The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 12th December 2012, 06:39 PM   #7801
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by a.wayne View Post
Only fair he sends one out , i'm sure you could make it the quietest best amp in the world ...
I must say as well that the HFN/RR measurements, while better than nothing, make me appreciate Atkinson's ones in Stereophile all the more.
Old 12th December 2012, 07:23 PM   #7802
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by bcarso View Post
Well, that is mean. Plus that style of bathroom scale is usually not very accurate
A line of early aftermarket autosound amps I worked on a little for JBL, circa 1990, looked a lot like carpet sweepers, one of those old Bissell jobs, something noted as well by Tom Jacoby iirc.
I remember those , that was you ...
Old 12th December 2012, 07:48 PM   #7803
diyAudio Member RIP
Actually the main man was Darrell Bennett, who inherited the project from some others. I got involved a little based on some problems, including excess distortion in the switchable Sallen-Key three-pole lowpass, which was to allow a channel to be used for a woofer alone.
It was actually one of my early atta-boys. The filter had three 18k resistors in series to the noninverting input of a unity-gain buffer, and switched the three capacitors to the junctions of the resistors and input in and out. There was excess distortion at high frequencies with the caps switched out for full bandwidth. I conjectured that the BiFET opamp was suffering from common-mode distortion, associated with the PFET input stage and substrate capacitance. Since active drive of the power rails (really only the negative rail drive was needed) was out of the question, I experimented with a compensatory impedance in series with the inverting input and tuned it for minimum distortion. It was enough to bring the product into spec. My bosses were impressed, having in particular vocally discounted my conjecture until I showed that the fix solved the problem
Old 12th December 2012, 07:58 PM   #7804
dvv is offline dvv  Serbia
Brad, so what if the noise is a little above some others?
Hopefully, you and I do not listen to them for noise and distortion, but for the music. If the music comes out better to much better than from other, nominally technically superior, then that's all there is to it.
As I see it, Dan d'Agostino was one of the first designers to recognize the simple fact that low THD and IM distortion values mean very little - if anything? - in terms of the final result, the sound. Of course, this should not be taken literally, but I'd like to remind one and all that for the last two decades, Krell products had THD values of 0.3% no problemo, yet always came out on top, if not as No.1, then as one of the top 3 products in any group.
Personally, I agree completely with Thorsten especially and Nigel in good part, the 20 Hz to 20 kHz THD is just fine if it's 0.1% or so, so long as its say 50 kHz performance is what it should be, meaning just a little higher than its 20 kHz performance, not 5 or more times that, as is the most common case.
Per Aspera Ad Astra.
Old 12th December 2012, 08:57 PM   #7805
diyAudio Member RIP
Yes but...
The spectrum of the distortion is of course important. Low-order 1000ppm is not the worst thing in the world. Could it be that the amount of noise is intentional?? Is it an attempt to bury the distortion below a noise floor at low to moderate levels? Some signal-averaged residuals would be very interesting to see. Has Stereophile reviewed this yet? I'd like to see JA's sidebars. I don't recall it as being in there yet, although I see D'Agostino is advertising there.
What bothers me is how the noise can be that bad. I can't conceive of tradeoffs that would enhance some other performance parameters and entail that much noise! Especially for linear amps, getting substantially better noise performance should be pretty trivial. I was managing about 30uV rms output noise unweighted with a somewhat-smaller class D amp a while back, and that at higher overall gain.
The fairly high output impedance (and I am trusting the published HFN/RR measurements, perhaps unduly) suggests a low global feedback design. And that's o.k. if one is persuaded that this enhances the sound quality. It does not by itself say much of anything about noise.
I guess it is conceivable that he is massively degenerating the input devices, to have plenty of local feedback linearization, and that this is accounting for a considerably higher e sub n there.
I'm just puzzled. For many sources and nominal-efficiency loudspeakers, that amount of noise is not necessarily going to be intrusive. For high-efficiency ones in a quiet room at typical distances, you are likely to hear audible hiss if the roughly 400uV is predominantly high frequency. Again, actual listening and/or more data is needed.
Of course Krell has been noted for behemoths that handle low-Z loads and very high currents, so such amps would probably not be the first place to turn for driving high-efficiency speakers to begin with.
Old 12th December 2012, 09:42 PM   #7806
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by AndrewT View Post
memory no good.
Some are posted by our Member that claims to be a digital PSU and digital Amp designer.
I think Cordell did a circuit/test procedure to measure the effect of fast transients on the PSU caps.
