Random comments on common errors in technical documents Random comments on common errors in technical documents - Page 2 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 2nd July 2012, 02:06 PM   #11
HarryDymond is offline HarryDymond  United Kingdom
Originally Posted by Osvaldo de Banfield View Post
Certainly I don´t know. The automatic spelling check in this PC refuses both with, and without the apostrophes. And Spanish (In fact, I must tell Argentinian language) don´t use the negative form i the verb itself, nor apostrophes, so I really don´t know what is good and what not.
Maybe you're not using the apostrophe key? Certainly what you're typing here is not an apostrophe. What you typed in your post above is this character: ´ (which according to OS X is an ASCII acute accent), but you should be using this one: ' (ASCII apostrophe).
Old 2nd July 2012, 02:07 PM   #12
poynton is offline poynton  United Kingdom
poynton's Avatar
The usage of an extra "of" really gets to me.
As in " He got off of the horse."
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 2nd July 2012, 02:14 PM   #13
Pano is offline Pano  United States
Pano's Avatar
"Don't you know" is an English idiom - not a direct question, sorry. Similar to n'est pas? in French.
Must be your spell checker, or your apostrophe. You are not using the standard apostrophe, but more what we would call an "accent" mark. I'll check the ascii code for you.
Old 2nd July 2012, 02:19 PM   #14
Pano's Avatar
OK, looks like your keyboard is giving you the acute accent character, as Harry mentions. That should be Alt 0180 for those without a Spanish keyboard. ´´´´ The apostrophe is Unicode 0027, but I don't know how to get that other than directly on the keyboard. '''''''
I think that's why your spell checker doesn't like it. Copy and paste my spelling of -- doesn't, hasn't, won't -- and see if the checker accepts it.
Old 2nd July 2012, 02:21 PM   #15
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Yes, may be. As a still DOS user, in a DOS screen, there exists visible differences, but this (F***ing) windows environment, both appears equal.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 2nd July 2012, 02:25 PM   #16
Pano's Avatar
OK, interesting! For those of us with English set as the language, they appear different.
Wonder what those with French or Italian keyboards are seeing?
Old 2nd July 2012, 02:30 PM   #17
I have:
keys for a more or less equal sign. Which is the wright?
Old 2nd July 2012, 02:36 PM   #18
Pano's Avatar
The last one is it!
Old 2nd July 2012, 02:40 PM   #19
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Here is another one
alot instead of a lot
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 2nd July 2012, 02:41 PM   #20
Originally Posted by Pano View Post
The last one is it!
Thank you !!!
Random comments on common errors in technical documentsHide this!Advertise here!
Common Source versus Common Drain output stages alaskanaudio Solid State 36 1st June 2014 02:35 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
NOS Stanton 681A, complete, all hardware, documents $55 shipped to U.S. hags Swap Meet 2 1st October 2010 08:45 PM
Checking for PCB errors Cyberzim Class D 7 12th November 2009 09:53 AM
Copyright ©1999-2017 diyAudio
