The Lounge A place to talk about almost anything but politics and religion.
The Music
The Music
Old 6th September 2012, 12:16 PM   #1
FraserSoft is offline FraserSoft  United Kingdom
Default The Music
I have been a member now for a couple of months and done a lot of reading around many of the forums.I have come to realise that most of the time discussions center around the components and theoretical calculations and very little about how the music sounds.
I recently modified three Musical Fidelity Dr Thomas amplifiers so that they are now effectively all mono blocks (seperate power supplies for each channel) and find the result very acceptable. I have spent the last few weeks listening to the music rather than worrying if my inter connects are the right way around or if the speakers (home made) are in the exact place for the volume of my room.
I realise that diyaudio is by Fanatics for Fanatics but is there an area for people who just enjoy the music and aren't obsessed by the technicalities of the hobby or have I joined the wrong group ?
Alec
Old 6th September 2012, 09:30 PM   #2
tvrgeek is offline tvrgeek  United States
For many of us, yes music is the driving force. But we are DIY which means we want to fiddle inside. This means we have to learn what we are doing, or at least enough to accept the help from those who really do. Most of us believe if we do hear a difference, there is a good technical reason and we want to reproduce it. That is how the state of the art is raised.
Hang around, we'll corrupt you yet. So, modified MF's and DIY speakers. Do tell.....
Old 6th September 2012, 10:38 PM   #3
Default The Music
The 3 Dr T's amplifier boards now have their own 500VA toroidal transformers and 2 times 22,000uF caps and a 25amp bridge. The home made speakers took nearly 18 months to get right and have a KEF B110 mid range unit and a High power B200 bass unit and the HF is taken up with a Scanspeak D2010.
The cabinets are made from 25mm MDF and the dimensions of which were designed on a computer system at Newcastle University to fit in with the parameters of the drive units. The mid range driver is in it's own cabinet also made from 25mm MDF with sculptured internals and shaped front panel.
I have numerous B&K response plots done in the anechoic chamber at Northumbria University which I can scan in and post if anyone is interested. The crossover was also designed at Newcastle Uni again taking into account the drive unit parameters and the cabinet internal dimensions, and the coils for the bass unit part of the crossover were custom made and because of their very low resistance present a virtual short to the voice coil. This gives the bass an amazing amount of control and tightness that stops when it's supposed to.
I could go on but I reckon that's enough for now, the rest of my system in part 2....
Old 6th September 2012, 10:55 PM   #4
Simon B is offline Simon B  United Kingdom
http://www.diyaudio.com/forums/music/
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 6th September 2012, 10:57 PM   #5
M Gregg is offline M Gregg  England
Just my thoughts,
I think you have made the number one mistake..Its been raging for ages sound quality and measurements..
Ie does every one like the same sound<<<I guess not because people buy different equipment..And some build different equipment..
Thats the number one interest...The rest is all just preference..and its not just the idea of what sounds the best but who likes the sound..
M. Gregg
Old 6th September 2012, 10:57 PM   #6
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Member Soundsteve has 4 channels 5 ways all horns
Old 6th September 2012, 11:01 PM   #7
Default Wrong forum
I take it I should be somewhere else ?
Originally Posted by Simon B View Post
Old 6th September 2012, 11:05 PM   #8
You are not in the wrong forum..
The fact that you are asking questions is the reason you are here..
There are some real fanatics here both for music and equipment...
Some just want to build every type they can because they can..and I know the help that is here is second to none..
M. Gregg
Old 7th September 2012, 07:54 AM   #9
Default Music
Thanks for the explanation I'll get the hang of all this Forum stuff soon. I was starting to think there were a lot more fanatics than people like me. I suppose being a service engineer nearly all my life made me a bit cynical when it comes to what I got used to calling hype.
There must be a point I suppose where the money runs out or you can't hear the difference. The cost of some the components on sale is completely crazy and I wonder if the manufacturer knows about all these fanatics and charges what they think they can get away with. I can't see how anyone can justify paying nearly 100 for a 330uF 250vw Mundorf capacitor !!!!!
Old 7th September 2012, 08:13 AM   #10
The parts you refer to,
Usually referred to as snake oil<<ie how much difference do they make..
I guess thats the point of DIY you can make your own cables etc and see what happens without spending over the top..
It comes down to if you can hear a difference or is that measurable..Trouble is it can cost a arm and a leg to try such things...so most don't.
I think up to a point there is a difference <<thats just my thoughts
However it seems to have different impact on different types of Kit..valve/tube or SS..I guess the main thing is to get the most "bang for the buck"..things like obbligato coupling caps are quite cheap and I think sound quite good..others will always use standard parts..however they will choose selective standard parts..
Engineering things like Hex diodes etc to reduce noise..You can bypass PSU caps with other caps of higher quality to reduce cost..the type usually polypropylene at audio grade...You can also by pass chokes as long as you don't make the amp etc unstable..
The difference between Choke PSU and cap only PSU is different and there is a cost difference also.. The current delivery to the speakers can have an effect and damping factor of the amp<<ie the control over the voice coil. This goes on welcome the wacky world of DIY audio..
M. Gregg
The MusicHide this!Advertise here!
Where did the music go? robmedia The Lounge 77 25th September 2011 12:23 AM
your music Bregg Music 0 10th June 2009 01:59 PM
Music for your sub mikee55 Subwoofers 13 23rd April 2006 03:56 PM
Music Les Music 6 24th August 2003 05:01 PM
JE Labs 300b round 5. MUSIC!! MUSIC!! TubeHound Tubes / Valves 14 11th January 2003 12:02 AM
