The Lounge A place to talk about almost anything but politics and religion.
Square wave test on speakers - what does it tell ?
Old 15th May 2014, 01:25 PM   #71
Charles Darwin is online now Charles Darwin  United Kingdom
Originally Posted by AndrewT View Post
20Hz to 20480Hz is 10 octaves.
Three 3octaves capable drivers can't cover 10 octaves.
30Hz to 15360Hz is 9 octaves.
Four drivers each with AT LEAST 2.5octave capability can just reach 10octaves, if the overlap at each crossover is absolutely minimal.
It would seem that north of the border 'slightly more' means 'precisely the same'.
I have to bear that in mind next time I travel to Scotland. ;-)
Old 15th May 2014, 01:30 PM   #72
a.wayne is offline a.wayne  United States
Sin Bin
Forget that , Vote for Nigel before they get him ....
Old 15th May 2014, 01:55 PM   #73
kasey197 is offline kasey197
The Dastardly Dad of Three
Unless I am mistaken the only speakers capable of really reproducing square waves are quad electrostatics. One can of course argue that this ability is irrelevant to sound reproduction but it's hard to see why that might be the case given that a good sq w is not possible without excellent phase and frequency fidelity. Both desirable attributes in sound reproduction.
Old 15th May 2014, 02:56 PM   #74
ginetto61 is offline ginetto61  Norway
Hi and thanks. Very interesting.
I remember now an advert on HiFi News & Record Review, if i am not wrong, about a company building a passive multiway crossover able to pass a very decent SW.
I think that they presented this as a remarkable achievement
I do not remember the Company name by the way
Regards, gino
P.S. as i am also interested in coupling caps i wonder if a SW could be a good test signal to select the best caps for signal coupling
Old 15th May 2014, 04:34 PM   #75
bwaslo is offline bwaslo  United States
bwaslo's Avatar
Originally Posted by kasey197 View Post
Unless I am mistaken the only speakers capable of really reproducing square waves are quad electrostatics...
Not so, some of the Danley Synergy horns (and some DIY versions, my own included) can do it as well. And something like the Manger, if used fullrange, can also.
One thing to keep in mind for most speaker measurements (including square wave reproduction capability) is that a speaker doesn't have just one output like an amplifier channel does. A speaker has many outputs that are almost always different toward every direction. Making a multi-driver, non-coaxial speaker reproduce a square wave only when measured from one direction (i.e. on some defined "listening axis") is difficult, but even when achieved probably still doesn't mean a heck of a lot. In a real room, you are going to hear all the sound outputs no matter what direction they are leaving the speaker at, as it will reflect around and get to you by some time (just turn a box speaker away from you and notice that the sound level really doesn't drop all that much, though the character of that sound probably will!).
Getting a speaker to reproduce a square wave (perhaps attenuated) over a wide range of output directions might mean something. But still I don't know of any documented evidence showing that that is necessary either.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 8th June 2014, 11:18 AM   #76
Originally Posted by bwaslo View Post
... Getting a speaker to reproduce a square wave (perhaps attenuated) over a wide range of output directions might mean something. But still I don't know of any documented evidence showing that that is necessary either
Hi and thanks for the very interesting explanation
The main reason for the question is what i read about drivers selection.
If i understand well most of this process is done by ear, by listening to signal/music. If i am wrong i am here to know.
And sorry but i find this quite unscientific. Again tell me if i am wrong.
I would expect that after all these years some kind of instrumental procedure were available, with well defined test signals.
I do believe in difference between one driver and another, starting from the cone material for instance. I prefer paper cones almost always.
Thanks and regards, gino
P.S. and drivers selection is the first step of a project. The first step.
I should study more drivers.
Old 26th June 2014, 05:23 AM   #77
Hi, just to say that i have found a champion ... at least at 1 kHz
1kHz squarewave response on listening axis at 1m
From Stereophile magazine.
I wonder if this behaviour is mantained also around that frequency.
Impressive.
I listened to these speakers and they amazed me for the realism of sounds, especially when reproducing special effects in movies.
I had an even scaring experience, never heard before.
We were watching a movie .. at a certain point a guy behind a glass wall knocked on it
I swear, i felt like he was inside the television knocking on the screen.
Unfortunately i do not remember the title of the movie but the effect was so real that both me and my friend, the owner of the speakers, were astonished.
Unbelievable. Was not a reproduced sound ... was the real sound.
Old 26th June 2014, 06:53 AM   #78
Kastor L is offline Kastor L  Europe
Kastor L's Avatar
Send a message via ICQ to Kastor L
Hi Gino, which speaker is it you call the champion? :-)
Old 26th June 2014, 09:18 AM   #79
On Hiatus
SY's Avatar
And what does that square wave look like with the mike moved a few cm?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th June 2014, 11:04 AM   #80
Hi well champion maybe only on this specific issue.
It is the Quad esl 63
And there is only the test with a 1kHz SW.
Still it looks very good to me for a speaker.
As i said i listened extensively to these speakers because a friend owns a pair.
No real bass, limited max ouptut.
Someone call them the big headphones ...
I do not like at all their width ... in general i do not like panels
But the realism of some effects was completely unbelievable.
Like the crash of a glass ... never heard something more real really.
I do not know if this can be related to their behaviour in the SW response test
Square wave test on speakers - what does it tell ?Hide this!Advertise here!
LTspice square wave and audio amp test maouna Solid State 2 11th December 2010 09:34 AM
How to run a square wave test on an OPT?? Ultima Thule Tubes / Valves 7 28th December 2009 10:47 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Copyright ©1999-2017 diyAudio
