The Lounge A place to talk about almost anything but politics and religion.
The car thread
The car thread
Old 9th November 2017, 12:32 PM   #41
VenusFly is offline VenusFly  Australia
VenusFly's Avatar
Those would more than likely be illegal here in AU, even blow off valves are illegal here. Thanks for the suggestion though.
Nah, I'm thinking more upmarket, I can import some adjustable height/stiffness coilover springs from the US for about the same price as a factory strut package.
I bought some fog lamps for the front of the Camry, should make the car look a bit more sporty. Their usefulness would be questionable as we rarely get fog here unless its in the early morning but I do want to put some miles on it so who knows where I'll be, could end up being in the fog-laden hills of Gloucester.
A freeman. Love your neighbours and Love nature. Stop cutting down trees to make houses a stones throw from your neighbour and join your real home, the rainforest.
Old 10th November 2017, 03:55 PM   #42
sippy is offline sippy  United Kingdom
I've taken on the 'challenge' of fixing some issues on a 2005 VW Passat owned by my neighbour who is a single mom.
1: Drivers door wont open from outside - 1hr fix (including a cuppaT n bikkies) - a clip had deserted it's assigned post, was found hiding like a coward in the bottom of the door so....
2: Passenger side window reg (elec) cables farked - no 'fix' as it would be a Long job to get the entire reg mech out, change cables (EXPENSIVE) and set up, so am hunt for a complete door in black which should be 40 ish and no more than 1hr to fit.
3: Find coolant leak and replace hose...... cant do this cos the batteries dead and to take the battery out is a 1/2hr job as it's buried under the inner flitch, not that this matters as the friend I lent my charger to about a week ago thought I wouldn't mind if he lent it to his mate...... and we cant get hold of this guy :@
I can only see 2 hoses, the one that 'might' be holed and the heater matrix return - the others are buried in the front valance - ie take the front of the car apart - or hidden by the under-tray.
I spoke to a friend who's an ex-VAG engineer and guess what he said?
"I stopped working on them because they are so badly laid out."
Furgus also said other stuff about VAG thats too rude to print, mostly about this specific car.
I'll win.
Old 11th November 2017, 01:53 AM   #43
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
The car thread
I think most modern cars are a PITA to work on. I suspect a lot of it is deliberate. In Australia at least there is very little profit made on selling the car, it is the servicing where the money is. Making things difficult (but maybe having a few dealer tricks to get around it) ensures a good revenue stream for after sales servicing.
One of the worst I ever heard was the 90's MG convertibles. Never verified if this was true, but was told that you have to pull the engine to change the spark plugs! I think it was evrery 60,000KM.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th November 2017, 03:47 AM   #44
VenusFly's Avatar
Despite my 3VZ-FE engine having a 90 degree tilt towards the firewall which blocks off easy access to the spark plugs because the engine is so tall, it is not difficult to service it. The intake can be easily removed (provided you haven't stripped the T bolts) and spark plugs replaced with a small wrench.
Dare I say that it is quite easy to repair this car. Of course not all modern cars are like this.
Old 11th November 2017, 02:57 PM   #45
Charles Darwin is offline Charles Darwin  United Kingdom
Tony.
Don't know anything about the '90s MG but mid-engined Ferraris required you to remove the engine to change the timing belt.
Never quite understood why they didn't use chains.
Old 11th November 2017, 05:09 PM   #46
Zeta4 is offline Zeta4  United Kingdom
I think it was a kind of fashion thing. Belts are a little more efficient and dont stretch
over time (but of course break without much warning) compared to the roller chains
at the time. They are also cheaper but I dont think this was Ferrari's reason for using them!
Since then chain manufacture has improved considerably. My BMW E46 M3's timing chain is
known for lasting well over 200K miles. Mind you the N47 timing chain didnt last but that was
due to badly machined crankshaft sprockets
I seem to remember the first Honda F1 V10 used belts but was soon redesigned to use gears.
Old 11th November 2017, 05:43 PM   #47
The 90's MG TF (mid engine) had a microscopic aperture accessed through the boot, trying to do anything through that would tax ones patience.... about the only thing you could doo was check the oil level and top it up using a very small pouring jug or funnel.
The correct way to service the engine was to remove the soft-top then the cover that served as the 'parcel shelf'.
TF's were truly horrid, they came with so many faults (seizing brakes / incorrect bias, cooling / engine probs, suspension alignment probs) that almost all of them ended up being re-built and were not too bad in a 'taken with a pinch of salt' kinda way.
There was an MG 'B' copy, am not sure which engine it used. I know that Rover used a Ford all iron v8 in one of their saloons so if it was that unit, it would have been Tightas the engin bay was rather full with the ex-Buick all alloy unit.
Fezzers and such are what they are and you do what's needed to maintain them. I've worked on a Dino 246, 308gtb and gt4 'Dino' under restoration conditions..... I think people see them as being difficult because they don't understand their anatomy even though they say / think they do and lets face it, if you can afford to own one you're probably going to be able to afford a cam-belt change.
What gets me about this Passat is that it's just a 'car' and there's no need for it to be the way it is.....
I hauled the battery out today, it took me 15 mins to get to it and get it out.
I woke this morning with the realisation that I could use my solar panel as a charger*, a dumped trailer provided a set of running lights as a resistor string**. It was taking charge and managed to get it up from 2.73v to 6.90v.
So tomorrow I hope to see it at 10v ish and it can go on charge tomorrow night - Furgus is loaning me the special pliers to remove the pipes, a pump to charge said cooling system and bringing me a charger.
*I'm putting together a small solar system together to run LED lighting and my high efficiency hifi system in my man-cave flat.
** A DeLight charger!
Old 11th November 2017, 06:44 PM   #48
My old '84 Merc W123 had a timing chain and frankly I've never even heard of chain failure. That despite two of my family members supporting themselves through Uni (and beyond) by driving taxis which were all W123s at the time and 500k of city traffic normal.
I was wondering how BMW managed to screw up the N47 because the M47 was very, very reliable and now I know. Thanks!
Old 12th November 2017, 05:20 AM   #49
VenusFly's Avatar
Sounds to me like you could do with a battery relocation kit? Anyway..
I've actually done this on my toyota camry vienta. this is the charger that I used with a 10 watt solar panel put onto my dash.
I chose PWM because I didn't want inherent noise that MPPT controllers produce on my power network.
You didn't hear it from me but its to power a GPS tracking system. (shh) More to protect the thousands of dollars of audio equipment than the car.
5A 12V Solar Controller Waterproof Load On In the Night Battery Charge Regulator | eBay
Old 18th November 2017, 08:11 PM   #50
VenusFly's Avatar
God I love having a toyota:
Twin Dual Double 2 USB Port Lighter Charger Adapter 12V In Car Socket for Toyota | eBay
The car threadHide this!Advertise here!
How to change thread title or delete thread in Swap Meet tubesguy Forum Problems 3 11th March 2017 02:32 PM
Should a person who starts a thread have quasi moderator status on their own thread? erin The Lounge 15 23rd October 2012 10:41 PM
Editing thread first post title doesn't change actual thread title muckrake Forum Problems 2 15th August 2012 10:13 PM
Looking for a thread... tubesdude Tubes / Valves 0 5th October 2005 04:25 AM
