Silver RCA Cable-share your experience, opinions here!
It would appear that the placebo effect mentioned by mictester has not fully worked for Audio Arenaline!
Is it too silly to suggest obtaining phono splitters in order to experiment with running the old and new interconnects in parallel? :)
697983d1534546186t-silver-rca-cable-share-experience-opinions-phono-splitters-jpg
That's a cool idea for anyone wants to test if they can hear a difference in two sets of cables at home with a good friend. It might in some systems allow hot swapping cables on the fly using a make before break double cabling before pulling one cable out without needing to turn off gear. Ideally a helper would swap cables around so the listener doesn't know which cable is in place. Audio sensory working memory is very short so rapid switching is a useful strategy. Running a simple home trial like this allows expectation bias to be challenged. Remember expectation bias is so strong many a pilot has died from it.
Your tone-arm may have silver litz wire (multi-strand).
Yes, it is Litz. Thank you for pointing this out. Never crossed my mind, as i have no other experience with stranded silver. Useful knowledge!
Maybe it is the chemicals you use.
Possible but unlikely. Only use the old kitchen foil/ bicarbonate recipe once the sulfide layer becomes intolerable.
The center conductor of a RCA cable could be copper, gold, silver or aluminium of any reasonable diameter and be solid or stranded and there will be no change in the sound.
Exactly.
Similarly, as long as the speaker cables have no significant resistance (one manufacturer did supply deliberately resistive speaker cables in the 1980s), no change of speaker cable will ever be audible. No amount of silver, gold, antimony or platinum will make the slightest difference - except to price!
Hello,
Do agree for the most part. But it is possible to use a construction of the wires such as to jack way up the capacitance or inductance of the cable.
What you really meant to say (IMHO) was that with a reasonable construction there would be no difference.
Greg
for example you can hear the quality of sound change in my system at different times of day as they change the amperage of the ac power they are putting through at around 5-6 pm :whacko:
:rolleyes: :rofl:
Oh dear. Some basic understanding of electrical properties required here....
The supply VOLTAGE may vary, and if that has an audible effect on the way your equipment sounds, your equipment is defective.
Competently designed amplifiers (and pre-amplifiers) are designed to be unaffected by the accepted range of power supply. If the supply to your house is sub-standard, leading to significantly lowered voltages during periods of peak demand, get on to your electricity supplier and get them to repair your supply.
Joined 2005
You all sound like the guys looking in the window of the McLaren showroom insulting the price of something you don’t want to pay that much for or appreciate. None of you have said you have any of this silver wire so how would you know? And is the rest of your system and hearing up to revealing the difference. In my system solid silver wire sounds better than the silver plated copper wire which sounds better than the copper wire. Your value system and hearing may differ.
