The Lounge A place to talk about almost anything but politics and religion.
Question on physics :)
Old 6th May 2006, 09:00 PM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default qquestion on physics :)
look at the pic ...
the small wheel is turning the big wheel ,when a chain is connecting between them .
if the small wheel is turning at constant speed , no friction whatsoever ...
is there a force on the chain?
if you are not living on the edge you are taking too much space
Old 6th May 2006, 10:11 PM   #2
On Hiatus
SY's Avatar
Once everything is up to speed, no, assuming everything is lossless. The big wheel's angular momentum is conserved.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th May 2006, 05:36 AM   #3
maxro is offline maxro  Canada
maxro's Avatar
What's the real-world application? There is no such thing as 'no friction whatsoever'. Beware, this could turn into another conveyer-belt thread.
Max
"No one likes jazz that much; even the guy playing it had to take drugs." -Bart Simpson
Old 8th May 2006, 04:37 AM   #4
sss's Avatar
Max
nah , SV allready answered the question (thanx btw!)
but , i forgot ,there must be a static friction between the chain and the wheels , if not then the chain wont move
Old 9th May 2006, 03:53 AM   #5
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
There has to be a force on the chain. If there was no force, the momentum of the links that are going straight would keep them going straight. But as you illustrated, they go around the sprockets. The centripetal acceleration of the links makes chain want to come off the sprocket as it goes around. The chain, being a loop, prevents this because the other side of the chain going around the other sprocket wants to come off in the opposite direction. All this results in tension in the chain.
If the chain was a perfect circle, then there would be no force on it.
Old 9th May 2006, 02:43 PM   #6
quasi is offline quasi  Australia
quasi's Avatar
But even if the chain was a perfect circle wouldn't there be an amount of centrifical force on each chain link as it moved around?
Old 9th May 2006, 03:08 PM   #7
quasi's Avatar
sorry ...couldn't resist .....tried not to but ....
Old 9th May 2006, 03:25 PM   #8
anatech is offline anatech  Canada
anatech's Avatar
Way to go quasi!
Troublemaker!
-Chris
Old 9th May 2006, 03:50 PM   #9
xplod1236's Avatar
You're right. Either way, there would be tension in the chain. I don't know how I missed that part.
Old 9th May 2006, 05:23 PM   #10
sss's Avatar
if the chain got no weight to it then there will be no tension if the wheels are spinning at constant speed
Question on physics :)Hide this!Advertise here!
Emerald Physics JonasKarud Multi-Way 53 15th August 2015 12:05 AM
Physics puzzle star882 The Lounge 20 14th October 2007 01:26 PM
speaker box design physics question priscared Car Audio 4 18th November 2005 11:07 PM
Physics question! Nappylady Multi-Way 3 13th May 2005 01:29 AM
physics equations slackerbob Multi-Way 22 15th November 2003 11:49 AM
Copyright ©1999-2017 diyAudio
