The Lounge A place to talk about almost anything but politics and religion.
why don't we use predistortion more in the audio world?
Old 31st August 2012, 05:44 AM   #111
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by DJNUBZ View Post
I don't want this to digress into a discussion on EQ and DRC but could you tell me what benefit you would get doing this in the analog domain instead of the digital domain? It seems to me that the con's far outweight the pros when it comes to EQ.
It would be great to equalize speakers for high-end sound reinforcement, where I don't want latency. At home I am satisfied by digital Audissey.
The Devil is not so terrible as his math model is!
Old 31st August 2012, 05:55 AM   #112
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Can't follow you here Wave - you're saying that digital EQ has inherent latency compared to analog EQ?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 31st August 2012, 05:58 AM   #113
Wavebourn's Avatar
Yes.
Old 31st August 2012, 06:01 AM   #114
abraxalito's Avatar
Ah then you need to roll your own implementations. Digital can be effectively minimum phase, just that most of the popular chips (ADC, DACs) implement linear phase and have high latencies. Its not inherent in digital as a technology though as far as I'm aware.
What latencies do you need to achieve?
Old 31st August 2012, 09:08 AM   #115
nigel pearson is offline nigel pearson  United Kingdom
One thing that is possible in digital is to EQ with different phase outcomes . I would imagine sometimes analogue is better and other times digital . A mix might be very good .
I would not say this but for the fact we already have information in digital format . Seems to me that is where to play with it if so .
I was trying to dream up a digital format based approximately on Nicam . The idea would be to have a digitally compressed dynamic range with absolutely defined parameters . The signal at any point can be reconstituted back into the original dynamic range if required or points between . It would use the best of all ideas ( part could be analogue under digital control perhaps ) . DVD as storage medium . This format would be ready to use for radio stations or the car without decompression . The compression arithmetic based on perception and taste ( motor car biased perhaps ) . The chips that process it might have user digital processing included . For example buy two DACs and configure them as active crossovers . The ultimate quality would be rather like buying a posh turntable in the past . It would be incredible . For ordinary people very acceptable in the cheapest format ( meaning me in my motorcar ) .
That's what is wrong today . No big leap from ordinary to hi fi today . Even top end . Same miserable sources of sound . Ones which mostly we bettered in 1957 ( Louis Armstrong , Belefonte etc Decca Peter Grimes 1959 )
Old 31st August 2012, 07:34 PM   #116
Wavebourn's Avatar
Length of cables divided by speed of light (that is constant!) maximum.
Old 31st August 2012, 07:45 PM   #117
Pano is online now Pano  United States
Pano's Avatar
There is a large, built in latency in the air between loudspeaker and ear. Certainly this is much larger than the latency in DSP? At least for PA applications.
Old 31st August 2012, 08:40 PM   #118
Wavebourn's Avatar
It depends on what kind of PA applications. But even for stadium for example floor monitors have to be nicely equalized. My PA systems are famous for "Sensitive microphones". However you understand that that means extremely flat frequency response. Put floor monitors with bumpy frequency response there and everything is screwed.
Old 1st September 2012, 10:05 AM   #119
I think pre-distiortion is only practical in valves from my own tests . It is almost alchemy as it corrects that which hasn't happened yet . Please tell me I am wrong . I know the simplistic geometric reason . What I find hard to accept is how good the fit can be . I am very new to valves so I hardly know anything . All I know is that building near to zero feedback with valves is possible ( loop feedback ) . I can not think how to do it with transistors as easily . 2 common type valves , 0.5 V in 8 V out 8R . THD , 0.03% at 0.6 W 0.1% 1.6 W 0.43% 5 W , 8 W clipping . No loop feedabck ( no Schade either ) . Schade is interesting . It is simple shunt where driver is no great hindrance . It is a slightly better triode ( 30% more gain for identical distortion ) . It measure much like a triode . However the overall gain is poor . I haven't tried all the RH series , RH88 seems less than ideal . If wanting to know about RH 88 measure the cathode of the ECC 81 with various waveforms , very interesting and perhaps V to I converter is correct ? I also found ECC 82 and 12BH7A usable , they were better than expected . A cascoded ECC 82 looked very like a single ECC81 in all respects ( 90 V g1 ECC82 No 2 ) . These are valves I inherited . The interest also . I am notoriously mean so always use what I don' t have to buy . Most of my valves came from the old Chipping Norton Studio .
why don't we use predistortion more in the audio world?Hide this!Advertise here!
NAGYS AUDIO Best Audio Cables in the World!!! Guaranteed!!! NagysAudio Vendor's Bazaar 0 25th August 2010 03:17 AM
World Audio Design cs Tubes / Valves 1 30th August 2006 02:33 PM
Looking to enter the Audio world. Need help ibanezcollector Introductions 4 27th December 2005 04:49 AM
Digital predistortion for speaker correction rtarbell Digital Source 14 21st October 2005 09:34 AM
Copyright ©1999-2017 diyAudio
