Memories of electronics.. Memories of electronics.. - Page 2 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 7th June 2012, 08:37 PM   #11
M Gregg is offline M Gregg  England
Originally Posted by SY View Post
A regenerative receiver. I couldn't believe that I could get Deutsche Welle on that little claptrap setup.
Great isn't it when you get the first radio working ..a two transistor regen with SW coils was an extension of the Phillips X40 kit
The "Radionic" electronic kit series
All bolt togeather parts..
M. Gregg
Old 7th June 2012, 08:38 PM   #12
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Originally Posted by M Gregg View Post
Did you need an extended aerial? Diode or crystal cats wisker?
M. Gregg
Yes - we did need the antenna - long piece of wire is all with that. It was the old crystal cats whisker type - Later we built one with the variable capacitor tuning circuits.
After that it was off to a couple of years of electronics tech school in da Navy.
My exposure to good quality stereo wuz while I was in the Navy. A buddy and I built a 15 wpc Heathkit and hooked up some Koss cans to it. Man!!!! I've been hooked every since...
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 7th June 2012, 08:46 PM   #13
Heathkit were very good...I remember Hart amps as well...Sinclair did a modular HIFI that just bolted togeather for the bodge it guys..it even had a Grafic EQ...
M. Gregg
Old 7th June 2012, 08:53 PM   #14
Pano is offline Pano  United States
Pano's Avatar
Crystal radio when I was about 8 years old. Really simple thing, but it seemed unbelievably complex to me at the time. It's still a great reference point.
Old 7th June 2012, 08:54 PM   #15
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I got my first taste of electronics when attempting to fix an old black and white TV.
My father had some spare valves lying around so I swapped some in and got the TV working again.
In the 1980's I got involved with disco equipment and built my own disco from Maplin kits. It all worked very well. This was amazing as i had little clue as to how the electronics worked then. A little care and a little luck go a long way.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 7th June 2012, 09:13 PM   #16
DF96 is offline DF96  England
Philips electronic engineer kit. I built the AM TRF radio (4 transistors?), then wound a new coil to get Trawler Band. About the same time I began to read Practical Wireless (I think I was about 13 at the time); I learnt a lot from that. Later progressed to Wireless World and RadCom.
Old 7th June 2012, 09:20 PM   #17
The Phillips engineer kit,
Was this the one with a perforated chassis and you pushed the spring retainer through the holes with a spring on the other side.. you depressed the spring to put the component legs in?
M. Gregg
Old 7th June 2012, 09:21 PM   #18
On Hiatus
SY's Avatar
That was the one I had!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th June 2012, 09:23 PM   #19
Yes I built a couple of maplin kits,
One of them was a fet amp that you could bridge to get double power..DC protection board and relay..They advertised it as bomb proof just like the best valve amps..
M. Gregg
Old 7th June 2012, 09:27 PM   #20
I bet you had the posh one with the speaker and extra parts.. My fingers used to sting after stripping it and rebuilding..pulling the springs off..
M. Gregg
Memories of electronics..Hide this!Advertise here!
Not electronics but .... quasi The Lounge 11 17th July 2017 08:50 AM
ESL electronics 101 for the electronics challenged markusA Planars & Exotics 12 29th April 2011 05:19 PM
New to electronics. Need help. rfortenberry Everything Else 1 6th October 2003 09:06 PM
B.K. Electronics ogp Solid State 2 19th November 2001 08:00 PM
Copyright ©1999-2017 diyAudio
