The Lounge A place to talk about almost anything but politics and religion.
I now have one of these.....
Old 9th September 2004, 10:44 PM   #11
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
Originally posted by ace3000_1
Skinny, if you tap into your brothers room and draw 15amps this doesnt mean its safe to do so, he would have to have all apliances off, and depending on your cable length your lines maybe under rated. Power Cables are normally rated at their spec upto a distance of 15 - 20meters. Wheather your welder is on full pelt or not, it would be atlaest safe to power it with the required 15amps as stated by the manufacturer. How do you know it doesnt draw 15amps at half power? from a few welders that ive looked in they used a big resistor to control the power output thus drawing its rated current draw all of the time, the others wer switches to change the winding in the coils.
Trev
did I mention my brother is out over half the time? and when he's not home, all that is powered up in his room is a clock radio?
Old 10th September 2004, 12:36 AM   #12
ace3000_1 is offline ace3000_1  Australia
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
do arc welders generally have some protection for if you short out the output? I guess it would have to.
No they dont, if you had a fuse for the output circut then you wouldnt be able to weld, because a arc welder is just a power supply that we short out on purpose.
also, welding currents/voltages... whats best? I have 45 or 70 volts, at adjustable currents... I read somewhere that most small arc welders are 40 volts. is higher voltage therefore better?
Higher voltages are used for thick plate, normally 10mm and up, that also goes with the amperage, the thinner the plate is the lower the voltage and amperage.
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts."
Old 10th September 2004, 12:37 AM   #13
ace3000_1's Avatar
LOL, are you sure there isnt any grow lights in the wardrobe?
Old 10th September 2004, 02:13 AM   #14
Banned
Trev
I didn't say a FUSE, I said short circuit protection... I should have said current limiting.. but anyway see, my dad made an adjustable powersupply with a selectable current limiting.... .5amps, 1 amp, and 2.5amps (I think) so even if you dead short it, it still only gives that much current....
Old 10th September 2004, 04:30 AM   #15
ace3000_1's Avatar
No short circut protection because your shorting the welder out on purpose to create the arc. There should be thermal protection but thats it, the psu your dad made is basically the same as your welder, you controll your current via the dial on the front, there isnt to my knewlege any over current protection on the input for over drawing power cos normally you would use a breaker with it in the fuse box.
Trev
Old 13th September 2004, 07:23 AM   #16
Banned
I think the current is limited by the core reaching saturation... the current is adjusted by moving a bar in and out of the core of the transformer....
I now have one of these.....Hide this!Advertise here!
