The Lounge A place to talk about almost anything but politics and religion.
What did you last repair??
Old 5th November 2017, 07:51 AM   #31
Dude111 is offline Dude111
The other day I got a VHS tape in the mail I ordered (AND JUSTICE FOR ALL - 1979)
I Think the person rewound it with one of those crappy radioshack things WHICH ARE HORRIBLE.. (They slam the tape @ full speed when it gets to the start) - YA DONT EVER USE THAT GARBAGE!!!
The tape was off the take up spool so I opened the cartridge and re-attached the clear lead tape to the spool using a couple pieces of tape..... I had to put it in a different shell as the parts in the back (1 of them) came off and it wouldnt play at all........
I took an empty one and put both spools into it.... Its not working correctly for some reason (the things in back of the spools) but thankfully its working...
This is the first 1981 columbia release of this movie and its the BEST and i didnt wanna lose it,been looking for it for along time!!!
Old 6th November 2017, 03:09 AM   #32
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
One of my IGBT amp modules didn't work.
I was quite surprised because I double check every resistor and capacitor value before fitting. My drawers have transistor and diode values written on them so I double check them too.
I visually inspected pcb for shorts and none soldered joints but it was fine. Buzzed out all resistors and all correct values.
Got the magnifying glass out read the transistor numbers and noticed one was BC182L instead of MPSA42. I was shocked as I never use that transistor in my designs.
It must have sneaked into the batch at my component supplier.
Replaced it and the amp burst into life.
The BC182L is npn as well but a different pin out.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 6th November 2017, 03:19 AM   #33
anatech is offline anatech  Canada
anatech's Avatar
That is hard to find. I'm glad you did!
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 6th November 2017, 01:13 PM   #34
AstroZon is offline AstroZon  United States
AstroZon's Avatar
On Saturday, I fixed a portable freezer at work. Then the same day a coworker and I fixed our pressure washer.
Repairing stuff isn't our job, but as we're surrounded by people lacking any concept of how machines work, we're sort of forced to keep it all working.
Old 9th November 2017, 09:48 AM   #35
It sure makes ya feel GOOD when ya get it working huh?
Old 12th November 2017, 11:09 PM   #36
AcoustatAnswerMan is offline AcoustatAnswerMan  United States
AcoustatAnswerMan's Avatar
It took me only 4-1/2 years to rebuild this updraft Zenith carburetor for a 2008 cu-in gas V8 engine in a 35-ton Plymouth ML8 locomotive. Note US quarter provided for scale. This was my first carburetor rebuild and hopefully my last. We’ll see if it actually works after spending $200 on the rebuild kit and so many hours cleaning decades of dirt inside and out. The guy where I bought the kit said if he had one of these for sale in rebuilt condition, he’d be asking $5000 for it.
File Type: jpg Rebuilt Zenith 1510MV Carburetor_0020.jpg (330.9 KB, 92 views)
Last edited by AcoustatAnswerMan; 12th November 2017 at 11:10 PM. Reason: fix spacing
Old 12th November 2017, 11:18 PM   #37
Congrats,it takes time IF YA WANT IT RIGHT!!!
Old 12th November 2017, 11:48 PM   #38
DavinCarter is offline DavinCarter
Just rebuilt an engine for a 2000 Honda CRV.
It needed the head planed and had enough miles to want a full rebuild.
Engine is done and now I just have to fix one front CV joint.
Old 12th November 2017, 11:49 PM   #39
Originally Posted by AcoustatAnswerMan View Post
It took me only 4-1/2 years to rebuild this updraft Zenith carburetor for a 2008 cu-in gas V8 engine in a 35-ton Plymouth ML8 locomotive. Note US quarter provided for scale. This was my first carburetor rebuild and hopefully my last. Well see if it actually works after spending $200 on the rebuild kit and so many hours cleaning decades of dirt inside and out. The guy where I bought the kit said if he had one of these for sale in rebuilt condition, hed be asking $5000 for it.
You have a locomotive for casual use?
Just wondering.
Pictures?
Old 13th November 2017, 03:05 AM   #40
PRR is offline PRR  United States
PRR's Avatar
It took me only 4-1/2 years to rebuild this updraft Zenith carburetor for a 2008 cu-in ....spending $200 on the rebuild kit ... in rebuilt condition, hed be asking $5000 for it.
I suspect this is #4463 at the Arizona Railway Museum.
When I discovered I could buy a whole new carb for my 3.75HP B&S, I didn't bother with a rebuild. (I done float-carbs, but do not understand this reed carb.)
Stromberg or Zenith? Ah, in 1943 it was whichever they could get.
My first thought was that you could plop a Holley 2300 2bbl carb on that engine and it would run better than new. Down-flow converts to up-flow with a bent pipe, like a sink drain trap only bigger. There's a turbo-four shop in your town which does such big bends every day. 21st-century TIG-welded! The boat-shop has hand throttles.
Ah, but the Le Roy is governed. Flyballs pull-back the throttle at 1,000RPM. The revised throttle position may not suit the linkage. The project has overcome too many problems to risk an over-rev. Ignition limiters are rude and may not be adaptable to Bosch magnetos.
What did you last repair??Hide this!Advertise here!
NP-5ex repair Swampwalker Feastrex 1 21st October 2017 02:47 PM
a/d/s/ repair? troystg Car Audio 0 28th August 2016 05:49 PM
Repair help? gsindell The Lounge 0 3rd February 2012 10:36 PM
Is a repair possible? seebert Multi-Way 9 6th October 2011 05:27 PM
Repair or Get something else.... sboyer Analogue Source 24 29th June 2011 05:04 PM
