The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 7th January 2012, 08:33 PM   #621
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by Steve Eddy View Post
Thanks, one of those transfer functions is a pretty horrible non-physical crossover region with discontinuities that have singularities in the derivatives. I don't use LM324's why should anyone?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 7th January 2012, 08:48 PM   #622
john curl is offline john curl  United States
john curl's Avatar
Scott, you work for an IC company, you can use anything that you want. However, much mid-fi equipment will NOT use ADI and will probably use the cheapest stuff possible. Do you guarantee that every IC now commonly available for audio has a good enough transfer function?
"Condemnation without Examination is Prejudice"
Old 7th January 2012, 08:57 PM   #623
DF96 is offline DF96  England
The discontinuities had to be smoothed away when calculating the metric, so might have affected the results. The metric value for these would be more or less wholly determined by the smoothing applied, so there would be scope for adjustment.
Old 7th January 2012, 09:13 PM   #624
john curl's Avatar
X-over distortion in any form is bad, sonically.
Old 7th January 2012, 09:35 PM   #625
wahab is offline wahab  Algeria
Hitachi decades old lateral fets allow for 10V wide crossconduction region
with as low as 100mA quiescent current/device for a three pair push pull , it should
keep any crossover distorsion being more of a ghost than an actual problem.
Old 7th January 2012, 10:00 PM   #626
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I agree with Jon here: when building something for high end potential flaws have to be examined under microscope. Like, apply 1 MHz triangle on full swing to see close how it behaves on 20 KHz sine. If it is subtle on oscilloscope and hard to measure, it may be well audible as "something is odd". But if it looks nice, fronts of squares are equal, that means at least stereo image would not be blurred by phase intermodulation.
The Devil is not so terrible as his math model is!
Old 7th January 2012, 10:03 PM   #627
Wavebourn's Avatar
That's why I don't like symmetrical amps in this regard: single ended amps can't have them at all. But in order to save trees and the world from global warming I use push-pull topologies.
Old 8th January 2012, 12:59 AM   #628
I saw, this adds an element of contrivance however small. In any case a transfer function this bad would hardly be expected when comparing reasonably well designed products.
Old 8th January 2012, 01:26 AM   #629
john curl's Avatar
LIKE DUH, Wavebourn, of course single ended amps don't have Xover distortion. They are ALL Class A!
Old 8th January 2012, 01:47 AM   #630
Wavebourn's Avatar
DUH, John, and they EAT electricity!
I bought some cheap PCB with 4x100W class D amp, going to try for woofers and subwoofer... Have no time now though, wife is coming from Florida (conference), need to clean up in the house... Bought 4 boxes of such drivers, $1 each, need to find the place for them in my barn... Going to try tall open baffle line arrays.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
