The Lounge A place to talk about almost anything but politics and religion.
Random comments on common errors in technical documents
Old 5th July 2012, 04:54 AM   #101
MarcelvdG is offline MarcelvdG  Netherlands
Originally Posted by DF96 View Post
Possibly. I think UK EEs generally extend 'linear' to include 'affine', as 'affine' is not a word which crops up often on EE courses here. 'Linear' is taken to mean 'no new frequency components in the output'.
Interestingly, the strict definition of linear excludes all sources (e.g. DC PSU, AC oscillators) so may be mathematically correct but perhaps unhelpful?
Strictly speaking, if there is no DC at the input but there is DC at the output, you have a new frequency component namely 0 Hz.
Anyway, an affine circuit can usually be split into a linear circuit and a bunch of independent sources. Superposition applies to the linear circuit, so you can turn on each independent source in turn and add the resulting output signals. I don't see what's the problem with that.
Old 6th July 2012, 02:40 PM   #102
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by MarcelvdG View Post
-In the context of current feedback op-amps it applies to the exact same feedback configuration as normal voltage feedback (shunt at the output, series at the input), but with an op-amp having a low open-loop input impedance at its negative input.
IMHO this captures very poorly one fundamental property of CF op-amps, the closed loop BW to the first order does not change with gain. If the closed loop equations are rearranged to isolate the current into the inverting input things are very clear by considering that that current as what is fed back.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 6th July 2012, 09:36 PM   #103
Hi Scott,
I'm not denying that having a low open-loop input impedance at the negative input can have practical advantages, such as the one you just explained. All I'm saying is that three totally different feedback configurations are all referred to as "current feedback" because the term has been redefined at least twice. That doesn't make it any easier to understand what is meant.
Best regards,
Marcel
Old 6th July 2012, 10:33 PM   #104
Ron E is offline Ron E  United States
Ron E's Avatar
Originally Posted by jlsem View Post
I once read a technical paper by a well-known and respected Ph.D. who posts often on these forums and he didn't seem to know that a loose cite was not the same as to lose sight.
I read a book, possibly by the same phd, that reversed form and from so many times that it made your head spin.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 8th July 2012, 10:39 PM   #105
7n7is is offline 7n7is
Banned
There's a serious problem here.
The Streptomycin was invented by Selman Waksman and received patent number 2443485 on June 15, 1948.
When was the Streptomycin invented?
The patent given is on streptothricin not streptomycin.
Old 8th July 2012, 11:26 PM   #106
willysan is offline willysan  Argentina
In the previous page I spotted "it's" where the the author meant "its".
Old 9th July 2012, 12:27 AM   #107
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Wehn you quickly raed mispyted txet olny frist and last lettres mettar. That's why ancient people used hieroglyphs to communicate meanings instead of sounds.
The Devil is not so terrible as his math model is!
Old 9th July 2012, 06:29 PM   #108
popilin is offline popilin  Argentina
popilin's Avatar
Tell us who is
The tribune is thirsty for blood.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 9th July 2012, 09:15 PM   #109
Shaun is offline Shaun  South Africa
Shaun's Avatar
Originally Posted by Pano View Post
And the worst one of all, the eternal "And I" mistake. Seems that so few people in America can get that one right that it's going to have to change. Stupid, but that's the way it is. It seems we have a generation or two of English teachers that has failed us.
"And I" or "And me" - how hard can it be?
Let's explore that. When do you use the one or the other? I do believe that we have been taught to use "and I" at all costs.
The way I figure it out is use whatever you would have used had the other person(s) not been included.
Jack and I went to the shop. (I went to the shop)
The shopkeeper stared at Jack and me. (The shopkeeper stared at me)
Not Quickly he handed the goods to Jack and I. (Quickly he handed the goods to I)
Also, I've never been told this or read it anywhere (that I'm aware of), but I believe the correct form is to refer to yourself last (not "me and Jack").
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 9th July 2012, 09:34 PM   #110
DF96 is offline DF96  England
Shaun and I agree on this.
Random comments on common errors in technical documentsHide this!Advertise here!
Common Source versus Common Drain output stages alaskanaudio Solid State 36 1st June 2014 02:35 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
NOS Stanton 681A, complete, all hardware, documents $55 shipped to U.S. hags Swap Meet 2 1st October 2010 08:45 PM
Checking for PCB errors Cyberzim Class D 7 12th November 2009 09:53 AM
Copyright ©1999-2017 diyAudio
