The Lounge A place to talk about almost anything but politics and religion.
What have you built lately?
Old 26th January 2018, 11:38 PM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Testing new power supply. No hum at all audible when all faders are up on +10 dB, headphone amp all the way up. Only noises from microphone preamps. Oscilloscope on 5mV/div shows no ripples at all.
I am satisfied. Time to mount the PS. New holes have to be drilled, it is thicker now, so old holes do not fit. However, one wire had to be soldered outside, I forgot about +42V anode power for UV meters.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 5th February 2018, 11:46 PM   #22
phase is offline phase  United States
Wow, a lot going on in there^. Cool that itís working nicely with any unexpected hiccups.
I have been entertaining myself hotrodding an old bgw 250 amplifier, sounds nice now with better decoupling, and ditching the funky caps in the signal path for better quality parts.
Old 5th February 2018, 11:54 PM   #23
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
Been working on triac controlled soft start unit for an amplifier up to 2000Watts.
Been working on a TDA7294/12au7 amplifier module.
Been working on a USB scope for windows pc.
Been working on USB LC meter for windows pc.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 6th February 2018, 12:42 AM   #24
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
What have you built lately? Send a message via Yahoo to vdi_nenna
Some interesting projects here.
Just working on a couple of things.
Amp cases for MoFo Power Follower.
Was making a prototype for a balanced power unit.
Decided to not pursue the venture.
Just remembered I need a high gain preamp for the MoFo.
Red boards in the background are for a BA-3 frontend.
I build, therefore I am.
Old 6th February 2018, 06:41 AM   #25
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Soldered all pieces together and have (almost) finished a Noise Toaster from MFOS.
Also, got a TPA3116 installed in my favourite plastic boxes.
The amp works great, but the microsynth has to be debugged.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 6th February 2018, 11:00 PM   #26
chrisb is offline chrisb
Wooden sleeve for a vintage Fisher 202T tuner-pre rescued from an old console.
Tight fit - not a lot of overlap on the front panel to achieve any fancy bevel detailing, so just went simple. QC Sapele veneer on BB ply.
and yes, I definitely subscribe to the "tidy workbench is a sure sign of OCD" philosophy - although whenever I do clean up, I find a couple of extra Olfa knives and tape measures.
kinda burnt out - taking a break
Old 11th February 2018, 09:44 AM   #27
Mrcloc is offline Mrcloc  South Africa
Got a bass guitar, so I built a little 45W 4x6". Two are in a small 4th order bandpass, isobaric, and two provide the mids. Sounds quite nice. I used bits and pieces I already had. I only put together a small 10x gain preamp buffer extra.
Old 25th February 2018, 12:32 PM   #28
And now after a few weeks (I should actually say months), I have completed this (the carport).
Old 25th February 2018, 04:27 PM   #29
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
48" Cornucopya's.
planet10 needs your help:
Let's help Ruth and Dave
Old 26th February 2018, 06:37 AM   #30
That's pretty cool, but WAF is about 0.
What have you built lately?Hide this!Advertise here!
Mouse over image to zoom Custom-built-audiophile-quality-speakers Custom-built-audi djn Swap Meet 7 21st August 2016 05:49 PM
WTB: F5 project - built or not built jdubs Swap Meet 2 11th November 2014 12:01 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
has anyone built these? spoggles Multi-Way 2 3rd June 2004 05:50 PM
