The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 16th November 2012, 04:11 PM   #7601
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by dvv View Post
My speakers have to fill with sound a room of some 110 sq.ft., i.e. small. They are nominally 8 Ohms, minimum 6.5 Ohms, worst case phase shift is -25 degrees, effciciency is 92 dB/2.83V/1m.
My speaker cables are van den Hul Hybrid 352. That's a mix of silver plated OFC cable, mixed with carbon fibre (vdH has been a professor of metallurgy at a Dutch university for 40 years now). Cable has 2 x 256 strands and is capable of passing through well over 200 Amps.
My current range of readily available amps consists of cheap'n'cheerful low level (a bit above absolute entry level) 2x50W to very much High End 2x180W amps, from Toshiba, Marantz, Sansui, Harman/Kardon and Karan Acoustics ( Karan Acoustics | Manufacturer of High-End Audio ).
The point is not to go watt mad, I already have more watts available than I know what to do with. The point is twofold:
1. It has to be mine, I have to design and make it, for the hell of it, and
2. As John put it so aptly, it has to be done right.
At this time, I have a simulator working model which will nominally deliver 28.3 Vrms into 8, 4 and 2 Ohms, with minimal voltage loss, on a continuous basis. It will not clip up to around 175 W/8 Ohms, due to relatively high voltage lines, +/-63 regulated for everything including predrivers and drivers, and +/-56V for the output trannies alone. There should be two versions.
One should use 3 pairs of Motorola/ON Semi MJ 21195/21196 (metal can TO-3 trannies, rated at 250W each, 15 Arms, 30 Apeak, Ft > 4 MHz).
The other should use 4 pairs of Motorola/ON Semi MJL 3281/1302 (platic pack TO3, rated at 200W each, 15 Arms, 30Apeak, Ft > 30 MHz).
The two versions have a double purpose. One is to check out for myself a theory I have, which is that in many cases, older power devices, developed over decades, actually sound just as good and often better than the new(er) ones, even if their spec sheet says different. I have a nagging feeling that older power devices appear to be more stable than the new ones, and I want to check it out.
The other is to produce two solid power amps, which I can then use to biamp my speakers. If it turns out as well as I hope it will, perhaps a third unit later for the wife, who currently has a Harman/Kardon 680 integrated powering her JBL Ti600 floorstanders.
That's it in a nutshell. No binding peconceptions, my starting point is a fully complementary topology, but I do not insist on it.
The only thing I do insist on is fully electronic protection against overvoltage, overcurrent, overheating and excess DC. I do not trust fuses alone, I've seen far too many burnt out amps with "protection" fuses intact. I believe the fastest fuse we have is one made up of transistors.
That's it.
One of my amplifier is a PS audio 200CX it has a 3 pr output mounted on copper
Very good sonics , can even drive the amp killa ...
So i have one amp with 24 outputs / ch , one with 20, another with 12 and this PS audio with 6. Not sure if 6 is some kind of magic number , but it works , gold plated fuses and all ....
I still suggest you stay away from sonic killing protection , current limiting et al , KILL SONICS , if you are serious about it , don't do it ....
Regards ....
Old 16th November 2012, 05:34 PM   #7602
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Do you EVER have any snow, even if transient?
No. Otherwise houses would be better isolated.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 16th November 2012, 05:43 PM   #7603
dvv is offline dvv  Serbia
Regards ....
"3 pairs" is, at best, half information. I have seen just about anything in terms of 90, 100, 110, 130, 150, 180, 200 and 250 Watts rated devices in pairs. I think we'll agree pretty easily that it's not quite the same thing whether they are of the 90 or 250 Watt persuasion.
As for using copper for heat sinking, the best scheme I have ever seen so far is using a 3 mm thick copper plate in full back contact with a hefty aluminium fin heat sink. Copper has the advantage of faster heat transfer, but making entire heat sinks of copper must be ridiculously expensive, and I don't know anyone selling these.
However, substituting wiring with thick copper bars to link the PCB output points with the back side speaker binding posts is quite possible and is a good idea.
Regarding the number of output devices, this is both a matter of power requirements and personal choice. Some people I know swear that the total number must be an odd one (3,5, 7, etc pairs), others swear it must be an even one, and so forth.
