The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 5th January 2013, 07:43 PM   #7951
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by nigel pearson View Post
Mr PP and others . Is there a class D amp which can be built " dead bug " and is > 90 % efficient and < 1% THD . It would be great to have something to work on . I always suspected a NE555 and some FET's should be able to get us somewhere . Hypex is too much like a cake mix for me ( look mummy I made a cake ) .
Google tells me this site is a risk ( Trojan horse or the like , policeman sign says " get me out of here " ) . hope me being here is sensible ? Other than that we are a threat to world order and we are being censored , great !
Chrome was warning me for a while about diyaudio, so I avoided it for a bit. Not sure if it was a real threat or not.
Old 5th January 2013, 07:56 PM   #7952
diyAudio Member RIP
The genesis of Hypex, whose products use, among other later developments, Putzeys' patent that belongs to Philips, is that Bruno started off when he was with Philips to make the lowest-cost class D amp, period. At the time he did it, Philips (having not yet spun off NXP) made certain parts from which the earliest UcD designs were constructed. As a result there are more discretes than might be seen today as cost-effective, although they are still pretty cheap. But it means that board area is larger than more integrated designs. Note that you can use exactly the original reference design if you use NXP semiconductors, no licensing fees required.
The surprise, though, was how well things worked. By requiring only a small delay inserted in the loop, essentially no hysteresis, and counting on the output L-C for most of the phase shift, one makes a self-oscillating amplifier with the output filter inherently enclosed in the feedback loop. Many benefits thereby accrue.
Old 5th January 2013, 08:15 PM   #7953
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Nigel,
not sure what you're getting at.
maybe I should emphasize that IMO efficiency is not the biggest advantage of class D. my electrical bill is less than GBP 35 during the winter when I turn the electrical heater on now and then. and in all honesty, likely my bike with its low mileage does a decent job at getting few species closer to extinction so I'd be a hypocrite to pretend that I'm green. ok, lecture me, it won't help LOL
it's about size and weight that translates to price. and yes, I don't have an infinite income therefore I need to take that into consideration.
about Hypex, THD and efficiency, I'm even more confused.
the standard UCD180 datasheet lists efficiency at 92%, NCORE at 93%, full power. but as we all know, at idle the output devices still switch so...
I have done distortion measurements with my implementation. at ~100W into resistive 4.7ohms, a 18k+19k intermodulation tests gave a highest product at -80dB. pretty decent. Stereophile reviewed the Channel Islands amp and their measurements pretty much confirm it (actually -70dB at 50W but there must be something wrong in their methods as I have personally tested it).
and NCORE? as per Hypex datasheet it's pretty much unequaled.
so, you don't like Hypex? cake mix? I don't get it. no I'm not a fan boy. I own one but I have no problems admitting it has its issues. in no way perfect. quite the contrary I'd like to find out what's wrong.
we all love a good ol' stereotype until it's against us
Old 5th January 2013, 09:03 PM   #7954
dvv is offline dvv  Serbia
Looking over the sites of some digital audio amp manufacturers, I noticed that when one added all the extras, which are supposed to make them work and sound better, in the end, they turn out to be not at all cheap. While for the price they will produce nominally more power, I still feel that for the money, I can do better in analog sound-wise, even at the cost of the power output
Of course, every new technology has its gestation period, the time during which its milk teeth need to fall out and be replaced by proper teeth, and I have no doubt that the future belongs to them.
I also feel their time is yet to come. In the meanwhile, I'll stick to analog.
Per Aspera Ad Astra.
Old 5th January 2013, 09:17 PM   #7955
john dozier is offline john dozier  United States
john dozier's Avatar
I am using the ClassDaudio mastering amp. I have some very expensive tube amps running in triode. I find the ClassD to be better in all regards.
Evil looms. Cowboy up. Kill it. Get Paid.
Old 6th January 2013, 12:29 AM   #7956
a.wayne is offline a.wayne  United States
Sin Bin
Well run it at 1 ohm and let me know ..i can do that with the ab amps here
Originally Posted by mr_push_pull View Post
Nigel,
Old 6th January 2013, 12:31 AM   #7957
Sin Bin
Well i guess the death of tubes John , finally .....
Old 6th January 2013, 12:46 AM   #7958
I re-read my post that you quoted and I haven't been able to find the part where I said that my amp is/should be able to drive 1 ohm loads. I say "my car won't start" and your reply "yeah and it doesn't do 300 mph either".
Old 6th January 2013, 12:57 AM   #7959
Sin Bin
Ok , but can it do 300 MPH after we start it ....
Old 6th January 2013, 08:59 AM   #7960
No, it can't, it's an 8 Ohm car.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
Copyright ©1999-2017 diyAudio
