The Lounge A place to talk about almost anything but politics and religion.
Funniest snake oil theories
Old 15th January 2018, 01:07 PM   #13111
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
There are significant differences, the initial 1.5 seconds room sound is one difference.
Dan.
Old 15th January 2018, 01:11 PM   #13112
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by Max Headroom View Post
Attachment 656992
Attachment 656993
Dan.
Easily visible by eye, there possibly is a difference in spectral balance that is perceived as louder. There looks like some clipping too, not a good sign for critical listening.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 15th January 2018, 01:12 PM   #13113
gabdx is offline gabdx  Canada
Maybe people moved in the room or they placed a sound damper behind the microphone.
amplificateurslegrand.ca
Old 15th January 2018, 01:13 PM   #13114
Originally Posted by DF96 View Post
If you have to ask the question then you cannot understand the answer.
Try to be a teacher, we are all ears.
Good cables are inexpensive to buy but very difficult to make (unless by "make" you just mean putting bought connectors on the ends of bought cable). Almost all DIY cables are seriously inferior to sensible bought cables. Bad cables can be very expensive to buy.
So what defines a 'good' cable versus a 'bad' cable, physical durability etc considerations excepted for the purpose of this discussion.
Dan.
Old 15th January 2018, 01:18 PM   #13115
Markw4 is offline Markw4  United States
Dan, both look clipped which would cause some distortion. Also, since the room sound went up in one case, it may be that whoever was doing the sound recording turned up the gain when the "good" cable was switched in. Maybe that was done so the folks watching online could hear a "difference" given the low fidelity of most streaming audio.
Old 15th January 2018, 01:20 PM   #13116
The clipping is likely the audio AGC pushing too close to the wire.
Agreed, constant gain would be better but the differences are audible as is.
Dan.
Old 15th January 2018, 01:25 PM   #13117
DF96 is offline DF96  England
Find a good undergraduate textbook on quantum mechanics. Read it. I cannot recommend one as my books are from 40 years ago. If necessary, learn the prerequisite mathematics first: linear vector spaces, concept of orthogonality, complex numbers, second-order differential equations etc. Also, it helps if you have a good grasp of classical mechanics, especially in the Lagrangian and/or Hamiltonian form.
Adequately low series resistance, and can carry required current without overheating. Adequately high shunt resistance, and can carry required voltage safely. Moderate (not too high, not too low) inductance and capacitance. If unbalanced, then well shielded accurate coaxial construction. If balanced, then adequately tight twist of pair.
Old 15th January 2018, 01:36 PM   #13118
Dan.
Old 15th January 2018, 01:38 PM   #13119
KK , not want to name the manufacturer, makes possibly the best speaker cables. Can be bought by the spool too. Not too hard to make a replica.
Possibly the type of copper makes a difference: slow/fast drawn, cold drawn, hot drawn etc. at the molecular level.
Old 15th January 2018, 01:43 PM   #13120
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Thanks Dan, That's really interesting.
Funniest snake oil theoriesHide this!Advertise here!
More snake oil astouffer The Lounge 26 6th November 2016 05:21 PM
Snake oil or not? Carlp The Lounge 21 28th February 2011 09:03 PM
Looks like snake-oil but really works. Circlotron Everything Else 18 28th November 2002 10:40 AM
