The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 23rd July 2012, 12:03 PM   #6841
nigel pearson is offline nigel pearson  United Kingdom
DVV . Even the MP3 can sound good . A look at DAC's , buffers, clocks , and with and without final filtering perhaps . I think it is time I built a universal digital interface for myself .
The Meridian 14 bit CD players still to me had more magic than the others . They were highly praised in their own time . I wonder how many kept them when the CD discs improved ? They would have been very surprised . Maybe a little less detailed than the very best , like taking a slightly less good seat at the concert hall .
Even the best digital I suspect does not investigate the sub 1 watt ?
Old 23rd July 2012, 01:28 PM   #6842
dvv is offline dvv  Serbia
Originally Posted by nigel pearson View Post
DVV . Even the MP3 can sound good . ...
That I have yet to hear, MP3 without the bloated bass and weak treble.
But I'm a patient man.
Per Aspera Ad Astra.
Old 23rd July 2012, 04:47 PM   #6843
Charles Darwin is offline Charles Darwin  United Kingdom
My beef with MP3s isn't bloated bass or weak treble, it is a poor stereo image.
Basically what I get with MP3s is hard left-dead centre-hard right with nothing in between those points.
Old 24th July 2012, 01:04 AM   #6844
fas42 is offline fas42  Australia
Banned
I've done some interesting experiments of taking nominally fairly squalid MP3 files and resampling in Audacity up to the level of very high resolution files. MP3 -> 24/384 ... pretty extreme, huh, but it works! In terms of "fixing" the SQ, that is; at least, on playback via the very ordinary PC, on mainboard chip and conventional computer speakers.
Downsides are, very lengthy processing time in Audacity, and monstrous output file sizes ...
Why does this work? My theory is that a lot of the degradation is caused by the normal, real time processing of the MP3 file; if you offline the process then you get much, much better results.
Frank
Old 24th July 2012, 01:22 AM   #6845
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Audacity's SRC algorithm sucks - I get around -82dB 3rd harmonic, -86dB 5th harmonic distortion on a single 1kHz tone at full scale. Also it rolls off the top end frequency response somewhat.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 24th July 2012, 01:59 AM   #6846
Banned
Fair enough, I won't argue that technically there are inadequacies, perhaps other algorithms can do an even better job. My point, though, is that, in my experience, the resampling made the world of difference in the quality of replay of an ordinary MP3 file, which to me is purely a result of the CPU not having to decode the MP3 file in real time.
In particular, the quality of treble dramatically improved. A cymbal strike in the original MP3 was just a bit of dull, white noise; the resampled, hi res output was a hell of a lot closer to sounding like proper instrument shimmer ...
Frank
Old 24th July 2012, 02:07 AM   #6847
abraxalito's Avatar
Maybe it actually has nothing to do with the resampling at all. Perhaps the codec used by Audacity is a better one than in your fave media player?
Old 24th July 2012, 02:22 AM   #6848
john curl is offline john curl  United States
john curl's Avatar
What is 'better' abraxalito? I thought that you presumed that virtually all products are properly engineered or 'over-engineered'. How could there be any difference between the two? '-)
"Condemnation without Examination is Prejudice"
Old 24th July 2012, 02:42 AM   #6849
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
How mosquito with elephant eyes can be better than an ordinary mosquito? Better engineered = more optimal for the functions.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 24th July 2012, 02:44 AM   #6850
Banned
I tried, from memory, 3 different players. Including foobar2000. Made slight differences to replay of MP3, but nowhere to the degree that resampling to different rates did. Audacity was never used for replay, merely for the processing (blown sound chip on work m/c).
There was a very precise, stepped improvement in quality with each upping the ante: MP3 -> 16/44.1 -> 24/96 -> 24/192 -> 24/384. Each time, resampling from the original MP3, and creating ever larger files. The last round took about half an hour to process, for a normal pop track!
Again, I think the gains were that the CPU and sound chip were having ever easier times during replay, and less electrical thrashing means better sound quality ...
Frank
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
