The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 6th July 2018, 07:32 AM   #111
chris719 is offline chris719  United States
Originally Posted by JPS64 View Post
As promised.
The reference of the DRAKA (Prysmian Group) is F 4709-17.
Test equipment:
- 2GHz Oscilloscope 10GS/s WAVERUNNER 204Xi LECROY
- Active Differential Probe WL300 LECROY
- USB Test Fixture TF-USB LECROY
According USB-IF compliance program (http://www.usb.org/developers/compliance/):
--> Overall result: pass!
- Signal eye: eye passes
- EOP width: 7.89 bits: EOP width passes
- Measured signaling rate: 480.0834 MHz: signal rate passes
- Rising Edge Rate: 1005.11 V/us (636.74 ps equivalent risetime): passes
- Falling Edge Rate: 974.79 V/us (656.55 ps equivalent risetime): passes
- Consecutive jitter range: -81.928 ps to 131.408 ps, RMS jitter 49.613 ps
- Paired JK jitter range: -55.155 ps to 59.024 ps, RMS jitter 16.807 ps
- Paired KJ jitter range: -65.229 ps to 61.868 ps, RMS jitter 16.529 ps
Images attached.
ESD protection is RCLAMP0502N.
EMI CMC is DLW21S.
JP
Nice, I have used that same common-mode choke on a USB interface (different ESD protection though). They are missing from many audio designs.
Old 6th July 2018, 08:12 AM   #112
mmerrill99 is offline mmerrill99
And why do you think a CM choke is needed? Because the cable is carrying high speed USB differential signalling & the cable CAN INDUCE CM noise at the USB receiver IC - it's not simply transmitted from the source. Therefore in this one factor alone USB cables can differ, never mind all the other factors
Old 6th July 2018, 08:36 AM   #113
Originally Posted by mmerrill99 View Post
And why do you think a CM choke is needed? Because the cable is carrying high speed USB differential signalling & the cable CAN INDUCE CM noise - it's not simply transmitted from the source. Therefore in this one factor alone USB cables can differ, never mind all the other factors
It might be needed to pass emissions or immunity testing on a case by case basis. A nice to have if you don't have signal integrity problems with it populated. I'd use it, but highly doubtful it has any measurable impact on the analog output. You still have yet to describe the mechanism by which this ends up in the analog output on a piece of correctly designed gear.
There are specs for USB cables you know? They specifically discuss things like the required shield construction, twist pitch, etc.
Maybe you should get in the audiophile Ethernet cable business before that blows up.
Old 6th July 2018, 08:56 AM   #114
You now have altered your argument to admitting that there are difference between cables but doubt they have any "measurable impact on the analog output." Very interesting shift from your first rant about this
So, what is the effect of CM noise in audio? Have you ever measured the effect of cm noise on a DAC's analogue output?
I don't have to describe anything other than the possible differences between USB cables, as I have done. As I stated from the start I have heard some differences with ferrite clamps on USB cables & a USB cable (not designed for audio) designed ferrite compound wrap
Yes, there are USB specs which are meant to ensure a certain level of reliability in USB digital signal delivery. Tell us what it says about shield construction & twist pitch in the USB specs
Old 6th July 2018, 10:38 AM   #115
So, what is the effect of CM noise in audio? Have you ever measured the effect of cm noise on a DAC's analogue output? I don't have to describe anything other than the possible differences between USB cables, as I have done. As I stated from the start I have heard some differences with ferrite clamps on USB cables & a USB cable (not designed for audio) designed ferrite compound wrap
I haven't shifted at all on cables. You can continue tilting at windmills. A total non issue in gear that is correctly designed. You can find the USB cable specifications on Intel's website.
Old 6th July 2018, 10:45 AM   #116
OK, no problem you don't want to back up what you say & just want to rant
Old 6th July 2018, 10:53 AM   #117
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Guys -may I make a suggestion / observation:
You have been baited into a worthless debate by an OP who makes a practice of this kind of thing. 6 months or so ago, he was whiling away his time in a thread on the loudspeakers forum essentially trying to claim AC is not alternating, that all electrical circuits are created based on Spice models (including those created before electronic computers even existed), and that a given loudspeaker crossover will behave differently if a series component were placed in the nominal positive or negative leg (no changes to electrical component order, and independent of external influences e.g. mutual inductance interactions which is a matter of board layout / component configuration rather than the electrical topology of the circuit). No support, no evidence (hardly surprising in the circumstance), just hand-waving twaddle and a rapid exit when pressed for his claimed evidence. Same modus operandi here. Paraphrasing only slightly, any of these phrases ring a bell?
-'I've... read some books [titles unspecified] & it's too complex to explain'
-'I think'
-'I believe'
-'You need to prove [despite being the one making claims -a favoured inversion of this type of troll on-line, in print or in debate]'
Do yourselves a favour: don't fall for it any further. Let the thread die now.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th July 2018, 10:56 AM   #118
cacao ambiance is offline cacao ambiance  United Kingdom
I had trouble with bad USB cables when re-flashing the bootloader on my android mobile. I had some "samsung" cables but they failed. The only ones that worked reliably where my Anker | #UseAnkerInstead usb cables.
idk the details of reflashing bootloader but i guess its more sensitive/less or no error correction, hence the problem. i had not noticed previous use of the bad cables being a problem with day to day use.
Note that reflashing bootloader was a low level operation. so its different from a normal full OS.
This problem of bad cables caused me a lot of lost time in asking my self, "Oh Why is it not working!" It was only when someone on the IRC help channel encouraged me to try a different usb cable i found that was the problem.
Old 6th July 2018, 11:44 AM   #119
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by andy2 View Post
Seems like lots of people still missing the point of the argument. Some still arguing like a little children. Well, I am moving on to better things.
LOL. That's one of the laziest cop-outs I've ever seen. You started this whole mess, and now you leave. Was your plan just to stir the pot then leave when it got to hot for you? Scottmoose sums it up perfectly above.
Well at least we can hope some people learned a little about how digital interconnects work - and don't work.
Take the Speaker Voltage Test!
Closed Thread
Watts or Whatts..... What makes the difference a.wayne Solid State 52 22nd March 2011 10:49 AM
TDA1541A S2 Upgrade Makes No Difference dantwomey Digital Line Level 10 16th June 2009 05:45 AM
Choke... The side makes difference? blindsjc Tubes / Valves 4 18th June 2008 10:40 PM
Makes the difference or not?! Alexnick Multi-Way 12 27th January 2006 11:21 PM
What a difference a feedback resistor makes!? kropf Chip Amps 17 27th November 2003 01:08 AM
