The Lounge A place to talk about almost anything but politics and religion.
fast fun projects?
fast fun projects?
Old 9th October 2012, 11:19 PM   #1
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
fast fun projects?
Default fast fun projects?
What projects did you make for fun that can be repeated quickly by other members?
I made a night stand. All took no more that 15 minutes.
Ingredients:
1.) Glass vase
2. )Glass balls
3. )Optic fibers
4. )4 resistors 22 Ohm each
5. )4 LEDs
6. )Old 5V cellphone charger.
Here is the picture attached:
The Devil is not so terrible as his math model is!
Old 9th October 2012, 11:26 PM   #2
Cassiel is offline Cassiel  Libya
A son project.
Old 11th October 2012, 12:54 AM   #3
popilin is offline popilin  Argentina
popilin's Avatar
The only thing pretty fast I can think of is to reproduce the Young's Experiment.
Ingredients
1) A screen (can be used a wall)
2) A LASER pointer (a cheap one)
3) A thin wire (Hey, you must have lots of wire)
Put the wire near the LASER (1 cm would be fine) and on the wall, you will see a beautiful pattern of alternating light and dark bands.
It is one of the most beautiful experiments, and if necessary, you can measure the diameter of the wire with a tape measure, with amazing accuracy, better than with a micrometer.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 11th October 2012, 05:59 AM   #4
Wavebourn's Avatar
fast fun projects?
Thank you Popilin!
But how do you know exact wavelength of the cheap lazer?
Old 11th October 2012, 06:34 AM   #5
kctess5 is offline kctess5  United States
When I'm bored I just pull out the random assorted speaker drawer and through together an OB or something with my extra active crossover, listen to it for a day, decide I still like my system and take it apart
Good fun
But also I like putting LED strip in interesting places, I lined my door frame with some cool white strip and it looks super cool. Took about 10 minutes and was quite cheap
Old 11th October 2012, 02:07 PM   #6
popilin's Avatar
Originally Posted by Wavebourn View Post
Thank you Popilin!
Good point !
I guess standard cheap red LASERs has a typical wavelenght.
Laser pointer - Wikipedia, the free encyclopedia
An other way would be measured with a monochromator.
It also takes less than fifteen minutes.
Old 11th October 2012, 02:18 PM   #7
adason is offline adason  United States
adason's Avatar
here is one fast and fun...
I took apart old scanner, took out the long fluorescent light tube, hook it up to a small chip amp from computer speakers, feed the little amp with music signal and voila...you get yourself fluorescent signal meter
granted, it has small range, but the light really starts from one end and moves like a bar to the other, fun to watch!
Old 11th October 2012, 03:49 PM   #8
Wavebourn's Avatar
fast fun projects?
Did you connect the bulb directly to the amp output, or used it's voltage converter powered from output of the amp?
Old 11th October 2012, 09:01 PM   #9
tvrgeek is offline tvrgeek  United States
Ingredients
Got to try that. I have a laser level that shroud do just fine.
Old 12th October 2012, 12:24 AM   #10
adason's Avatar
i kept the step up transformer between the amp and fluorescent tube, that way I did not have to put volume too high up
there are however such scanners, which have very long tubes without the trafo, just a board with electronics, in that case I connected amp directly
fast fun projects?Hide this!Advertise here!
Fast, fun, Inexpensive OB project Pano Multi-Way 1598 18th October 2017 02:07 PM
hacking the Sony control-A1/A1-2 bus for fun projects knutinh Everything Else 0 27th June 2005 08:03 AM
ne1 have fun projects for CPU PS? JZatopa Solid State 7 20th June 2005 01:46 PM
Copyright ©1999-2017 diyAudio
