The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 18th January 2013, 08:41 PM   #8181
dvv is offline dvv  Serbia
Actually, Nige, that may be some waystation, because in the end, the best overall solution is an active speaker.
Just imagine the bass or tweeter being connected to the driving amp by something like 10 inches of wiring of your choice, no resistors, capacitors or inductors in the way to cause nasty phase shifts and decrease natural driver efficiency, and so forth.
Under such circumstances, I believe some of the available all-in-one-chip power amplifiers would do just fine, possibly even very well. After all, they'd be seeing as clean and easy load as possible.
Assuming you select your power amp chip well, and are not stingy about it, and with no passive crossover losses, you might be able to get some awesome dynamics in a room.
Not to even mention the Games Unlimited you get at no extra charge. For example, if you have a say 96 dB/2.83V/1m efficient tweeters, which are powered by a say 50 WRMS chip power amp, you could easily add a series resistor and not have to worry about drive power.
Or, if your really went for it, you might consider the opposite direction, such as putting two tweeters in parallel, because again, practically nothing stands in the way between them and power amp driving them.
MOST interesting thoughts become possible.
The only caveat that comes to mind is the problem of cables linking the active speakers and the command center, the preamp. Personally, I'd think hard about balanced lines, but obviously only after first deciding where to place the electronic crossover. If placed inside the speaker, then it would also act as a buffer for the chip power amps.
Per Aspera Ad Astra.
Old 18th January 2013, 08:52 PM   #8182
DF96 is offline DF96  England
Originally Posted by a.wayne
Why higher voltage vs VA ..?
How can a 50v 500va transformer make an amp sound better than an 40v /800va one , i don't get this , big transformer big cap bank , yes ..
The larger VA oversized transformer will have less noise for sure .....
Unless you listen to continuous sine waves, or many modern CDs with almost no dynamic range, the transformer has plenty of time to recharge the caps during the quieter periods. The higher the voltage they recharge to (set by the secondary voltage, not VA - within reason) the more you can droop when the next music peak comes along.
As I said, it is counterintuitive so some people will find it hard to believe. Do the maths, or read the other thread and believe the maths we have done. The right transformer can be better than the bigger transformer. I guess I am arguing for design, not fashion following.
Of course, if you have to sell a product then you may need to degrade its performance by putting in a bigger transformer which can supply more current than necessary in preference to one with a bigger secondary voltage which can provide more headroom.
Old 18th January 2013, 08:54 PM   #8183
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
What you are talking about, gentlemen?
What capacitance? What Joulies?
Suppose, I have an amp. It draws 1 A constantly, it has a source follower output supplied by current source. Let's take the worst scenario: output resistance of the source follower is 1 Ohm, dynamic resistance of current source is 1 KOhm only. That means ripples and sag from power supply re 60 db down on speaker terminals. So if they are huge, like 1 Volt, there will be -80 dB S/N level on speaker terminals caused by PS ripple and sag. Now let's calculate which minimal capacitance do I need for -80 dB or below?
It's the practical question based on strong arithmetic theory. No esoteric at all.
The Devil is not so terrible as his math model is!
Old 18th January 2013, 11:24 PM   #8184
fas42 is offline fas42  Australia
Banned
This is the Krell "secret" of course - what they did was realise that minimising voltage droop was the name of the game, and they threw a lot of resources and money at refining that. Hence the infamous Krell bass, simply because the power supply didn't collapse when some meaty notes needed to be played.
That the rest of the amp wasn't too sharp at reproducing everything else probably didn't worry them too much ...
Frank
Old 18th January 2013, 11:34 PM   #8185
a.wayne is offline a.wayne  United States
Sin Bin
Frank
Infamous bass .....
I'm wagering you have not heard much Krells, if using them on an 8 ohm speaker load, then its a waste , put them on Maggies, apogees, or anything with a 4 ohm impedance or lower and they shine thru. While not the best sonically, they were easily top tier of the day ...
Old 18th January 2013, 11:57 PM   #8186
Banned
Originally Posted by a.wayne View Post
Infamous bass .....
I think you misunderstood me, I just said exactly what you repeated: Krell could do brilliantly driving extremely severe loads, maintaining bass performance at high volumes.
Here, I will again put in a good word for the Australian ME amplifiers, which back then could easily out-Krell a Krell, how about 1500W into 1 ohm per channel, continuous, both channels driven. 5KVA transformer, 300,000uF, switchable class A operation. The bloke behind it had problems in the interim, but has re-emerged, at the moment with far less ambitious units: Home
Frank
Old 19th January 2013, 02:07 AM   #8187
Sin Bin
ME, 1500 watts @ 1ohm ! what is ME, I will search for it , it's my destiny .....
EDIT: Do you really need a thousand little caps , I'm limited to 8 , it's a round number and in stock ...
Old 19th January 2013, 02:44 AM   #8188
Banned
It's "hidden" in that last link, in my previous post! Home ... me-au.com ...
Nope, the number of caps doesn't have to be huge, though that ME used 92, I seem to recall .... It's about the right values, in the right place ... patience, Grasshopper ...
Frank
Old 19th January 2013, 06:29 AM   #8189
Banned
How far have we come in 25 odd years? The new, "ultra monster" Boulder 3060 only does 900W into any load, meaning I guess also 1 ohm ...
Frank
Old 19th January 2013, 07:11 AM   #8190
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
That's the one they're discussing over at 'another place' where the 17keuro premium for black is being questioned?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
