The Lounge A place to talk about almost anything but politics and religion.
How Well Can You Hear Audio Quality?
Old 10th November 2017, 02:14 AM   #11
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I gave up after missing the first one on a set of Logitech USB headphones.
If there are no dogs in Heaven, I don't want to go there.
Old 10th November 2017, 02:43 AM   #12
stellarelephant is offline stellarelephant  United States
Sent to this to a buddy. He said:
"The test is rigged. If i listen to a Katy Perry song first, my ears will be irreparably damaged."
I must confess I chose three 320K mp3s and only two WAVs.
The 128K files sound pretty bad and were easy to eliminate in most cases, but I did pick one--the a Suzanne Vega clip. Sheesh.
In my experience, the most complex or "full" arrangements are the easiest to hear a difference, as the sheer quantity of information exceeds the 320K bandwidth. The Coldplay tune was the easiest one for me in this case.
Old 10th November 2017, 01:32 PM   #13
radiosmuck is offline radiosmuck  Canada
radiosmuck's Avatar
So, those that score low would not be able to enjoy music as much as those that score high and quality audio equipment would be wasted on them?
Old 10th November 2017, 02:01 PM   #14
VenusFly is offline VenusFly  Australia
No the test is flawed.
Squee!
Old 10th November 2017, 03:48 PM   #15
HarryY is offline HarryY  United States
HarryY's Avatar
I don't think I would say that.
I view it as a demo to show the differences of encoding schemes.
The DAC or sound card you are running it through may affect your results.
Old 10th November 2017, 03:54 PM   #16
Earl Grey is offline Earl Grey
Well, if the MP3 algorithm was literally designed around that exact track, perhaps you shouldn't feel too bad...
Old 10th November 2017, 04:03 PM   #17
in my own testing 128kbps actually sounds really good. Sonic-wise I would prefer it over 160 and higher bitrates if I didn't care about losing the definition because bitrates between 128 and 320 sound more like a half-assed attempt at reproducing the sound. Whereas 128kbps cuts off that level of detail at exact the right spot to make it not matter so much where the loss of detail begins.
However in my testing I couldn't tell the difference between wav and 320kbps mp3, it was at least exceedingly difficult. 128kbps mp3 is a 'sweet spot' which sounds quite good, to the point that I would prefer 128 over 160. But I would prefer 320 over 128 mainly because it adds more detail. The other bitrates between 128 and 320 are just about useless.
Which is just bizarre.
Now if you want to really blow your mind then have a listen to VBR OGG or 64kbps OGG, it beats 128kbps MP3 and gets real close to 320kbps MP3.
Squee!
Old 10th November 2017, 04:40 PM   #18
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
5 good of 6
Suzanne Vega voice only was hard to detect sample quality differences.
Thanks HarryY for all fun
class A amplifiers with full range speakers
sings like angels in heaven
Old 12th November 2017, 12:39 AM   #19
Johnny2Bad is offline Johnny2Bad  Canada
Fraunhofer spent many years developing the mp3 codec and that included live panels of listeners; each time they were able to tell the difference, they went back to the drawing board and refined the algorithm. Then another year in a contract with the National Hockey League (NHL) who used mp3's for stadium sounds (organ music, timeout music) ... yes, through stadium PA systems ... before they released it.
So, the mp3 codec was specifically designed to fool the ear. Despite that, some untrained people can hear the difference, and the 80% of the population that can appreciate music (10% have physical limitations; another 10% simply don't have the receptors in the brain that normally respond to music) can be trained to hear the difference.
That's without considering test anxiety where someone who truly knows the material still get failing marks (as proven conclusively via studies of college students).
Use your own system, create files of your choosing, and create a playlist with the random order enabled ("shuffle" in Apple speak). Be in a relaxed state of mind. You can go back and see the recents to determine which are which after you take your test.
Not true. Appreciation of sound reproduction isn't about brief snippets of highly compressed highly processed pop music ("highly compressed" as in near-zero dynamic range in the lossless version as well as the lossy version). Some tracks do sound OK on a high bitrate lossy compression scheme but the "shivers down your spine" tracks need realism and that "you are there" illusion to work. Fear not.
For the record I was 2/6 via the speakers in my Macbook Pro and 5/6 via my Ultimate Ears In-Ear-Monitors (IEMs). I took the first test at least six months ago but decided to revisit it, mostly due to this thread, for the second time yesterday, so I definitely couldn't remember which were the "right" choices.
I also have a bit of an issue with the "test" for "audio quality" as it's presented. There is only one track that has any pretence to audio quality.
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..."
How Well Can You Hear Audio Quality?Hide this!Advertise here!
Anyone hear the Cayin Audio CDT-15A??? djn Digital Source 3 1st December 2012 03:44 PM
Mable Audio vs. Suppo audio sound quality imnewbie Tubes / Valves 9 5th August 2010 08:46 AM
O-Audio? Anyone hear from him... Todd, I think?? PHilgeman Multi-Way 1 5th December 2006 03:36 PM
Did u hear about Crescendo amps... ive heard that from Hunter Audio India... diysmartdeep21 Solid State 23 2nd October 2005 02:08 AM
Audio Quality from CD's poulkirk Digital Source 16 16th September 2003 11:37 AM
