The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 2nd December 2012, 10:34 AM   #7741
dvv is offline dvv  Serbia
Originally Posted by nigel pearson View Post
It beats me ! I did notice in some set ups it sounds boomy if in wrong phase .
If anyone reads the Slew PDF I would be interested if anyone supports using Complimentary Feedback Pairs for the LTP input . The writer of the PDF uses a single input CmfbP if my memory is correct . The design I like is 90% the original Hitachi amp , 10 % me . I like the fact it gives 100 W and near op amp distortion at 50 kHz with only 7 transistor devices ( Hitachi , mine 10 ) . The pair I probably will use are 2SA1085 and 2N2504 . I recently tried a cascode VAS . It was no better and no worse .That is important as suitable transistors are now rare . 2 x 2SD756 + 2 x 2sB716 replaced by 2 x BC550C+ 2 x MPSA 42 + 2 x MPSA 92 . If was fantastically stable .
Have I not been clear, Nige?
Transistors are just as subject to fads and fashon as anything else. Over the decades, the vigorous Japanese semiconductor industry has reached a level of brainwashing that one is led to believe an amp without their products is simply almost not possible.
Nonsense.
Of course they have some very good semicondictors, and anyone disbelieving that should take another hard look at what's being offered. But by the same token, many have never encountered, or have forgotten, that quite a few non-Japanese manufacturers have as much, of not mor, to offer as well.
I realize the European BC series is badly suited to Amerian needs because they are mostly lower voltage, up to about 80V (BC 639/640), and the really low noise models don't go higher than 45V (BC 550/560), or 65V at best (BC 546/556). But where they stop, Motorola/ON Semi takes over.
How does it work? Well, let me just say this - around 80% of Krell amps are made using Motorola/ON Semi MPS series, there are over 120 of them in the voltage gain stage of EACH channel. And the rest is also by the same team, MJE 15030/15031 as predrivers, MJL series as drivers and output devices.
The voltage reg and output stages use custom MJL transistors, which are simply their well known output devices repackaged from plastic to metal TO-3 cans for more power.
High quality, high power devices have ALWAYS been America's forte, and specifically Motorola's forte. The Japanese never caught up, and Europe made only a few attempts worth mentioning over the decades, of which most are no longer being made.
Per Aspera Ad Astra.
Old 2nd December 2012, 10:55 AM   #7742
nigel pearson is offline nigel pearson  United Kingdom
Not really . When the Hitachi amp design came along the transistors were specially made to do the jobs . By combining BC550C and MPSA 42 I can get close . As a cascode the 45 V is not a problem used with MPSA 42 . Look at 2SD 765 ( PDF below ) . If is a bit like a very good 2N5551 . Then look at specifics . It more resembles the BC550 C yet in A version is good for 140 V . Cob is 1.6pF . Gain is > 250 ( 400 typical ) . 0.75W
2SA1085 is an interesting device . 0.5 nV noise , 120 V 0.4 W and high gain .
http://www.datasheetcatalog.org/data...or/mXwuuwq.pdf
Old 2nd December 2012, 11:28 AM   #7743
But Nige, these are all small signal devces, not power trannies.
And while you seem convinced of MOSFET's qualities as an audio powwer output device, frankly, I am not. They all have problems with large currents, another case of excellent Data Sheet but not nearly so excellent real life perofmrance. True, the latest generations do much better, and the prices have gone down, I suspect mostly because of IRF policies of cheap devices.
As for behaving "like a very good xxx ...", pray tell why would use something that behaves like when I can use the original? As a matter of principle, not this one case?
Old 2nd December 2012, 11:46 AM   #7744
The power transistor are nothing of the rest is less that it should be . Although I have never seen the 2SD756 and 2SB716 used with bipolar outputs I would expect them to be superb . If a complimentary feedback pair was made with your favourite Motorola outputs and drivers with suitable Vbe bias adjuster if should be out of this world good . My reading leads me to think in term of power delivery , current and purity at high frequencies it should be unbeatable . I like MOSFET's as they do 90% what you want without hassle . If matched sets are bought which is automatic if buying at trade price 25 pieces then the current delivery can be excellent using multiple pairs . Ron 0.8 R , absolutely no requirement for source resistors if matched . By the time you get to 4 devices the difference between bipolar and MOSFET is small . I note you use 0R47 so that is not far away .
