The Lounge A place to talk about almost anything but politics and religion.
My heat pump
My heat pump
Old 8th February 2018, 04:44 PM   #1
Ripcord is offline Ripcord  United States
Ripcord's Avatar
Default My heat pump
So the heat in my house is a heat pump. Apparently it has a feature that when it drops below a certain temperature a resistive heat coil turns on automatically to supply additional heat. It's basically a big wire coil. Very inefficient. It doubles my electric bill during the coldest months. I'm thinking, wouldn't there be a better way to supply this extra heat. What makes heat while drawing little current? I thought about disconnecting it but haven't really opened up the unit to see how feasible it would be. Any ideas? Could I replace the coil with something else that makes heat while drawing very little current?
Old 8th February 2018, 04:53 PM   #2
VenusFly is offline VenusFly  Australia
VenusFly's Avatar
You could replace the source of heat with another energy source such as gas or kerosene so that the heat pump doesn't have to turn on its coil.
That would be the safest and logical approach to this problem.
Old 8th February 2018, 05:24 PM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I turn mine off and use a pellet stove as auxiliary heat. Iused to use a wood stove at my last house.
Unless you have gas available at a lower cost per btu-hr, and are willing to add gas heat, you are pretty much out of luck.
If there are no dogs in Heaven, I don't want to go there.
Old 8th February 2018, 05:38 PM   #4
HankF is offline HankF  United States
Propane is a very high BTU energy source. Natural gas a bit less, as I recall. If you can't do either, the pellet stove might be your best bet.
Old 8th February 2018, 06:31 PM   #5
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Solar panels, accumulators, charge controller and a inverter.
Old 8th February 2018, 11:48 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
Ground source heat pump.
Natural gas or propane furnace - usually costs <1/3 of electric for heating in the USA.
You could try a hot water coil heated by a gas water heater (w/ circulating pump), etc...
Solar thermal and energy storage could work depending on a number of factors
The best suggestion comes from having all the info. What do you have, how is the heat distributed, what alternate forms of energy do you have available on site? etc...
What state do you live in? etc... What direction does your house face, etc...
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 8th February 2018, 11:57 PM   #7
5th element is offline 5th element  United Kingdom
5th element's Avatar
I figure I should point out that electric heaters are pretty much 100% efficient in that they turn almost all the electrical energy into heat.
Something that draws much less current will obviously provide much less heat and you'll have a cold house.
As to reducing heating costs, as others have said, you need a different energy source.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 9th February 2018, 12:12 AM   #8
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
My heat pump
How much power are you going to get in mid winter? I doubt you'll store enough to provide any form of effective heat boost.
I'm a stove fan so would top up with that. But I'm suprised the heatpump isn't sized for all year. Is it ground or air source?
Old 9th February 2018, 12:21 AM   #9
jackinnj is offline jackinnj  United States
jackinnj's Avatar
My heat pump
coal stove -- more btu's per dollar. or you could use lignite or pete.
Old 9th February 2018, 12:22 AM   #10
billshurv's Avatar
My heat pump
I'm odd. I actually like chopping wood!
My heat pumpHide this!Advertise here!
Does anybody here use bass pump in a car? tonywang365 Vendor's Bazaar 0 19th December 2011 06:38 AM
charge pump jamesrnz Solid State 1 13th August 2008 03:35 PM
charge pump jamesrnz Power Supplies 0 8th July 2008 12:23 AM
Desolder gun or pump? protos Parts 25 26th December 2007 04:18 PM
0 noise, 0 moving parts, water cooling heat pump/radiator! Brian Guralnick Pass Labs 17 29th March 2004 08:24 AM
