The Lounge A place to talk about almost anything but politics and religion.
Making LPs with a 3D Printer
Old 22nd December 2012, 10:27 PM   #11
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Can we make multi-layer PC boards with it?
Kevin
Old 22nd December 2012, 10:31 PM   #12
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I have used 3D printers recently to produce replica parts for making flight simulators but have never used anything 3d printed to such a high resolution.
One possible DIYAudio application I have considered is 3D printing wave guides for line array HF drivers.
Old 24th December 2012, 12:22 PM   #13
tvrgeek is offline tvrgeek  United States
If you come up with a way to print copper.
Old 24th December 2012, 12:42 PM   #14
Just thinking here. There are several dozen totally different technologies for 3D printing. Mostly either making solid from a liquid or some sort of thermal deposit. What if one of these were combined with a machining tool? Mechanical, electron, laser. Then the ability to add shapes generated from other technologies, such as a metallic shapes. I was also thinking about printing a metallic power with a binder that could then be fired to produce sintered parts.
Old 24th December 2012, 12:55 PM   #15
jcx is online now jcx  United States
I've lost the link but recall a tube amp built on CNC grooved teflon slab with heavy (cast?) Silver conductors pressed in
Old 13th January 2013, 02:24 AM   #16
I ran across the original clip that started this thread. Yes, they did try to print an LP. It said it needed to be more than 30 times finer resolution to work at all. In other words, they made a disk with a rough surface.
Making LPs with a 3D PrinterHide this!Advertise here!
3D Pic... you need Anaglyph 3D Glasses to view moe29 The Lounge 13 18th June 2013 12:56 PM
Mistracking LPs evetsfrance Analogue Source 19 30th July 2011 01:55 AM
distortion with LPs Zero One Analog Line Level 19 23rd August 2006 07:09 PM
Must-have LPs? Wally Music 24 10th April 2006 09:49 PM
PCB making with printer Dwiel Parts 9 26th September 2004 10:49 PM
