The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 24th June 2012, 06:11 PM   #6361
1audio is offline 1audio  United States
Bigger caps mean smaller conduction angle and higher peak currents, which cause higher drops on the power source. Following it through leads to an impossible situation.
I suggest looking with both voltage a current probes to see what is actually happening. The peak currents for those big caps could radiate a long way from the cap diode transformer loop.
What good is low ripple voltage if the induced noise swamps it?
Demian Martin
Product Design Services
Old 24th June 2012, 06:18 PM   #6362
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by dvv View Post
Studer/reVox's A740 power amp
Serial production Motorola TO3's (5631/6031 = 200W/140Vce)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 24th June 2012, 06:18 PM   #6363
dvv is offline dvv  Serbia
Good point.
Which is why I advocate getting bigger capacities by using parallel "big" and "small" capacitor. Big = 22,000 uF, "small" = 10,000 uF. With good bypass and with bleeders.
Old 24th June 2012, 06:20 PM   #6364
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Pano View Post
I'm not a big fan, either, but what about batteries and caps?
Yes , better with caps , but we all felt at the time better with linear PSU ....
Old 24th June 2012, 06:24 PM   #6365
Sin Bin
Is this when the top end dies .... ?
Old 24th June 2012, 06:31 PM   #6366
Pano is offline Pano  United States
Pano's Avatar
Many amps have either an L or an R element in series after the rectifier and 1st cap. That's gotta make a difference.
Old 24th June 2012, 06:34 PM   #6367
On Hiatus
SY's Avatar
One could accuse engineering of finding the minimum that will possibly work - for a little while.
If that's the goal. Engineering is finding the right way to hit a target- deciding what that target is lies elsewhere. If the target is high performance and a set of goals are laid out, then engineering is a way of not doing silly things like using "rules of dumb" to accomplish religious goals while sacrificing real performance. The "bigger is better" is a perfect example- higher ripple currents have performance and reliability consequences, and a dumb rule like that ignores the realities of actual amplifiers.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th June 2012, 06:53 PM   #6368
Pano's Avatar
How do we know what the rules are?
If we see that a large number of amps judged to have strong power supplies have 1 joule per watt (or whatever) might that tell us something? The goals are interesting, the results more so.
One might engineer an amp for a certain amount of ripple, then find that there sonic advantages to going further. That seems to be what amp builders have been finding, tho I'm sure a lot of it is conjecture. Is all of it just audio voodoo, or do increasingly bigger PSUs bring real, audible benefits? Of course that would not be too hard to test, but might be expensive and time consuming.
Looking at what has already been done and the reported results is another way of finding out if the idea has merit.
Take the Speaker Voltage Test!
Old 24th June 2012, 06:53 PM   #6369
That sounds awfully like the politicians - they are also in total denial of everything, especially their own culpability. Realities they have already discarded as useless baggage a long time ago.
Old 24th June 2012, 06:56 PM   #6370
On Hiatus
SY's Avatar
That was my point- there are no rules, just a logical approach to getting the performance that you want. John gave a nice explanation, and when he and I are in agreement, you should treasure that moment.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
Copyright ©1999-2017 diyAudio
