The Lounge A place to talk about almost anything but politics and religion.
My heat pump
My heat pump
Old 9th February 2018, 01:40 AM   #11
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I figure I should point out that electric heaters are pretty much 100% efficient in that they turn almost all the electrical energy into heat.
That's true. A heat pump uses electricity to move heat from outside the house to the inside. It will bead the "coat hanger plugged into the wall outlet" as long as there is sufficient heat available outside the house.
A heat pump that pulls heat out of the air obviously has less to work with as it gets colder outside. A larger outside unit will do a better job, but there is a payback involved in replacing the unit. If you are considering replacement, then it is wise to investigate a ground based (geothermal) unit, if your location suits its use. Here it is possible to find 60 degree F areas 50 to 100 feet below the surface. This would make the outside unit more efficient in the winter and summer.
I have also seen some rather unique DIY devices created to add some heat to the outside unit. Most involved a remote outdoor wood burning fire box and heat exchangers made from car radiators, but the days of buying old radiators for $10 are long gone.
Here, propane and other gasses cost about the same if not more than electricity. The you need to recover all the heat energy released by the burning propane. The best DIY contraption I ever saw fed the gas into a small automobile engine mounted outdoors. The exhaust and water jacket heat was recovered and used for home heat. The crankshaft energy spun several automotive alternators creating electricity for light and heat. It has been 30+ years since I saw that, I have no idea it it is an economical alternative today.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 9th February 2018, 02:24 AM   #12
jackinnj is offline jackinnj  United States
jackinnj's Avatar
My heat pump
Someone should figure out how to capture the heat+ IR energy of the 100W incandescent which is both illuminating the text and providing warmth to me when it's 22F outside.
The "mound-builders" in SW Ohio knew a thing or two about conserving energy.
Old 9th February 2018, 02:48 AM   #13
VenusFly is offline VenusFly  Australia
VenusFly's Avatar
That would make a half decent method of heating a small cabin if you were roughing it and all you had was ethanol to burn in a small generator. Of course you would want to be using solar the rest of the year but during winter I'm sure its completely possible to be running an ethanol powered 2400w generator and recovering the exhaust heat to heat a small cabin with instead of burning coal or wood.
Thanks for reminding me that this is a possible method of heating. I did see a video on youtube a few years ago where this guy had a large water tank mounted up on a pedestal (to also provide gravity fed hot water) which was fed with a Lister CS Diesel engine and he recovered the waste heat from the exhaust with a water jacket and pumped it around and into the tank.
I mean if he is able to heat a large tank of water with just the exhaust heat from a Lister CS Diesel, the heat from a small 2400w generator should be more than adequate for also filling up a large tank of water for warm or hot showers and or for heating a small cabin.
On the plus side you could also make your own moonshine. Hell why don't more of us live this way.
A freeman. Love your neighbours and Love nature. Stop cutting down trees to make houses a stones throw from your neighbour and join your real home, the rainforest.
Old 9th February 2018, 02:51 AM   #14
Ron E is offline Ron E  United States
Ron E's Avatar
1 Therm = 100000 BTU = 29.3 kW-hr
Costs perhaps $1 as natural gas, and roughly $3-3.50 as electricity.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 9th February 2018, 05:44 AM   #15
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Originally Posted by billshurv View Post
How much power are you going to get in mid winter? I doubt you'll store enough to provide any form of effective heat boost.
Depends on the weather/location and accumulator capacity.
Plus at one time it will have paid for itself and heat will be "free".
Old 9th February 2018, 12:59 PM   #16
Despite the fact that fracking has displaced coal as the primary energy source for this area, there is no piped natural gas to the houses. People have large tanks and need to get them filled regularly in winter. I don't have gas at my house, all heat is electric, so I don't have any personal comparisons.
The church where I'm a trustee uses electricity for primary heat, and truck delivered propane when needed. That is usually when the power goes off or the heat pump is broken (which it is now). The head trustee has been tracking energy costs for two years to justify a new heat pump, and determine the payback of different size and EER rated units. He tells me that propane is about 1.1 X the cost of electric heat for an AVERAGE winter. We are outside the city limits by a few miles, so the cost is not regulated and there are only two companies that deliver here. This winter has NOT been average. There has been a large number of days in the 20 degree F range where the heat pump sucks, causing the "coat hanger" heat strip to run a lot.
The electric bill for my house last month was $622. January last year, $410. Typical summer bill, $100. Propane delivery here runs about $500 to fill a large tank which may last a month during a winter like this one.
Old 9th February 2018, 01:32 PM   #17
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
My heat pump
Yeah, but in winter here, its dark and cold at 4:30pm. A $$$$ tesla powerwall is 13.5kWh. That's touch and go for providing the extra heat even if you have enough PV to charge it in winter. I'd rather spend the money on better insulation OR
-Stove
-new chainsaw
-new safety gear
-bigger axe
-lots left over for music.
But that's just me
Old 9th February 2018, 01:50 PM   #18
TheGimp is offline TheGimp  United States
TheGimp's Avatar
In my last house, I had no heat in the new addition which was half the floor space. I used a wood furnace, and cut firewood for 20 years. Every winter I would get a permit from the nearby Forrest Service Station for something like $10 for six truckloads of wood. Wood could be cut and hauled from clear cut areas in the National Forrest. There was no one counting truckloads.
If there are no dogs in Heaven, I don't want to go there.
Old 9th February 2018, 02:22 PM   #19
w5jag is offline w5jag  United States
Originally Posted by Ripcord View Post
.... Apparently it has a feature that when it drops below a certain temperature a resistive heat coil turns on automatically to supply additional heat. .... Any ideas? .....
Get a different controller. Our second house uses a heat pump and the thermostat controller has two heat positions - one is for heat pump only, the second engages the electric heat bar. It is an air only unit, meaning when ambient air temps drop much below freezing, there is little heat to exchange. I have found it is considerably less expensive to just let the compressor run and try to exchange whatever heat there is, than to engage the heat strip.
My simple suggestion would be to go down to wal mart, or home depot, or wherever, and get a controller that allows you to control the heat strip activation, and supplement the heat in the rooms where you need it with some of the inexpensive oil filled radiator heaters. They are inexpensive, and work reasonably well.
I have a mix of properties with natural gas and all electric heat. A heat pump is by far the least expensive means of heating. Natural gas feels warmer, but even around here, where there are so many hydrocarbons in the ground that I'm shocked the place doesn't explode when somebody tosses out a cig, gas is relatively expensive.
I have the mineral interests for most of my properties, and properties that I no longer own. It's cheaper than electric, but still a big net loser for me. I wouldn't fool with wood, or pellets, or other survivalist type stuff, personally. There could be insurance issues with stuff like that if it goes south.
Win W5JAG
Old 9th February 2018, 02:48 PM   #20
billshurv's Avatar
My heat pump
Ouch. In my teeny hovel in damp but not cold UK $622 is nearly a YEARLY bill for leccy. Half a tank of oil for the heating and all the wood I can scrump does the rest. We will be so ****** if the gulf stream shuts off
My heat pumpHide this!Advertise here!
Does anybody here use bass pump in a car? tonywang365 Vendor's Bazaar 0 19th December 2011 06:38 AM
charge pump jamesrnz Solid State 1 13th August 2008 03:35 PM
charge pump jamesrnz Power Supplies 0 8th July 2008 12:23 AM
Desolder gun or pump? protos Parts 25 26th December 2007 04:18 PM
0 noise, 0 moving parts, water cooling heat pump/radiator! Brian Guralnick Pass Labs 17 29th March 2004 08:24 AM
