The Lounge A place to talk about almost anything but politics and religion.
Threadjacking
Threadjacking
Old 18th July 2013, 10:58 PM   #1891
7n7is is offline 7n7is
Banned
Optics
Old 19th July 2013, 07:04 AM   #1892
keantoken is offline keantoken  United States
keantoken's Avatar
We were looking for replacement parts for a vintage Osterizer 825W blender today. The original glass jar is nowhere to be found so it must have been broken. So far we've been using mason jars which have the same threading. The blade leaks and rattles when shaken. The gasket is dried out but surprisingly doesn't crack.
We were wondering whether a cheap modern blender would outperform this one. My brother suggested that more power was the main thing, but I'm sure a lot more must matter. For instance the Osterizer takes care not to mount the motor directly to the chassis. It also has a rubber decoupler between the blade and motor. This all must be important for energy transfer. Not to mention motor speed vs force and inertia.
Of course at 825W this might outperform anything reasonably cheap outright.
I wonder what would be the tune-up procedures on the motor and what kind of grease I should use. There doesn't seem to be an easy way to remove the old decoupler which is stuck on.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 22nd July 2013, 04:24 AM   #1893
keantoken's Avatar
Also, the blender proudly bears the words "SOLID STATE".
It has exactly ONE diode, as far as I can tell.
Old 23rd July 2013, 01:00 AM   #1894
Bigun is offline Bigun  Canada
Bigun's Avatar
Threadjacking
Now there's your problem. Only one diode. What can you do with only one diode. Hardly seems adequate.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 28th July 2013, 09:48 PM   #1895
Banned
Some Spectra
Old 3rd August 2013, 01:58 PM   #1896
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
Old 5th August 2013, 03:07 AM   #1897
tomtt's Avatar
Old 14th August 2013, 08:27 AM   #1898
tomtt's Avatar
Old 15th August 2013, 06:42 AM   #1899
tomtt's Avatar
Every Second on the Internet
73209
Old 23rd August 2013, 03:33 AM   #1900
benb is offline benb  United States
I got your low-jitter clock source right here:
Ytterbium atomic clocks set record for stability
The ytterbium clock ticks are stable to within less than two parts in 1 quintillion (1 followed by 18 zeros), roughly 10 times better than the previous best published results for other atomic clocks.
ThreadjackingHide this!Advertise here!
Copyright ©1999-2017 diyAudio