As far as I know I have most of the 2SD756 that exist in the world . They are like 300 B 1941 stock
Old 2nd December 2012, 12:44 PM   #7745
Agreed on the view that power transistors are not much good without a good driver and possible a predriver.
You are wrong in my case, I haven't used a 0.47 Ohm emitter resitor in decades. I typically use 0.33 Ohms, Motorola MPC71 or MPC72 by default, and sometimes, 0.27 or even 0.22 Ohms. I currently have around 60 pcs of MPC71 0.33 Ohms on stock.
This preference is purely practical. They are not wirewound but use metal oxyde, and are hence not inductive to any significan degree, they are available in a wide range in 5W (MPC71) or 7W(MPC72) versions, unlike most other similar offerings they are rated at 5% (most others 10%) tolerance, and experience shows they will handle more than their power rating. In the last 30 years, not one has ever failed me.
Old 2nd December 2012, 04:03 PM   #7746
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by dvv View Post
What is missing from Keith's comment is how was this wide bandwidth achieved. Was is through inhrenetly wide bandwidth design, with an open loop full power bandwidth of say 100 kHz, then aided by relatively low global NFB of say 20-26 dB, a mix of more modest open loop bandwidth and more global NFB, or the traditional way, with lots of global NFB?
The only Spectral schematic I've ever seen a fragment of is a very early preamp, in one of John Linsley-Hood's books. But I recall some remarks Keith made about negative feedback some years ago in an interview and then some elsewhere, and he mentioned a relatively modest amount of global feedback, of the amount you tend to prefer, and as well that the input devices were small-geometry JFETs. He said the latter were slightly higher noise but permitted the amplifier to be faster, indeed specifically faster-settling.
Old 2nd December 2012, 04:16 PM   #7747
diyAudio Member RIP
Another remark or two about settling time: except for the nonrealizable totally flat response with frequency, the optimal open-loop response for fast settling to high accuracy is an integrator, that is, a response with a 6dB/octave falloff with frequency; for settling to less than perfect accuracy an amp with flat gain to the 6dB rolloff is the first compromise.
Real amps often approximate this in ways that are not exactly ideal in this respect. Some of the more successful opamps like the JE990 depart from it to get other advantages in distortion at high frequencies. Scott Wurcer remarked that the split compensation shown by Self and others, for enclosing the output stage within the pole-splitting network of the second stage (colloquially the "VAS", although Putzeys agitates to change this nomenclature), is shunned at ADI because of the deleterious effects on settling time.
Aside from anecdotal reports, with which we must include KOJ's (although I would personally give him a lot of credence ), I don't know of any controlled tests that discriminate among amps with different settling behavior.
It sounds like, from others' recent remarks, as if Bruno is exploring considerable departures from canonical fast settling singularity patterns of late, and must certainly be doing so in the belief that it is advantageous for audio.
Old 2nd December 2012, 04:23 PM   #7748
jcx is offline jcx  United States
given what is known about musical signals, audio transducers, human hearing it really doesn't seem likely that fast settling by ~ MHz gain intercept electronic amplifier time scales is required
Old 2nd December 2012, 04:35 PM   #7749
diyAudio Member RIP
I'm inclined to agree, at least as far as my own perceptual efficacies are concerned. But to paraphrase Lloyd Bentsen, I know Keith Johnson, and I'm no Keith Johnson.
Old 3rd December 2012, 06:58 AM   #7750
In my admittedly modest experience, extremely wide bandwidth, say 1 MHz response amps will also tend to overshoot, sometimes badly, and to ring a bit using square waves up to 20 kHz.
I also found out that when such an amp is endowed with an input filter in the 200-300 kHz region, overshoot all but disappears and the ringing is for all practical purposes done away with.
In other words, the Studer/reVox and Sony approach again. Make it as widedbandwidth as you can, then limit its input signal rate of change. A cutoff point of 200 kHz is the bandwidth of 24/196 and of course, 10 times above our limit of hearing. In my case, at 59, more than 10 times.
A trade-off is the added phase shift of the input filter. One of the reasons we want wide bandwidth is so that our phase shift, expressed as a square wave tilt at 20 kHz, is as small as possible, and the input filter will degrade it somewhat. By how much remains to be seen/heard, but in my view it's a good trade-off.
Actually, the above may well be one of the reasons why the British audio industry is so commited to bandwidth limiting to 60 or 70 kHz. I feel this is a bit too low, but I can see the reasoning.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
