The Lounge A place to talk about almost anything but politics and religion.
HUGE technology development.
Old 16th February 2012, 05:10 AM   #41
cbdb is offline cbdb  Canada
If Edison was a scientist he would not have blown the wad on DC power transmission. Edison invented industrial science. He was the Ford of electricity. He hired a bunch of scientists and told them what to invent then took the credit. (sorry thats a little harsh)
Old 16th February 2012, 07:01 PM   #42
DF96 is offline DF96  England
Originally Posted by GloBug
Consider the limited coupling of a single wire to radio waves, where the only improvement is in length.
If you pictured it in the "traditional" transformer context, it's weaknesses are obvious.
Length? Of the antenna, range of signal or what? Weaknesses of what? Difficult to comment on something I don't understand.
Think of how a crystal radio works, using a capacitors resonance to it's advantage, now scale this down and paint it on.
I don't think it "extends" the range so much as it "improves" the coupling of the device with RF waves.
A crystal radio works via LC resonance, not "capacitor resonance", but it is true that impedance matching providing good coupling is part of the technique.
If this spray-on coating does anything, it could be by acting either as a dielectric or a negative index metamaterial. In either case it would need to be designed in to the antenna, not just sprayed on the outside. Antennas just aren't that simple!
Old 16th February 2012, 08:13 PM   #43
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I remember when people claimed that mercury in copper tubes improved TV reception, but were illegal because they generated RF interference.
And of corse, name of Nikolai Tesla was pronounced, because press already created an aura of superstitious smoke around his early works.
The Devil is not so terrible as his math model is!
Old 16th February 2012, 08:43 PM   #44
GloBug is offline GloBug  Canada
Banned
If you don't understand now, then it does it warrant further comment?
Here's some test you can do at home.
1: Cut 90% of the length off of any antenna, now does this work better or worse?
2: Separate the primary and secondary windings of any transformer and place them at opposite sides of the room, does it work better or worse?
You do realize that an antenna is in reality half a transformer?, a transformer is really two antennas with a core to improve coupling?
And what does the "C" in LC stand for?
Do you agree that a capacitor can also have inductance?
As a side-note Chamtec is already a defense contractor, maybe one of the experts here would like to purchase some, you can always return it. Spray On Kit
I respect that some may have worked in this field for many years, this has nothing to do with future scientific discoveries.
It's one thing to claim you "know" how something works, "understanding" however is a completely different beast. The moment you close your eyes is the moment you stop learning,
Old 16th February 2012, 09:11 PM   #45
On Hiatus
SY's Avatar
Originally Posted by GloBug View Post
No contributions in physics??? Are you reading this by candle light?
Fluorescent. And backlit LCD.
In any case, electrical heating of filaments was long known- Edison (or more precisely, guys working for Edison) figured out how to make them practical as light sources through extensive trial and error. We call that "engineering."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th February 2012, 09:11 PM   #46
a.wayne is offline a.wayne  United States
Sin Bin
brewwwwhahaha .....................
Old 16th February 2012, 09:17 PM   #47
dirkwright is offline dirkwright  United States
dirkwright's Avatar
As I recall, Edison himself said that his work was "99% perspiration and 1% inspiration".
Old 16th February 2012, 09:26 PM   #48
Banned
So he should have blown the wad on Westinghouse's product?
Westinghouse did not invent AC nor was he nearly as successful as Edison.
Kind of ironic bashing DC on a site that converts AC into usable DC for projects isn't it?
Old 16th February 2012, 09:32 PM   #49
dirkwright's Avatar
No, he should have reviewed Tesla's inventions and papers and realized that AC was the way to go for long distance power transmission. Edison tried to force DC power transmission on the world out of greed and ego, and not on technical excellence.
Old 16th February 2012, 09:34 PM   #50
That would depend on whether it was already the correct length. If it was right, then shortening or lengthening or spraying dielectric on it would make it worse.
Not quite as simple as that. You may be confusing the local induction field with the far radiation field.
Capacitor self-inductance does not play a significant role in resonance in a crystal set.
Defense contractor's main skill is extracting money from the military. I used to think that defense contractors knew their stuff, and of course many of them do, but this is not universally true. I once saw a report on some military-funded research which showed that the author did not know the difference between input impedance non-linearity and gain non-linearity so assumed that one was a reliable proxy for the other - his experimental results showed he was wrong but he just blamed it on calibration errors.
Yes, I agree. That is why there is so much nonsense spoken about antennas.
HUGE technology development.Hide this!Advertise here!
What is your development / prototype process? weinstro Solid State 0 7th December 2009 04:37 PM
Smps In Development albert_emule Power Supplies 3 11th April 2009 10:29 PM
Sub Development jwatts Subwoofers 21 11th June 2006 07:30 PM
Interesting development StevenOH Everything Else 2 10th October 2005 06:26 PM
Copyright ©1999-2017 diyAudio
