question dubdub Tubelab 10 12th September 2008 01:30 AM
Noob Power transformer for Tubelab SimpleSE dubdub Tubelab 9 4th February 2008 08:42 PM
GTA 300B SE Mk.II Power Transformer korneluk Tubes / Valves 4 17th December 2007 05:09 PM
Copyright 1999-2017 diyAudio
