The Lounge A place to talk about almost anything but politics and religion.
How Do DSL Companies Limit Speeds to Narrow Ranges?
Old 9th April 2007, 12:59 AM   #1
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Default How Do DSL Companies Limit Speeds to Narrow Ranges?
Taking a look at some DSL plans, I see that different plans have different upload and download speeds.
How do they do that? I know that speeds vary anyway, how do they make sure that each customer can only go so fast or so slow?
A not-too-technical explanation would be appreciated.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 9th April 2007, 01:10 AM   #2
Geek is offline Geek
Geek's Avatar
Bandwidth throttling is easy to do.
How they do it for each customer is each computer on their network can be identified by I.P. or MAC address. Their equipment then compares internet requests from those addresses with a list of who gets throttled back.
Cheers!
Old 9th April 2007, 01:49 AM   #3
Wizard of Kelts
The speeds vary within each plan.
Technically, how is the bandwidth throttling accomplished?
Do they do it proportionately, such as one customer is on the 1/4 full bandwidth plan, the other customer is on the onehalf bandwidth plan, etc?
Because within each plan, the speeds vary. If everyone always got one speed, I can see a specific speed being assigned per plan. But if the network itself varies as to what it can deliver, I wonder how they divide it up.
-Anonymous
Old 9th April 2007, 03:44 AM   #4
Geek's Avatar
They can do it either with software, which just gives lower plans less of a share of the traffic. This can be done in the load balancer, a device that makes sure no one customer or piece of equipment is being a hog, or it could be done at the DSL hub, which is within 4Km of each subscriber.
They could offer too, a different protocol for each plan. More detailed info on the plethora of DSL protocols here:
http://whatis.techtarget.com/definit...213915,00.html
Hope this helps
Old 9th May 2007, 10:20 AM   #5
jacquesl is offline jacquesl  South Africa
jacquesl's Avatar
kelticwizard, did you found your software?
Old 9th May 2007, 02:34 PM   #6
Wizard of Kelts
jacques:
I'm not certain what you mean by the question. I just wanted to know how the telephone company limits the bandwidth on individual DSL lines. I did not anticipate getting any software for this, unless it is the software which comes with the router.
Could it be some software for some other thing I might have mentioned, that you are referring to?
-Anonymous
Old 9th May 2007, 02:55 PM   #7
jacquesl's Avatar
Quote: “Technically, how is the bandwidth throttling accomplished?”
Oh sorry, I though you wanted to start your own ISP and / or create ISP accounts for your customers, and that also has to do mainly with bandwidth controlling and user management
How Do DSL Companies Limit Speeds to Narrow Ranges?Hide this!Advertise here!
FireWire speeds set to quadruple (to 3.2 GigaBit !) FastEddy Digital Source 0 18th December 2007 05:12 PM
Origin of turntable speeds Netlist Analogue Source 3 16th October 2007 06:10 PM
Resistance ranges and maths eeka chu Everything Else 2 22nd July 2005 07:46 PM
Power amp transistor speeds? AndrewT Solid State 7 23rd May 2005 08:13 PM
Dual Mid-Ranges in a 3-way Design wigginjs Multi-Way 7 25th September 2004 08:20 AM
Copyright ©1999-2017 diyAudio
