The Lounge A place to talk about almost anything but politics and religion.
Random comments on common errors in technical documents
Old 2nd July 2012, 02:45 PM   #21
Bonsai is offline Bonsai  Europe
Well, Harry sent me the errata sheets and there's about 4 or 5 A4 sheets worth I'd corrections. Most are to do with punctuation, usage of SI symbols, it's vs. its; there were quite a few typos as well. Ill post up the errata tomorrow when I am at my computer - seems I cannot get it work on my iPad.
Let take this opportunity to thank Harry for going through the document and highlighting the problem areas.
Old 2nd July 2012, 02:52 PM   #22
HarryDymond is offline HarryDymond  United Kingdom
You're welcome!
it's vs. its
Actually that's something I was pleased to see you had got correct.
For those that don't know what we're talking about, it's Andrew's excellent write-up of his latest amp, the e-amp. Check out his website!
Old 2nd July 2012, 02:56 PM   #23
DF96 is offline DF96  England
For those who want to write as they speak, the correct spelling of "should of" is actually "should've" - but this is rarely used and such people would probably put the apostrophe in the wrong place anyway!
Old 2nd July 2012, 02:57 PM   #24
Thanks! :-)
Old 2nd July 2012, 04:04 PM   #25
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Aluminum/Aluminium, color/colour
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 2nd July 2012, 04:10 PM   #26
One assumes you prefer the US spellings? If you're a British-English speaker/writer but you suspect the majority of your readers will be American, should you use their spellings and words (faucet/tap sidewalk/pavement etc.)?
Old 2nd July 2012, 04:15 PM   #27
Wavebourn's Avatar
British to American Translator & British Dictionary
Old 2nd July 2012, 04:17 PM   #28
Mooly's Avatar
Using quite instead of quiet always crops up a lot.
And adding the word "like" as in "there is like 7 volts on the emitter".
Old 2nd July 2012, 04:38 PM   #29
Wavebourn's Avatar
"Do you here me now?"
Old 2nd July 2012, 05:13 PM   #30
Alternative rendering of Mooly: "the emitter was so 7 volts!".
Random comments on common errors in technical documentsHide this!Advertise here!
Common Source versus Common Drain output stages alaskanaudio Solid State 36 1st June 2014 02:35 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
NOS Stanton 681A, complete, all hardware, documents $55 shipped to U.S. hags Swap Meet 2 1st October 2010 08:45 PM
Checking for PCB errors Cyberzim Class D 7 12th November 2009 09:53 AM
