The Lounge A place to talk about almost anything but politics and religion.
Do you have a strange mind?
Old 10th July 2006, 06:56 PM   #11
KBK is offline KBK  Canada
Default Re: Do you have a strange mind?
fi yuo cna raed tihs, yuo hvae a sgtrane mnid too. Cna yuo raed tihs? Olny 55 out of 100 plepoe can. I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg. wtih the phaonmneal pewor of the hmuan mnid, aoccdrnig to rscheearch at Cmabrigde Uinervtisy, it dseno't mtaetr in waht oerdr the ltteres in a wrod are, the olny iproamtnt tihng is taht the frsit and lsat ltteer be in the rghit pclae. The rset can be a taotl mses and you can sitll raed it whotuit a pboerlm. The huamn mnid deos not r! aed ervey lteter by istlef, but the wrod as a wlohe. Azanmig huh? yaeh and I awlyas tghuhot slpeling was ipmorantt!
-T
I read this at my normal speed, which is at about a page every 30 seconds. That's pleasure reading, as in novels. Speed reading, that's different. For speed reading the letters must be in the proper sequence, as it is a form of bulk pattern recognition. THis is the same as normal reading (for most of us), but the rate which they are assimilated at in speed reading makes the proper spelling and organization critical.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 10th July 2006, 07:18 PM   #12
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Originally posted by Christer
we have to find at least one, preferrably two
Wiat uiltnl E8C100 rades tihs taerhd.
/Hugo
Old 11th July 2006, 01:39 AM   #13
maxro is offline maxro  Canada
maxro's Avatar
I also read this at my normal pace. Maybe it has something to do with my feeling that I'm developing dyslexia. When writing quickly, I tend to skip a letter or two ahead of myself and have to go back and fill in the blanks.
Max
"No one likes jazz that much; even the guy playing it had to take drugs." -Bart Simpson
Old 11th July 2006, 05:30 AM   #14
francis varkey is offline francis varkey  India
Trehe.
Took some time to make out it's "there".
Whereas the original post was easy reading.
Guess I don't belong to the "55 out of 100 plepoe"
Old 11th July 2006, 06:06 AM   #15
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Innsteerstig. You have to choose how you mix up the letters quite carefully otherwise it's difficult to decode. Although I could read the thread's first example easily, I'll bet that "innsteerstig" slowed you down - it appears that easy decoding requires that the new arrangement must not look anything like a valid word. Anyone using this as an excuse for textspeak will still find themselves in tluobre.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 11th July 2006, 08:13 AM   #16
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Actually it wasn't "There" but rather "Three".
- Dan
Old 11th July 2006, 08:14 AM   #17
Warp Engineer
On Holiday
AudioFreak's Avatar
Not for a second.
- Dan
Old 11th July 2006, 08:28 AM   #18
Srory, nevertheless I'm not as dyslexic/non-dyslexic as I'd thought.
Old 11th July 2006, 08:33 AM   #19
Tee-Rex is offline Tee-Rex  Israel
I'm sure the order matters. What if I wrote:
iieettnnsrg
or
mtdrooear
Those would probably slow most of us down. So some rules probably need to be applied in order to make it easily readable.
-T
"I can resist everything, except temptation" - Oscar Wilde
Old 11th July 2006, 08:36 AM   #20
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
The first took a second or so, the second I had no problem with. I suspect the context is important, the more information you have, such as use in a longer sentence, the quicker you can decode the wdros.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Do you have a strange mind?Hide this!Advertise here!
XRT28 in mind wilbur-x Multi-Way 1 11th July 2008 01:32 PM
Changing my mind. E. Pardaans Pass Labs 11 12th December 2005 12:09 PM
I've lost my mind bjackson Multi-Way 3 30th October 2005 05:58 AM
Ok ok, so i changed my mind.... Lisandro_P Solid State 7 24th July 2001 02:10 AM
Copyright ©1999-2017 diyAudio
