The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 24th June 2012, 04:40 PM   #6341
dvv is offline dvv  Serbia
Originally Posted by Pano View Post
And that's basically what I was looking for.
For some reason when you ask for a rule of thumb or general practice, people fly into a fit and want to hit you over the head about "no Magic Answers" or "You can't generalize" or some such. Sheesh..... All I wanted to know is if anyone had noticed a relation between energy stored/output power and sound quality. (Sound Quality vs Measurements). It appears that no one posting here thinks in those terms, fair enough. Tho we can see that someone at Motorola did.
FWIW, many deluxe amps have much more than 1.5 joules per 10W. Is it just overkill?
Indeed? Please give one or two examples of having more than 1.5 Joules/10W and we can try to find out if that's an overkill.
Theoretically, as you add more and more capacitance, at some point you will reach a state which would equal full electonic voltage regulation, even if that point would, pricewise, be higher than with electonics. I mean in terms of effects - quite simply, your nominal power output into say 8 and 4 Ohms would not cause any appreciable voltage drop (sag) of the powers supply lines. I fear that would cost you a pretty penny indeed, but it is possible.
Old 24th June 2012, 04:42 PM   #6342
Originally Posted by nigel pearson View Post
I beg to differ a little . Say whatever maximum current will be . Times it by 1.5 for safety . Job done . The manufacturer will give the ripple ratings . Then add caps as your ears require . I would admit that the currents that might be required baffle most of us . Would anyone like to say ? Lets talk daft speakers and stupidly high wattage's ( 1 ohms 600 W ) . One problem is that the big amps draw current at the crest of the sine wave . Sometimes the caps hardly get a look in . My friends in the PA world use 3 phase power as it helps replenish the caps more often . They find there comes a time when no matter how big the caps are 3 phase does it better .
A quick, sure fire way to bankruptcy, Nigel.
On a per item basis, NOTHING in an amp is as expensive as capacitors.
Old 24th June 2012, 04:47 PM   #6343
Originally Posted by DF96 View Post
Not necessarily. Motorola were mainly hard-headed engineers, so it is very likely that their rule of thumb was derived in the way I explained i.e. the criterion was not 'sound quality' but x% droop in 10 ms (or 8.33 ms in US). This could be regarded as a ripple calculation, but ripple calcs usually assume full power sine-wave; I assumed full power square wave.
If your amp has good PSRR (including low power supply IM) then it may be the case that there is nothing more to be said: low enough ripple guarantees good enough sound. When people try to explain anything further they usually quickly fall back on myths and legends rather than genuine explanations. Now it may be that we don't know how much hum is low enough, or how much ripple IM is low enough, given that we can't have zero of either unless we use battery power. 'Too low to measure' is meaningless, as you can always measure lower if you try a bit harder.
I beg to differ.
Measuring say THD and/or IM at say 0.001% under worst case conditions is going down to academic values. I honestly see no point fighting now to make that 0.000,9%. That's just making the inaudible even more inaudible.
In my book, that is simply brainless. I prefer to stay on this side of sanity.
Old 24th June 2012, 04:55 PM   #6344
a.wayne is offline a.wayne  United States
Sin Bin
Are you calling my speakers daft ..
Ok , they are , but the sound isn't , my findings , too much hurt the top end , too little muddies the sound , so I agree with John , there's no set formula, now how do we combine the two ..?
Ohh.....
Battery power kills dynamics , been there done that .....!
Old 24th June 2012, 04:58 PM   #6345
Sin Bin
And nothing in the amp hurt the sound more ....
Old 24th June 2012, 05:06 PM   #6346
Pano is offline Pano  United States
Pano's Avatar
I thought I did yesterday. See this post:
http://www.diyaudio.com/forums/showthread.php?p=3070031
Or am I not understanding Motorola's 1.5 joules/10W? I see that as 0.15 joules per output watt.
Old 24th June 2012, 05:07 PM   #6347
Pano's Avatar
I'm not a big fan, either, but what about batteries and caps?
Old 24th June 2012, 05:25 PM   #6348
popilin is offline popilin  Argentina
popilin's Avatar
The old holy grail of science:
-The unified field theory.
The new holy grail of science:
-An equation for optimizing an analog power supply.
And do not speak of a rule of thumb, and even less of a rule of Dumb.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 24th June 2012, 05:28 PM   #6349
On Hiatus
SY's Avatar
Bigger is better.
If you like higher ripple currents, sure. This is another audiophile legend, I'm afraid, one to which I succumbed for many years until I started looking more carefully at what was actually going on in the power supply. As well, adding capacitance until there's no more ripple (whatever "no more" means) is an invitation to make the overall system noise performance worse.
Maybe I'm just a nutcase, but the more sensible approach seems to be to specify the required noise level at the amp output, and knowing the power supply rejection of the signal circuit, work backward to see what acceptable ripple is. Then design the supply for something lower than the maximum acceptable ripple, but not too much lower in order to keep ripple current to a minimum.
Of course this is engineering, not "design."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th June 2012, 05:39 PM   #6350
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
examples
Only two ?
Metaxas Soliloquy monaural, 1984.
About 1 J/W, +1600VA transformer for 100W/8.
See post 6159
2nd one, post 6241
1 J/W, +3000VA toroidal for 500W/8
(plenty more, up to some years ago i used to calculate every imaginable correlation factor/coefficient of commercial amps, professional disease)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
Copyright ©1999-2017 diyAudio
