The Lounge A place to talk about almost anything but politics and religion.
Random comments on common errors in technical documents
Old 3rd July 2012, 06:36 PM   #91
DF96 is offline DF96  England
No contradiction at all. Linearity does not necessarily imply large output, and it does not necessarily require simple proportionality as a constant bias can be involved too. All linearity, in the context of a PSU, means is that if raising the input from 20V to 25V raises the output by 0.5mV (from 12V to 12.0005V) then raising the input to 30V means that the output goes up 1mV to 12.001V.
I think it was your mistaken introduction of 'proportional' which led you astray.
Old 3rd July 2012, 06:42 PM   #92
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Linear voltage regulator is opposed to the one that uses PWM. But who is well known vendor of chips for PWM regulators? A company with "Linear" in their name.
The Devil is not so terrible as his math model is!
Old 3rd July 2012, 06:44 PM   #93
wahab is offline wahab  Algeria
"Bootstrap" is one of the worse technical terms since it s barely analytical.
Old 3rd July 2012, 06:49 PM   #94
Wavebourn's Avatar
What is confusing in bootstrap?
Old 3rd July 2012, 06:50 PM   #95
MarcelvdG is offline MarcelvdG  Netherlands
No, you are confusing linear with affine. When there is a constant bias involved, the system does not comply with the superposition theorem anymore and it is therefore not linear. At least that's what I've been thought at the Delft University of Technology.
Current feedback has at least three different meanings nowadays:
-In the oldest literature that I've read, it meant series feedback at the output, no matter what happens at the input.
-In the book/PhD thesis of Ernst Nordholt it means series feedback at the output and shunt feedback at the input, resulting in an accurate current to current transfer.
-In the context of current feedback op-amps it applies to the exact same feedback configuration as normal voltage feedback (shunt at the output, series at the input), but with an op-amp having a low open-loop input impedance at its negative input.
Old 3rd July 2012, 06:51 PM   #96
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
And what if I use a quadratic device like a FET or tube? It has some proportionality, but not necessarily linear (equal output measure per equal input measure)
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 3rd July 2012, 06:59 PM   #97
It is not analytical ethymologicaly speaking.
"Positive feedback loop" is the right term and it s quite remotely
linked to "bootstrap".
Old 3rd July 2012, 07:34 PM   #98
Wavebourn's Avatar
Right, bootstrap is actually a jargon term for specific positive feedback from output of the voltage follower to it's input.
Old 3rd July 2012, 09:42 PM   #99
Possibly. I think UK EEs generally extend 'linear' to include 'affine', as 'affine' is not a word which crops up often on EE courses here. 'Linear' is taken to mean 'no new frequency components in the output'.
Interestingly, the strict definition of linear excludes all sources (e.g. DC PSU, AC oscillators) so may be mathematically correct but perhaps unhelpful?
Old 4th July 2012, 10:23 AM   #100
Linearity of such PSU is not tied to its regulation factor seen from
input to output but to the relation between its voltage reference
and its output.
Random comments on common errors in technical documentsHide this!Advertise here!
Common Source versus Common Drain output stages alaskanaudio Solid State 36 1st June 2014 02:35 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
NOS Stanton 681A, complete, all hardware, documents $55 shipped to U.S. hags Swap Meet 2 1st October 2010 08:45 PM
Checking for PCB errors Cyberzim Class D 7 12th November 2009 09:53 AM
Copyright ©1999-2017 diyAudio
