The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 21st June 2012, 02:06 AM   #6221
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by nigel pearson View Post
Thanks John .
This was the very conversion I had coming home last night . I said 1 KVA as I think it is the limit of a responsibly designed product . My friend who I know agrees said no way , make it 2 KVA as it is Audio and they will appreciate it . This has profound importance for me a I want to use one component for a range of products . I seem to remember the 4KVA is 45 Kg's ( 100 lbs ) . I think 1 KVA units will be fine and allow 2KVA spaces in boxes .
I strongly suspect 2KVA and only 10 000 uF will sound better than 1KVA with 22 000 uF . It's a hunch from all the amps I repaired in 23 years in a previous life .
Also,
When listening , I like to unplug and amplifer should continue playing for at least 5 seconds Without obvious noise and distortion ....
Old 21st June 2012, 08:10 AM   #6222
nigel pearson is offline nigel pearson  United Kingdom
I have no doubt 80 000 uf is fine . The irony is that 2 KVA and 10 000 uF is cheaper than 1 KVA and lets say 88 000 uF if talking high quality ( it is in my world ) . I have a small hunch the 2 KVA / 10 000 will sound better and especially in therms of punch . Maybe even better than 700 VA and 80 000 uF . That one might be capacitor heavy ?
A well designed PSU with respect to all the usual things ( which I never seem to get right if my oscilloscope isn't lying to me ) . Would deliver massive current even if 10 000 uF . The wires to the transistors should be massive ( half inch I don't doubt , direct to collectors usually or drain ) . That causes problem number one . As massive cables cause HF reduction . The decoupling caps can rescue that problem ( usually about 220 uF ) . If the PSU voltage is about 5 V above the driver PSU voltage there never is a problem with ripple . If class A it gets more complicated . Caps on the PCB isn't such a bad idea with copper reinforcement . Almost design the PSU first if doing that .
The 5 seconds is not required ( I like it also ) . 0. 1 will do . However a bank of lets say 22 000 uf charged every one second has merit ( charge is mS in reality ) . The amp never seeing the rectifier by using a flip flop switch ( MOS FET's in saturation ) . Some guy has a patent on that . What a nerve as it is so obvious . A commutator or distributor . One could even have something very simple like a PSU that switched in caps simply as the volume was advanced . It wouldn't need a fancy computer for that . It might then have a more delicate sound when it mattered ( 1000 uF + 10 000 uF + 22 000 uF .... ). Equally a very simple feed-forward signal switching idea could work . Not class H , just part of the general commutation . If hammering the speakers switch the commutation off and go conventional . I had the idea years ago but didn't do anything .
The LC resonance of the PSU is interesting . Nearest I can give you is the inductance of a big VOX output transformer I have somewhere at 500 H .
Old 21st June 2012, 11:02 AM   #6223
dvv is offline dvv  Serbia
How true!
I just received the new price list of my transformer manufacturer:
500 VA: 135*60 mm, 4.3 kg (9.5 lbs), V. drop 4%, US$ 64.50
1000 VA: 170*80 mm, 6.7 kg (14.8 lbs), V. drop 2%, US$ 103
1500 VA: 210*70 mm, 9 kg (20 lbs), V. drop 2%, US$ 162
2000 VA: 210*90 mm, 11 kg (24.2 lbs), V. drop 2%, US$ 198.
"V. drop" refers to the voltage drop from load off to full load on voltage.
Now, I have to pay €24 app. US$ 30) per BC Components 22,000 uF/63V capacitor. So, assuming that each channel will need 2 such caps, the caps alone will cost me €96, or about US$ 120.
A good quality 10,000 uF/63V cap will set me back €12...15, depending on which one I choose and its quality, let's say € 15. That's about US$ 18.8.
So, a 2000 VA transformer with 4 10,000 uF caps, as Nigel suggested, would cost me (198 + (4*18.8)) $ 273.20.
A 1000 VA transformer with 4 22,000 uF caps would cost me (103 + (4*30) $ 220.
Therefore, Nigel's reasoning is at least for me locally is absolutely true.
Of course, things may change somewhat if one needs caps of 80 or 100 V, because their prices quickly escalate above the popular 63V limit, I don't know by how much because I never need them.
On the other hand, it all depends at what kind of power are you looking at. A 200 WPC amp will necessarily cost more than a 100 WPC amp. The way Nigel is going, he'll end up asking his amp to do something like 1,500 Watts into 1 Ohm, in which case he's in for a whopping power supply bill.
Old 21st June 2012, 11:44 AM   #6224
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The irony is that 2 KVA and 10 000 uF is cheaper than 1 KVA and lets say 88 000 uF.
Originally Posted by dvv View Post
a 2000 VA transformer with 4 10,000 uF caps, would cost me $ 273.20.
A 1000 VA transformer with 4 22,000 uF caps would cost me $ 220.
Therefore, Nigel's reasoning is locally absolutely un-true.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 21st June 2012, 12:30 PM   #6225
Sin Bin
Old 21st June 2012, 01:04 PM   #6226
Yes, sorry, I swapped theses.
As for how each might sound, well, there's only one way to find out.
Old 21st June 2012, 01:05 PM   #6227
Originally Posted by a.wayne View Post
Smile when yuh grin, stranger!
Old 21st June 2012, 01:05 PM   #6228
China's import of copper has driven the price of raw copper up over the last ten years.
A decent 1kVA toroidal does over $225 overhere.
For standard series transformers above 300VA, transformer price goes up almost linearily with VA/weight number, so 2kVA would be roughly twice the amount of a 1kVA.
Unfortunately, 2kVA is not standard for most toroidal winders, so $/VA goes up instead of down.
(raw copper is expected to take a dive in a couple of years, hopefully tranny prices go down as well)
Not so for electrolytic capacitors, the large the cap value, the lower $/uF (for sane voltage ratings).
But for small time DIY folks there's also price breaks : 10 times 10.000uF may be cheaper than buying 22.000uF lytics.
A comparison doesn't hold water anyway, the number of uF will depend more on the secondary voltage of the transformer than the VA size.
(1kVA with 2% regulation is amazing, a low weight one normally does 5%, 7.5kg/16.5lb and up do 4%)
Old 21st June 2012, 01:22 PM   #6229
I just asked my supplier the same and got the reverse answer . I chose DNM ( BH ) slit foil caps at £20.42 ( 10 000 uF 80 V ) for an example . Mundorf was too complicated to look at ( too many choices ) . BBH would be fine .
1KVA + 160 000 uF = £407.72 inc VAT 20% ( £ in the old Latin for pound ).
2KVA + 20 000 uF = £250.84 inc VAT
2KVA + 40 000 uF = £291.68 ( Best ? )
I am placing the voltage at 70 +/- max which seems about right if using these VA's
Those prices change with quantity . Doubtless you can buy cheaper caps . As JC would say we should always do our best .
I recently bough loads of 4700 uF 100 V at £1.84 . they are great to do experiments with ( Sun Tan , yes , China , Rapid UK ) . They even have decent ripple current !
Old 21st June 2012, 01:30 PM   #6230
81 pounds for a 1kVA, ~$125, and $30 each slit foil caps ?
How realistic.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
