The Lounge A place to talk about almost anything but politics and religion.
Capacitors can you hear the difference
Old 9th November 2014, 08:49 PM   #1
millychew is offline millychew
Default Capacitors can you hear the difference
Hi folks , has anyone replaced an inexpensive capacitor with an expensive one in a speaker crossover, I have built a troels gravessen design 3 way speaker and the capacitors that I am thinking about replacing are for the midrange speaker a SEAS ER18RNX, they require between 80 and 100 uf
I have fitted 4 clarity cap esa 22uf, im thinking about replacing these with
1. mundorf supreme
2. jantsen superior z cap
3. audyn cap plus
Would I see an improvement in sound quality or should I save my money.
Old 9th November 2014, 09:10 PM   #2
voltwide is online now voltwide  Ireland
Certainly you will never see any improvement as long as the crossover is hidden inside the cab.
Old 9th November 2014, 09:15 PM   #3
Default Re Capacitors can you hear the difference
Oh sorry the crossovers are in a separate box placed at the rear .
Old 9th November 2014, 09:17 PM   #4
rayma is offline rayma  United States
He was implying that the capacitors won't sound different, just look different.
Old 9th November 2014, 09:25 PM   #5
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
Really?....there are countless threads regarding capacitor differences...real or imagined....
Example of capacitor sound comparison.
http://www.diyaudio.com/forums/multi...rossovers.html
Just two I found within 5 secs of searching.......
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 9th November 2014, 10:43 PM   #6
Guess the general feeling is capacitors don't make a difference.
Old 9th November 2014, 10:54 PM   #7
pkitt is offline pkitt  United States
And, almost without fail, the more expensive the capacitors are the better they'll sound according to the "golden ears".
Paul
Old 9th November 2014, 10:57 PM   #8
On Hiatus
SY's Avatar
I wouldn't say that. The correlation between "better" and "more expensive" is pretty weak, though. And "better" is very dependent on exactly how the cap works in a given crossover.
ESR, ESL, and microphonics are the most important parameters to consider, and again, depending on the filter design, "lower" may not necessarily be "better" for the first two.
Be highly skeptical of marketing claims for expensive caps!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th November 2014, 11:15 PM   #9
Sure they do, try it for yourself and see.
Old 9th November 2014, 11:21 PM   #10
zacster is offline zacster  United States
I've heard a difference between caps. I replaced some Solens with Auricaps and could definitely hear a difference. I also replaced the orange drops with Russian PIO caps and could also hear the difference, this in a pre-amp and amp respectively. Neither set of replacement caps cost much so it wasn't the money that made them sound better. I've heard that wound up Franklins in oil sound really good though .
Capacitors can you hear the differenceHide this!Advertise here!
Mundorf capacitors difference Audist Parts 106 6th August 2016 11:57 AM
Difference in Capacitors used in Speaker Crossovers jj Multi-Way 52 4th July 2014 08:17 PM
Now hear this : east electronics Multi-Way 23 23rd August 2013 07:32 AM
V-Link, Fireface, Dip Upsampler I don't hear a difference Sjef Digital Source 4 3rd November 2011 07:15 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Copyright ©1999-2017 diyAudio