Personally, I feel one needs to be practical about it. I do need several pairs because I am expecting significant power capability into 2 Ohms, and that power has to come from somewhere. On the other hand, increasing the number of output pairs complicates my life a lot due to the requierement of as close matching as possible. And I am not exactly Sony or some such to directly approach a manufacturer and order 100,000 matched pairs.
4 pairs of 200W devices is in potential power terms about 2.5 or 3 TIMES what the industry in general uses, but is still managable in terms of matching. Their work just fine, so mine should as well, only (hopefully) better.
As for protection circuits, I guarantee they will stay dormant until the load impedance starts to dip below 2 Ohms. In measurement terms, with or without them, I get exactly the same results even at 2 Ohms. So they stay.
Per Aspera Ad Astra.
Old 16th November 2012, 07:38 PM   #7604
Sin Bin
That is how it's done ... I will add this amp was built in 1990 ...
Old 17th November 2012, 08:17 AM   #7605
In 1990, just as in 10,000 BC, copper was still faster at transfering heat than aluminium was.
Wayne, there are so many things that can be done, it boggles the mind. The reason why many are seldom done is the usual suspect - price. And the added hassle.
I was thinking about having a copper plate machine bent (so there are no creases, deformities, etc) into an L shape, then bolting it to a hefty heat sink from the back side and then adding another half heigth sink on the front side. 20 years ago I wouldn't have wanted to do that, but today, with the proliferation of affordable CNC machines, it shouldn't be too much of a problem. Precision drilling is no longer a big, bad issue.
That should give me very good heat sink capability, admittedly WAY over what I need in everyday use, but - sort of - just in case I want to run it at high power levels for a longer time.
Given the areas involved, I'm going to need like a pound of thermal compound.
At this time, my current upper range of filters uses pure copper for its internal second bottom plate. I don't know if it helps, but I know it sure can't hurt. The point is, I already have some experience with copper; most materials require some hands-on experience to be comfortable with them.
Old 17th November 2012, 05:54 PM   #7606
bcarso is offline bcarso  United States
diyAudio Member RIP
One of the difficult aspects of copper, particularly the OFHC variety, is in the machining. One machinist I worked with at UCLA described it as "gummy". Of course it has also gotten very expensive.
Once machined, it's not very rugged, and then you also need to plate it to prevent corrosion. A lot of work. But, thick enough it is a pretty good magnetic shield as well as a thermal conductor.
Old 17th November 2012, 06:30 PM   #7607
magnoman is offline magnoman  United States
Why is faster copper better?
With regard to conductivity:
a 4-5:1 price difference to aluminum and 2:1 better conductivity seems like thicker aluminum wins easily.
-Antonio
Old 17th November 2012, 06:31 PM   #7608
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by bcarso View Post
One of the difficult aspects of copper, particularly the OFHC variety, is in the machining. One machinist I worked with at UCLA described it as "gummy”
One of the difficult aspects of copper for home diyers is power drilling.
Trimmed (shallow) cutting angle on the drill bit, rpm adjustment and less axial thrust is needed. And clamp component securely.
Otherwise, stacking (breaking) of the drill and damage of the copper component will occur.
Some hand fingure may be badly injured.
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 17th November 2012, 09:23 PM   #7609
Sin Bin
Just make sure it can drive this ......
Old 18th November 2012, 08:02 AM   #7610
Agreed, but Brad, I don't need any fancy work, just simple holes and that one bend at the bottom for the version using TO-3 metal can trannies. That's it.
@magnoman
True, however, as pointed out above, it's just plain boards with me. And, for once, where I live works in my favor - copper is mined and refined locally, the town of Bor in eastern Serbia is Europe's biggest copper mine, so prices are low enough not to matter (for plates and cables).
With aluminium, it's the other way around, it has to be imported, no local resources.
@gpapag
George, all I need is simple drilling, polishing and plating. Trust me, I've done this before, it's no problem at all, just a bit of hassle, because I have to scoot all around town - buy in one place, drill at another, plate at a third place. A tour of around 30 miles/50 km all told.
Obviously, I anticipate three amps, so I'll do the plates for all three in one go.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
