The Lounge A place to talk about almost anything but politics and religion.
10 kilo heatsink turned into a kitchen gadget
Old 15th May 2012, 01:45 AM   #1
DualTriode is offline DualTriode  United States
Talking 10 kilo heatsink turned into a kitchen gadget
Hi All,
10 kilo heatsink turned into a kitchen gadget.
What does a heatsink do? It takes heat from place and puts it somewhere else.
Now that I have a stand alone upright freezer I have put some 0.5 kilo packages of grass feed beef on the top shelf for future use. The question was, how do I thaw this thing out. For the first package I placed it into an aluminum frying pan and noticed that the pan got cold and stayed that way for quite awhile. The engineer in me went to the shop and found the largest heatsink on the shelf. The goal was to maximize the rate of heat transfer. 10 kilos does not stretch the truth too far.
I am trying to noodle (kitchen pun) through this. A thin layer of condensate quickly forms to fill the void between the package and the heatsink, acting much as thermal grease does for my amplifiers.
The use of this kitchen gadget cuts the defrost time in half.
Thoughts?
Just for fun!
DT
Old 15th May 2012, 01:58 AM   #2
DIYampNOOB is offline DIYampNOOB  United States
What was the cost of the 10Kilo Heat Sink? Probably not a cost-effective way of doing it, but VERY STYLISH INDEED!!!
Old 15th May 2012, 03:33 AM   #3
Alvis is offline Alvis
Banned
Sounds like fun.
You could expose the fins or aluminum surface to some water, preferably moving water.
Passive cooking.
I plan to make a solar oven when I can find the time. The research I have done shows them to be practical, even in the winter time.
Old 24th May 2012, 02:57 PM   #4
Bonsai is offline Bonsai  Europe
Just stick that thing on the fire and get done with it.
Old 30th May 2012, 06:22 PM   #5
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
Obviously you don't understand how freezers work. Attach the heatsink to the radiator at the back. Then the fridge will suck the cold back out of the meat. By the principle of the conservation of coldness, efficiency can approach 100%.
Ian
Old 30th May 2012, 06:26 PM   #6
Originally Posted by PlasticIsGood View Post
..............conservation of coldness, ...........
I thought I listened at school.
regards Andrew T.
Old 30th May 2012, 06:34 PM   #7
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Isn't that called an F5????
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 30th May 2012, 07:18 PM   #8
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
That's what I've got....it was a big chunk of Aluminium some 347mm by 197mm by 5mm (Got it on my lap) It was advertise "defroster". It would picture a steak on it.It is preffered chassis for my 12B4 amp ...I cut a hole(Filed) for a 220V PWR socket IEE ???socket.
has teflon style black coating. Says "Taiwan", cast feet (Bumps) for the four corners, radiused corners45mm?
__________________________________________________ _________Rick.....
Last edited by Richard Ellis; 30th May 2012 at 07:22 PM. Reason: additional thoughts
Old 1st June 2012, 04:31 PM   #9
Ian
A heat pump HVAC unit in a mild climate can extract the cold indoors and move it outdoors at a rate of 2 to 4 times greater than the energy used by the pump. That is called the COP or the Coefficient Of Performance. Or in other words efficiency of 200 to 400 percent.
DT
10 kilo heatsink turned into a kitchen gadgetHide this!Advertise here!
new 10.125" wide heatsink barrredboss Heatsink USA 76 19th July 2011 12:17 AM
a picture of the new 10 inch wide heatsink barrredboss Parts 1 27th April 2009 04:10 AM
10.125" heatsink barrredboss Parts 0 25th April 2009 05:01 AM
Standalone Speaker measuring gadget venki Digital Source 2 1st January 2006 06:22 PM
10.88 wide heatsink barrredboss Swap Meet 0 23rd April 2004 08:09 AM
Copyright ©1999-2017 diyAudio
