The Lounge A place to talk about almost anything but politics and religion.
Copy Transfer
Copy Transfer
Old 31st January 2013, 05:33 PM   #1
M Gregg is offline M Gregg  England
Default Copy Transfer
Just thought,
I would mention this I have no connection..I had a computer crash a while a go Hard drive fail..I had lost all my Ipod tunes on the PC...if tried to connect it to the new PC I think it would have wiped My Ipod ..so I used copy transfer to copy all my songs from the Ipod back to the PC..it worked so well I paid and bought the full version..
Transfer iPod to iTunes, copy iPod to PC and iPad to computer
It saved the day for me because my songs were not on the cloud at that time..There are other programs that do the same....its just for interest.
M. Gregg
Old 31st January 2013, 05:43 PM   #2
kevinkr's Avatar
Copy Transfer
iTunes will do this automatically with your iPod, I have had to do this several times over the years when the hard drive in one of my PCs failed. I think there are some minor configuration settings you should check first.. Apple Forums or Help in iTunes should provide the required information.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 31st January 2013, 06:38 PM   #3
Hi Kevin,
I tried on several occasions to do this with no luck the itunes folder would not show on the computer (Hidden or other)..I was told if ITunes did a sync on the ipod it would wipe it..so It would be nice to know how you did it.
Copy Trans also let me create a separate (normal) folder on another hard drive to back it all up. This just shows the songs as standard files MP3 etc
M. Gregg
Old 2nd February 2013, 12:18 AM   #4
kevinkr's Avatar
Copy Transfer
Of course I just upgraded iTunes so I can't find everything and my iPod is upstairs while I'm down here in the man cave listening to vinyl..
However you can prevent your iPod automatically syncing to an empty installation of iTunes by checking the box shown in the attachment below..
You can import purchased files from your iPod to iTunes, that however is not the case with music you ripped with iTunes..
Also make sure you never select the "Reset your iPod" in the software updates section of iTunes as this will delete anything on your device. Regular updates are OK.
I've reached the point where I no longer find much satisfactory sonically speaking with the iPod so I hardly ever use it. When it wears out I am probably going to get a hifiman or whatever has replaced it at that point in time - at least that can play flac files and makes some pretense at high fidelity..
When I next connect my iPod I will look and see if the library options are the same as I remember and will post here.
I have a 4 year old Classic 160GB..
Old 2nd February 2013, 12:25 AM   #5
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
This reminds me I have a wonderful iRiver iHP-140 somewhere around here that just needs a new battery.
Old 2nd February 2013, 12:34 AM   #6
Thank's Kevin,
Yes I tend to use the Ipod when I'm playing back ground music...Its just easy to use...
Yes please post what you find with the settings...I prefer flac perhaps off CD...however the CD looks like its got limited time..I find the software in linux better for some reason...I can't get to creating a PC based silent system....I guess I have an allergy to bits of music.
M. Gregg
Old 2nd February 2013, 12:34 AM   #7
kevinkr's Avatar
Copy Transfer
Reputedly the iRiver is quite good sounding.. I rebatteried a first generation iPod which I gave to my wife 4yrs ago when I got the current one.
Strangely enough the first 2013 release of iTunes (if not earlier, I ignored many previous prompts to upgrade) has apparently done away with Cover Flow which I thought was a gimmick, but nonetheless cool..
Old 2nd February 2013, 12:39 AM   #8
kevinkr's Avatar
Copy Transfer
Originally Posted by M Gregg View Post
Thank's Kevin,
M. Gregg
I've ripped a good many of my CDs to flac to the point that I no longer even have a CD player hooked up. My Sony SACD player - a modified SCD-777ES is rarely used to play SACDs and even less frequently to play CDs. I also have a Shigaclone which I no longer use either.
I'm about 90% Analog and 10% digital and the media server with a home brew dac (tube/transformer based I/V) is really quite good sounding and very convenient - if not really a match for the TD-124/Schick/SPU/Muscovite.
Old 2nd February 2013, 12:44 AM   #9
Originally Posted by kevinkr View Post
Reputedly the iRiver is quite good sounding...
Indeed it is... on top of having an optical SPDIF output. With RockBox loaded it will pretty much play any file type as well.
They sure don't make them like they used to.
Old 2nd February 2013, 12:45 AM   #10
I like coverflow..
At least you can kidd yourself it looks like an album..I do miss the artwork...
Tech is moving so fast these days..its time to buy "dont open" and just put it in the bin and go back for the next "In Vogue gadget"..
M. Gregg
Copy TransferHide this!Advertise here!
Transfer Funtion of the given circuit ? sameerdhiman Everything Else 13 11th October 2011 01:23 PM
Getting transfer characteristics lcsaszar Tubes / Valves 1 13th August 2008 12:14 AM
transfer function jenks Solid State 31 24th April 2008 09:28 PM
Transfer Function jclouse Multi-Way 22 1st July 2006 02:19 PM
Transfer functions? oracel Multi-Way 15 23rd October 2004 02:34 PM
Copyright ©1999-2017 diyAudio
