The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 26th September 2012, 12:04 PM   #7261
nigel pearson is offline nigel pearson  United Kingdom
Many years ago I think I remember one UK reviewer saying slew rates were like an arms race . Curious to know more a figure of about 6 V/uS was said to be enough for 100 W if real music . Anything above that a bonus or silly ? Having so many times read of greater slew rates I feel certain there is more to this story . A home cinema guy said he measured 1.3 W for dialogue ( 93 dB efficiency speaker ) , 250 W for the spaceship flying in . We covered symmetry the other day which I suspect was approved of ? Any ideas on minimum slew rates for 100 W ?
This link says about slew rates near the bottom of the page . By coincidence I have built nearly all these at some time having asked myself the same questions . Glad he thought it worth documenting .
Elliott Sound Products - Audio Power Amplifier Design Guidelines
One guy showed a 1 kHz square-wave and how to use it for evolution .He then said do not use a speaker for the test as the tweeter will fry . Too obvious ? Well it does say even that simple test has no musical reality .
Old 26th September 2012, 01:10 PM   #7262
fas42 is offline fas42  Australia
Banned
A simple way of looking at it is to consider a full power 20KHz sine wave. This has a period of 50uS, so to go from max -ve to max +ve rails takes 25uS. 25 x 6V/uS = 150, volts peak to peak, 75V rails. An amp with such could probably do near 400W into 8ohms; so I reckon we're safe ...
Frank
Last edited by fas42; 26th September 2012 at 01:16 PM. Reason: Woah! Love my arithmetic, must be the late hour ..
Old 26th September 2012, 05:13 PM   #7263
bcarso is offline bcarso  United States
diyAudio Member RIP
Also, see Putzeys' article in Linear Audio for his comments about the effects of slew rate when the signals approach, but don't exceed, the slew rate limits of the equipment. Jan posted a link.
Old 26th September 2012, 05:29 PM   #7264
john curl is offline john curl  United States
john curl's Avatar
You know, both Walt Jung and Matti Otala beat this topic to death with REAL measurements more than 1/3 century ago. It was found that 50V/us was necessary for a 100W amplifier, to be relatively SURE that TIM (SID) would not be generated.
What many here STILL seem to forget is 20KHz may be the highest frequency considered important in audio listening, BUT the working bandwidth goes on and on in many situations.
For example, for phono cartridge mistracking, 200KHz is pretty normal with MC cartridges, 500KHz has been measured. Where is your 6V/us THEN?
"Condemnation without Examination is Prejudice"
Old 26th September 2012, 05:51 PM   #7265
Thanks John . I had a hunch that would be the answer . One could almost say in audio a factor of ten more if you can . If overload margin of a phono stage that is probably a bit low . Not sorry I asked .
Old 26th September 2012, 06:10 PM   #7266
john curl's Avatar
Of course, it is also to be considered that future digital will have more effective bandwidth, with 24/192, 24/96, and SACD already here. You would be surprised how well these sources can fit the TIM profile, making 50V/us for a power amp, but only 5V/us for a preamp, pretty much a necessary spec for highest quality audio.
Old 26th September 2012, 06:24 PM   #7267
john curl's Avatar
A set of examples from 35 years ago. By the way, the newer Shure's are faster and wider bandwidth, even with normal loading, at least the best ones.
Old 26th September 2012, 06:38 PM   #7268
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
John do you have any references for that, papers or measurement reports where we can read up on it?
Edit: we xposted, you posted just above me, thanks
jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher
Old 27th September 2012, 12:13 AM   #7269
Banned
And of course the real answer, as John alluded to, for why really fast slew rate is necessary, is that it's required for the FB mechanism to function correctly. Funny concept, the amp has to work well enough to make sure the error correcting mechanism works well enough, hmmm ...
Frank
Old 27th September 2012, 06:30 AM   #7270
magnoman is offline magnoman  United States
My related question is, assuming the amplifier slew rate is fast enough to track the input, then is any additional slew rate margin a direct indicator of reduced SID.
It just seems to me this distortion is from larger nonlinear current swings in the input stage, so it could be reduced by reducing the current swing or making it more linear. If in the process this typically results in an increased measured slew rate, then maybe one can use this as in indicator but it still seems indirect to me.
Direct correlation to slew rate would imply that CFA type amplifiers would be automatically superior in this area (which may be true I don't know) but I dont even see a fundamental between a CFA and VFA if both are operating within the same i-v portion of the input transistors for the audio input.
Thanks (not sure I should have posted this, though crowd around here)
-Antonio
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
