The Lounge A place to talk about almost anything but politics and religion.
ECC82/12AU7 Line Preamp
Old 27th March 2012, 03:17 AM   #151
popilin is offline popilin  Argentina
popilin's Avatar
Originally Posted by Wavebourn View Post
Bigun already suggested you to ckick there: Tube CAD Journal
While answering Bigun I went twice interrupted, so two replies, sorry.
I visit very often the Tube CAD Journal page, I also did simulations of Aikido.
By the way, I've seen very similar picture in real life, the same -80 dB of 2'nd order only, from my Pyramid amp that contained 5 tubes per channel (actually, 6 if to cound pentode-triode as 2 tubes). The picture was very similar on half power, 40W. However, on higher power higher harmonics were visible. I don't remember already which input tube I used there in that version of the amp, either 6F12P or ECF-200. I usually don't do such measurements, only if somebody is curious to see.
I mean, 6AU7 is not the best choise.
Wow! -80dB, even in my dreams, is that at 1W?
I don't know 6F12P neither ECF-200, I guess it's a low signal triode-pentode, but nothing else, I will investigate.
Is very difficult to obtain good valves here, also closed the import
Maybe 6AU7 is not the best choice, but I think that would have to prove.
Wim de Haan, among others, the praises, other people the hate.
Only by intellectual curiosity, can be see the schematic somewhere?
Old 27th March 2012, 03:22 AM   #152
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
sorry for the OT, i use lye in water to treat aluminum chassis....gives it a dull sheen....
ashok, you have name of that that i can look at...i use a local thing called Stripsol that removes paints, not tried on magnet wires though.....it is a pasty substance, and applied by brush, highly corrosive and painfull to the skin just like lacquer thinners....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 27th March 2012, 03:26 AM   #153
On Hiatus
SY's Avatar
Can you get some of the color test strips people use for checking pH of their swimming pools?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th March 2012, 03:34 AM   #154
ashok is online now ashok
ashok's Avatar
Hi SY, I have some pH strips that I use to check acid content in my wine must. That's around 3.2 to 4.6 range I think and a few wider than that. I also have 0.2N NaoH solution and phenolphtalein that I use to check acid content by titration.
I can get any other acid/alkali indicators if required.
AM
Old 27th March 2012, 03:35 AM   #155
TonyTecson's Avatar
me? am afraid no.....
Old 27th March 2012, 03:39 AM   #156
On Hiatus
SY's Avatar
The phenolphthalein should indicate if it's basic. No need to titrate, if a drop of the nasty stuff in some water still makes the indicator bright red, it's probably lye-based. Other possibility is peroxide.
Old 27th March 2012, 04:04 AM   #157
ashok's Avatar
Yes I'll try that. I'll pick up a bottle of the 'stuff' soon.
If peroxide can bleach skin pigments ( I'm brown ...will tell easily !) then this one may not be it as it didn't bleach my skin or leave any marks. Just felt like a burning sensation when it touched the skin until washed off with water.
I have some 10% H202 here but that's too dilute to bleach skin pigments!
AM
Old 27th March 2012, 04:30 AM   #158
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I have an idea. Acetone must help, slowly adding more of acetone molecules in polymer making it softer, but it is looong way, you have to soak it for 1-2 days.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 27th March 2012, 07:01 AM   #159
ashok's Avatar
I currently have Amyl Acetate, Xylene and I think some Benzene. I'll have to pick up a bottle of Acetone. Any other possible solvents ? Might as well pick them up when I go to the shop !
AM
Old 27th March 2012, 01:57 PM   #160
avp1 is offline avp1  United States
You can try Dichloroethane too, it is quite toxic though.
ECC82/12AU7 Line PreampHide this!Advertise here!
ECC802S 12AU7 ECC82 heater question korabetsni Tubes / Valves 8 3rd July 2012 12:03 PM
12au7 ecc82 nigelwright7557 Parts 0 29th March 2010 01:07 PM
FS: single nos telefunken ECC82 (12au7) PreSapian Swap Meet 0 4th January 2010 03:03 AM
Do I need a Trafo for the HV in my 12AU7 (ECC82)? DaMeat Tubes / Valves 13 10th August 2007 10:08 AM
line preamp using 6SN7 instead of 12AU7 JPS Tubes / Valves 11 23rd May 2007 12:05 PM