And yes to lead lengths.
The straight through must be the smaller cap value. The high value cap then gets tacked on afterwards.
It's the same philosophy that is applied to the on board decoupling. The small caps must be right next to the power Pins (= short route lengths).
It's only a few days ago that I purchased a network analyser and one of the main reasons for it is to properly measure paralleled caps, supply impedances and stuff like that... once I find enough time for that besides the day job (where it will be useful, too). Today I made a first try with 1000uF/63V electro plus 100nF ceramic... a wiggle around 2Mhz was visible but not high-Q and still well below 1 ohm (if I did the normalizing right). I expect to find more severe ringing with bigger can size electros plus "just the wrong" (too small) bypass ceramic/film even when sitting as close as posible.
For gross resonance problems, injecting a current step and looking at the response offers insight with less expensive tools (see Measuring Capacitor ESR and Inductance for the concept).
Old 12th December 2012, 10:07 PM   #7807
KSTR's Avatar
As for the ratio of main vs bypass caps, you'll run into problems once the main cap already is fully inductive and the bypass is still fully capacitive at the intersect of the impedances, especially when there is neither resisitive component in the coupling connections nor parallel resistive damping with snubbers.
So a rule of thumb would be to select caps that have their turnover points seperated by less than one decade of frequency and also chose the bigger one to have just enough ESR to give a broad valley instead of a narrow notch at its turnover.
For caps with same order of ESL (including stray) this means staying lower than about 100:1 capacitance ratio as turnover freq is proportional to 1/sqrt(L*C).
Old 12th December 2012, 11:10 PM   #7808
Sin Bin
Interesting 100:1 , what about placing additional caps at output , i plan on using a cap per output right at the output stage , seperate from the main cap bank of 160k / ch ....
How to calculate the appropriate value ...?
Old 12th December 2012, 11:31 PM   #7809
fas42 is offline fas42  Australia
Banned
If the bypass is too small then what you're looking at is the inductance of the can overwhelming any impact of the bypass at frequencies lower than the resonant frequency of the ceramic/film.
Frank
Old 13th December 2012, 07:38 AM   #7810
@Brad
I understand your musings and, make no mistake, I am definitely not opposing your views.
On the other hand, like Krell sound or not, no-one can possibly say that Dan d'Agostino doesn't know his trade too well. Meaning, that if he left it as is, there is very probably some reason for that. Possibly he thinks this is low enough to be inoffensive, or solving that problem may cause problems appearing elsewhere, I don't know.
Let me remind you of what I think could be an amp designer's worst nightmare, he has no idea what his amp might be connected to, and people have been noted to come up with the strangest of ideas in time.
I've noted a few oddities like that in my time as well. In 2001 or 2002, I was desperately trying to make Graham Slee from UK to dump his NE based headphone amp for an AD 826. Eventually I did it, and he did admit it sound quite a bit better with the AD, but he also noted that it had an unexplained offset. Didn't bother him, he has a cap in series with the output, but it sure bothered me, this 0.6V offset.
Solving the problem was no bid deal, just a simple 1N4148 diode from output to the minus Vcc line, but that offset shouldn't have been there in the first place, it flew against their own Data Sheet.
I sent them a mail outlining the problem, with a schematic I was using. Got no reply, BUT the next batch of these op amps, purchased about 4 or 5 months later on had the problem resolved. It was almost pointless using a servo, it was that good.
These things happen. Just looking at the internal topology of modern op amps it's hard to imagine that a mistake should never somehow creep in, after so many checking and rechecking.
In 1990 or 1991, a friend and I were doing a text for a local PC magazine related to numeric coprocessor (remember those?) effciency and speed. The notm was, of course, Intel, but another company was making a lot of waves with their take on the matter, for the life of me I can't remember their name now. Anyway, I supplied the hardware, and he supplied the software, which was a massive architectural program he wrote, based on MS Fortran (among other tests).
During the test, we discovered that the alternative had serious problems understanding numbers 0 and 1 - believe it or not. Consequently, it kept churning out wrong results on Fortran based programs (and I hasten to add, in those days, MS Fortran was THE standard against which all others were compared).
We got in touch with the company via a BBS board (all the rave in those days) and explained the problem. They were quick to answer, tahnking us for bringing their attention to a problem, and they would get back to us. And they did, about two months later, sending us a new version of the chip, with a request that we try it out. We did, and it worked just fine.
It happens. No more, no less.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
